OPA2333-HT: ADC buffering
Part Number: OPA2333-HT
Other Parts Discussed in Thread: OPA2333,
I am using the OPA2333 in my application to reduce components to help achieve my design size restraints.  I am wanting to use a single OPA2333 device to buffer two separate ADC inputs (one channel on op amp A and the other on op amp B).  Should I be concerned with cross talk if I take precautions on the signal traces leading up to the device?  I do plan to run each signal trace with enough space between to allow for a ground trace to be placed all the up to the OPA2333.  Any suggestions on further protecting from cross talk?
Thank you,
Brandon
