Other Parts Discussed in Thread: OPA2990
Hello;
We are using OPA170 as open loop comparator where at inverting terminal is a Pot to set reference threshold. At non inverting terminal there is a output of our circuit. Effectively at the i non inverting terminal of ap-amp is 0.1uF cap in parallel with 1Meg Resistor.
During normal operation there is no issue. But when this circuit is exposed to High electromagnetic filed then what we see is that 0.1uF gets charged to 0.6V TO 1V. We initially through that EM waves might be inducing this voltage inside the circuit through a track or a loop But that was not the case. Hence finally what we did was keeping every thing same we just disconnected the supply pins of op-amp and tested again. This time there was no voltage observed across 0.1uF cap.
Hence want to know is it possible that due to external EM wave there might be high noise of power supply time and hence hence power supply is noisy at the supply pins of op-amp. Due to this noise on power supply will lead to strange behavior of the op-amp and hence it might be charging the 0.1uF capacitors which is at the non inverting input terminal of op-amp.
