OPA2374: The output increase suddenly
Part Number: OPA2374
Hi Team
   My customer use OPA2374 for the PFC current senseing in a power mode. When the PFC MOSFET Q7-1 turn off, the output of opa2374 is increased suddenly, and it is not normally. Below is the schematic and test waveform. Pls. help to give some suggestion. thanks
  • Hi Aggli,
    C40 looks weird! Remove it and place a 10p cap in parallel with R51. If the low pass filtering effect is too little, increase this cap and C39, but keep the both caps identical. Otherwise the common mode rejection of this difference amplifier will degrade.
    Take care, the common mode input voltage range of OPA2374 is only 0.2V below GND. If you violate this specification the OPA2374 will stop working properly.
    Kai
  • Hi Kai
    thank you for your comment, and we will try. we will update the result to you later.
