Part Number: AMC1301-Q1
The latest datasheet of "AMC1301-Q1" released in April 2017, specifies the Input Bias Current to be 60uA. But the latest datasheet of "AMC1301" ( updated in March 2018 ) specifies the Input Bias Current to be 30uA. Please confirm this updated specification is applicable for "AMC1301-Q1" as well.
Hi SR,
This is applicable to the AMC1301Q-1 as well. It was originally intended to mean both Inputs Bias Current together equals 60uA, but it was confusing. We're in the process of updating the datasheet.
As a reminder, this bias current can cause significant offset when performing voltage measurements depending on the size of the shunt resistor. If you're looking at performing a voltage measurement with the AMC1301-Q1, please consider a device with higher input impedance such as the AMC1311-Q1.
Alex SmithApplications Engineer | Precision Delta-Sigma Converters
Check out our helpful resources: BIO-FAQ: Common Questions for TI's ADS129x Family of Bio-Potential ADCs
TI Precision Data Converters | TI Precision Labs - ADCs | Analog Engineer's Calculator | Data Converters Learning Center | Selection Guide
