Other Parts Discussed in Thread: TLV7011, TLV7021, TLV1805
Hi Team,
Here need your help to have the suggestion for the application issue and circuit as attached.
My customer uses TLV3201 for Over current sensing and face the issue that some parts will be low impedance and some parts will be high impedance under no Vcc supply condition (off mode). It looks the OP output is on uncertain mode. Can't control it would be high or low impedance mode when no Vcc applying. This kind of high /low impedance behavior will follow the IC when do the OP SWAP checking.
My customer application needs to the output can keep high impedance when no Vcc applying condition. Does it mean that it needs to select open drain type for this kind of application or others?
Need your help to provide the circuit suggestion or suitable part but with the similar performance as TLV3201 for it.
Albert Lee.
