Other Parts Discussed in Thread: TLV1701, , INA186
With a larger sense resistor like a 10 ohms used with the INA199A2, should we expect a larger amount of current being taken at the power supply pin when the current being sensed and therefore the voltage across the 10 volts is higher? The power supply is around 3.1Volts.
The output is connected to a high impedance like the input of a TLV1701 comparator.
