in our application INA303 is putting the ALARM pin in an active state, immediately after power up (this is likely due to the slow power-up as mentioned in the datasheet).
Now, we also use the Latched mode, which holds the ALARM state and a reset is required. After the reset, everything works fine.
Question, is there any hardware workaround here, or just the software one (disregarding the alarm until power up stage is finished)? Would like to keep using Latched mode while not needing to perform a reset, hardware workaround would be best to have.
Thanks.
