May we know the minimum data rate that this device can handle? Customer needs data and we are unable to find information/verify it with the datasheet.
Thank you
Thank you
Hi Elisha,
ONET1151P has been characterized down to 1.0625Gbps. Low frequency cut off is in order of 20KHz so theoretically device should be able to handle lower rates however it has not been characterized across voltage and temperature for data rates below 1.0625Gbps.
Regards,, Nasser
