Other Parts Discussed in Thread: TINA-TI, LMP7718
I could find some model like TINA spice model for this LMP7721, but I could not find anything compatible with HSPICE.
How can I find HSPICE compatible model (subcircuit) for this LMP7721 opamp?
Hello Jari,
The LMP7721 simulation model was designed and updated a few years ago to run on our most popular simulator TINA-TI, and other Pspice based simulators such as Cadence PSpice and TopSPICE. It will run on other Pspice based simulators providing they don't use unique syntax specific to that particular simulator.
I was just looking over information online about HSPICE. I was left with the impression that some users import PSpice models into HSPICE, and run them successfully. It is likely a matter of the model design and compatibility between the two simulators.
I suggest you try using the LMP7721 text file listing I have attached, and set up HSPICE model and symbol files using it. Put the resulting simulation model in a simple op amp circuit and see if it runs, or produces error outputs. Unfortunately, if it doesn't run TI doesn't have resources to support HSPICE models. If you have issues with it running in HSPICE you may want to contact the help services at the company that produces the software.
Regards, Thomas
Precision Amplifiers Applications Engineering
*$ * LMP7721 ***************************************************************************** * (C) Copyright 2019 Texas Instruments Incorporated. All rights reserved. ***************************************************************************** ** This model is designed as an aid for customers of Texas Instruments. ** TI and its licensors and suppliers make no warranties, either expressed ** or implied, with respect to this model, including the warranties of ** merchantability or fitness for a particular purpose. The model is ** provided solely on an "as is" basis. The entire risk as to its quality ** and performance is with the customer ***************************************************************************** * * This model is subject to change without notice. Texas Instruments * Incorporated is not responsible for updating this model. * ***************************************************************************** * ** Released by: Online Design Tools, Texas Instruments Inc. * Part: LMP7721 * Date: 25JAN2019 * Model Type: Generic (suitable for all analysis types) * EVM Order Number: N/A * EVM Users Guide: N/A * Datasheet: SNOSAW6E - JANUARY 2008 - REVISED DECEMBER 2014 * Created with Green-Williams-Lis Op Amp Macro-model Architecture * * Model Version: Final 1.2 * ***************************************************************************** * Updates: * Final 1.2 * Updated claw, Added Vos drift. * * Final 1.1 * Release to Web. * ***************************************************************************** * Model Usage Notes: * 1. The following parameters are modeled: * OPEN-LOOP GAIN AND PHASE VS. FREQUENCY WITH RL, CL EFFECTS (Aol) * UNITY GAIN BANDWIDTH (GBW) * INPUT COMMON-MODE REJECTION RATIO VS. FREQUENCY (CMRR) * POWER SUPPLY REJECTION RATIO VS. FREQUENCY (PSRR) * DIFFERENTIAL INPUT IMPEDANCE (Zid) * COMMON-MODE INPUT IMPEDANCE (Zic) * OPEN-LOOP OUTPUT IMPEDANCE VS. FREQUENCY (Zo) * OUTPUT CURRENT THROUGH THE SUPPLY (Iout) * INPUT VOLTAGE NOISE DENSITY VS. FREQUENCY (en) * INPUT CURRENT NOISE DENSITY VS. FREQUENCY (in) * OUTPUT VOLTAGE SWING vs. OUTPUT CURRENT (Vo) * SHORT-CIRCUIT OUTPUT CURRENT (Isc) * QUIESCENT CURRENT (Iq) * SETTLING TIME VS. CAPACITIVE LOAD (ts) * SLEW RATE (SR) * SMALL SIGNAL OVERSHOOT VS. CAPACITIVE LOAD * LARGE SIGNAL RESPONSE * OVERLOAD RECOVERY TIME (tor) * INPUT BIAS CURRENT (Ib) * INPUT OFFSET CURRENT (Ios) * INPUT OFFSET VOLTAGE (Vos) * INPUT OFFSET VOLTAGE VS. TEMPERATURE (VOS DRIFT) * INPUT COMMON-MODE VOLTAGE RANGE (Vcm) * INPUT OFFSET VOLTAGE VS. INPUT COMMON-MODE VOLTAGE (Vos vs. Vcm) * INPUT/OUTPUT ESD CELLS (ESDin, ESDout) ****************************************************** .subckt LMP7721 IN+ IN- VCC VEE OUT ****************************************************** .model R_NOISELESS RES(T_ABS=-273.15) ****************************************************** I_OS ESDn MID -3e-15 I_B 30 MID 3e-15 V_GRp 45 MID 107 V_GRn 46 MID -80 V_ISCp 39 MID 46.9786 V_ISCn 40 MID -19.9733 V_ORn 38 VCLP -12 V11 44 37 0 V_ORp 36 VCLP 14 V12 43 35 0 V4 27 OUT 0 VCM_MIN 67 VEE_B -0.3 VCM_MAX 68 VCC_B -1 I_Q VCC VEE 0.0013 XV_OS 75 30 VOS_DRIFT_LMP7721 XU5 ESDp ESDn VCC VEE ESD_0_LMP7721 XU4 19 ESDp MID PSRR_CMRR_0_LMP7721 XU3 20 VEE_B MID PSRR_CMRR_1_LMP7721 XU2 21 VCC_B MID PSRR_CMRR_2_LMP7721 XU1 23 22 CLAMP VSENSE CLAW_CLAMP CL_CLAMP 24 26 27 MID AOL_ZO_0_LMP7721 C28 31 MID 1P R77 32 31 R_NOISELESS 100 C27 33 MID 1P R76 34 33 R_NOISELESS 100 R75 MID 35 R_NOISELESS 1 GVCCS8 35 MID 36 MID -1 R74 37 MID R_NOISELESS 1 GVCCS7 37 MID 38 MID -1 Xi_nn ESDn MID FEMT_0_LMP7721 Xi_np MID 30 FEMT_0_LMP7721 Xe_n ESDp 30 VNSE_0_LMP7721 XIQPos VIMON MID MID VCC VCCS_LIMIT_IQ_0_LMP7721 XIQNeg MID VIMON VEE MID VCCS_LIMIT_IQ_0_LMP7721 C_DIFF ESDp ESDn 5e-12 XCL_AMP 39 40 VIMON MID 41 42 CLAMP_AMP_LO_0_LMP7721 SOR_SWp CLAMP 43 CLAMP 43 S_VSWITCH_1 SOR_SWn 44 CLAMP 44 CLAMP S_VSWITCH_1 XGR_AMP 45 46 47 MID 48 49 CLAMP_AMP_HI_0_LMP7721 R39 45 MID R_NOISELESS 1T R37 46 MID R_NOISELESS 1T R42 