Hi TI experts,
I am designing pir circuit with bluetooth low energy. I use TLV8544 to amplify the signal from the pir and bluetooth ic will receive the signal for processing.
it is my schematic for my project.
and Bluetooth chip, i use TLSR253 from telink semiconductor.
I'm having a very complicated problem and I've been trying to fix it for a week now and it didn't work.
whenever I send my message board via bluetooth I get a signal pulse from the output of the 2nd amplifier floor ( TP10 ). The PIR block works perfectly when i don't send any message boards via bluetooth.
I'm using boost converter +3V3 TLV61224DCKR for the Vin.
I tried removing the boost converter to use battery power directly for the circuit but the problem still didn't get solved.
Even though I used two different sources to supply the module, of course I grounded the two sources, I still received the signal pulse from TP10.
This is a signal from TP10 when I sent a message board from Bluetooth (I created a dark room to cover the sensor).
Where can this cause come from?
Thank you.
