Other Parts Discussed in Thread: OPA4350
We have a question regarding using the OPA350 to drive voltage reference pins on the TMS320F28375DZWT.
- Is it better to drive the different ADC VREF pins with 4 separate OPA350 (single opamp) or 1 quad device like OPA4350?
- Can noise internally couple from internal devices in an OPA4350?
- What kind of offset difference could we expect between 4 OPA350 versus 1 OPA4350?
We’re using the four ADCs to take four simultaneous samples with the same sampling window. Every half PWM period we trigger each ADC to take a sequence of four conversions for a total of 16 samples. Our concern is that each op-amp buffer is going to have its own offset. Wouldn’t it just be better for each ADC to have exactly the same reference?
The reference path we have going out to analog circuits adds another layer of complication. Those circuits now see a buffered reference that is different from the references presented to the ADCs. Theoretically it’s the same but again, each buffer is going to have its own offset and other non-idealities. So, are we hurting ourselves by having this separate buffered path? Can we get away with a single buffered reference that goes everywhere?
According to the DSP Technical Reference Manual (http://www.ti.com/lit/ug/spruhm8g/spruhm8g.pdf )..
Thank you, Keith
