Hello
Could ALERT Pin be used for OCP only?
How do I to configure if available?
Best regards.
Hello
Hello Louis,
Thanks for considering to use Texas Instruments. Yes it can be used for OCP only. While the ALERT can be asserted for several different triggers, only one trigger source can be specified at a time. The trigger setting with the highest bit value in the register takes priority if multiple triggers are enabled, and only that trigger is monitored.
