Part Number: LM2903-Q1
Hello All,
To select correct part number for automotive products, can you please specify the difference between following part numbers:
LM2903AVQPWRG4Q1 and LM2903AVQPWRQ1
Shrikant L
Hello Shrikant,
Electrically they are the same device (same die, same electrical tests). There is a slight difference in the epoxy mold compound used.
The "G4" or "E4" suffix was used to differentiate RoHS material from the non-RoHS devices at the time (2007), until the base device was converted to RoHS.
http://www.ti.com/support-quality/environmental-info/lead-free/lead-free-conversion.html
The LM2903AVQPWRQ1 was converted to RoHS in 2009. It is common for the "G4" version to eventually be obsoleted (depending on demand) once the base device is converted to RoHS.
You can see the details in the Material Content Search:
http://www.ti.com/materialcontent/en/search?partType=tiPartNumber&partNumber=LM2903AVQPWRG4Q1%2CLM2903AVQPWRQ1
Paul Grohe
TI Comparators (CMPS) Applications Group
In reply to Paul Grohe:
Thank You Paul.
