  • TI Thinks Resolved
LM239: LM239 common mode input voltage range
Prodigy 170 points
Part Number: LM239
Good morning,
What about the input common mode range of the comparator LM239.. It is valid what the datasheet says about out of range at page 13?:
The following list describes the outcomes of some input voltage situations.
• When both IN– and IN+ are both within the common-mode range:
– If IN– is higher than IN+ and the offset voltage, the output is low and the output transistor is sinking
current
– If IN– is lower than IN+ and the offset voltage, the output is high impedance and the output transistor is
not conducting
When IN– is higher than common mode and IN+ is within common mode, the output is low and the output
transistor is sinking current
• When IN+ is higher than common mode and IN– is within common mode, the output is high impedance and
the output transistor is not conducting
• When IN– and IN+ are both higher than common mode, the output is low and the output transistor is sinking
current
Thank you..
  • Hi Roger,
    please don't open a new thread. This merely results in total confusion.
    e2e.ti.com/.../779018
    Kai
  • In reply to kai klaas69:
    Roger
    Since there has been no further discussion on this thread, I am closing it. If more support is required, please hit Reply and the thread will be re-opened.
    Chuck
