Other Parts Discussed in Thread: INA253, INA240
I have the application of the solenoid control circuit and the circuit can able to tell the status of the solenoid(open/close),is there any way to find the slow movement of the solenoid, faulty.
In my application i am using PWM controlled solenoids and Non PWM controlled solenoid(ON/OFF) with help of signal from DSP so all this circuit i need to use same IC which can detect the movement of the plunger..and hall sensor based IC not required because of the space availability.
which one is good either bidirectional current measurement and unidirectional current measurement for my application?
Iam using 24v solenoids
also you can suggest any IC whican cover all my requirement given above..
