For the INA826AIDRG when using DUAL SUPPLY what connection to the thermal pad (if any ?) should be made ?
Hi Shmuel,
The thermal pad needs to connect to the most negative V(-) supply.
I will contact the product line so they add/clarify this information on the datasheet.
Thank you and Regards,
Luis
Dear Luis,
Thank you for getting back to me so quickly. I will make the connection as you outlined.
Please could you let me know when the data sheet is updated ?
Best regards
Shmuel
Hi Shmuel,
I will check again with the systems engineer, it may take some time for the datasheet update to post on the web.
Luis
HI Shmuel,
I am told that the datasheet update for the INA826 is expected by the end of June due to a queue on other device datasheet developments.
Thank you,
Luis