VSENSE 47 R_NOISELESS 1M C19 47 MID 1F R38 48 MID R_NOISELESS 1 R36 MID 49 R_NOISELESS 1 R40 48 50 R_NOISELESS 1M R41 49 51 R_NOISELESS 1M C17 50 MID 1F C18 MID 51 1F XGR_SRC 50 51 CLAMP MID VCCS_LIM_GR_0_LMP7721 R21 41 MID R_NOISELESS 1 R20 MID 42 R_NOISELESS 1 R29 41 52 R_NOISELESS 1M R30 42 53 R_NOISELESS 1M C9 52 MID 1F C8 MID 53 1F XCL_SRC 52 53 CL_CLAMP MID VCCS_LIM_4_0_LMP7721 R22 39 MID R_NOISELESS 1T R19 MID 40 R_NOISELESS 1T XCLAWp VIMON MID 54 VCC_B VCCS_LIM_CLAW+_0_LMP7721 XCLAWn MID VIMON VEE_B 55 VCCS_LIM_CLAW-_0_LMP7721 R12 54 VCC_B R_NOISELESS 1K R16 54 56 R_NOISELESS 1M R13 VEE_B 55 R_NOISELESS 1K R17 57 55 R_NOISELESS 1M C6 57 MID 1F C5 MID 56 1F G2 VCC_CLP MID 56 MID -1M R15 VCC_CLP MID R_NOISELESS 1K G3 VEE_CLP MID 57 MID -1M R14 MID VEE_CLP R_NOISELESS 1K XCLAW_AMP VCC_CLP VEE_CLP VOUT_S MID 58 59 CLAMP_AMP_LO_0_LMP7721 R26 VCC_CLP MID R_NOISELESS 1T R23 VEE_CLP MID R_NOISELESS 1T R25 58 MID R_NOISELESS 1 R24 MID 59 R_NOISELESS 1 R27 58 60 R_NOISELESS 1M R28 59 61 R_NOISELESS 1M C11 60 MID 1F C10 MID 61 1F XCLAW_SRC 60 61 CLAW_CLAMP MID VCCS_LIM_3_0_LMP7721 H2 34 MID V11 -1 H3 32 MID V12 1 C12 SW_OL MID 100P R32 62 SW_OL R_NOISELESS 100 R31 62 MID R_NOISELESS 1 XOL_SENSE MID 62 33 31 OL_SENSE_0_LMP7721 S1 24 26 SW_OL MID S_VSWITCH_3 H1 63 MID V4 1K S7 VEE OUT VEE OUT S_VSWITCH_4 S6 OUT VCC OUT VCC S_VSWITCH_4 R11 MID 64 R_NOISELESS 1T R18 64 VOUT_S R_NOISELESS 100 C7 VOUT_S MID 1N E5 64 MID OUT MID 1 C13 VIMON MID 1N R33 63 VIMON R_NOISELESS 100 R10 MID 63 R_NOISELESS 1T R47 65 VCLP R_NOISELESS 100 C24 VCLP MID 100P E4 65 MID CL_CLAMP MID 1 C4 23 MID 1F R9 23 66 R_NOISELESS 1M R7 MID 67 R_NOISELESS 1T R6 68 MID R_NOISELESS 1T R8 MID 66 R_NOISELESS 1 XVCM_CLAMP 69 MID 66 MID 68 67 VCCS_EXT_LIM_0_LMP7721 E1 MID 0 70 0 1 R89 VEE_B 0 R_NOISELESS 1 R5 71 VEE_B R_NOISELESS 1M C3 71 0 1F R60 70 71 R_NOISELESS 1MEG C1 70 0 1 R3 70 0 R_NOISELESS 1T R59 72 70 R_NOISELESS 1MEG C2 72 0 1F R4 VCC_B 72 R_NOISELESS 1M R88 VCC_B 0 R_NOISELESS 1 G17 VEE_B 0 VEE 0 -1 G16 VCC_B 0 VCC 0 -1 R_PSR 73 69 R_NOISELESS 1K G_PSR 69 73 21 20 -1M R2 22 ESDn R_NOISELESS 1M R1 73 74 R_NOISELESS 1M R_CMR 75 74 R_NOISELESS 1K G_CMR 74 75 19 MID -1M C_CMn ESDn MID 1.5e-11 C_CMp MID ESDp 1.5e-11 R53 ESDn MID R_NOISELESS 1T R52 MID ESDp R_NOISELESS 1T R35 IN- ESDn R_NOISELESS 10M R34 IN+ ESDp R_NOISELESS 10M .MODEL S_VSWITCH_1 VSWITCH (RON=10e-3 ROFF=1e9 VON=10e-3 VOFF=0) .MODEL S_VSWITCH_3 VSWITCH (RON=1e-3 ROFF=1e9 VON=900e-3 VOFF=800e-3) .MODEL S_VSWITCH_4 VSWITCH (RON=50 ROFF=1e12 VON=500e-3 VOFF=450e-3) .ENDS LMP7721 * .SUBCKT ESD_0_LMP7721 ESDp ESDn VCC VEE SW6 ESDn ESDp ESDn ESDp S_VSWITCH_1 SW5 ESDp ESDn ESDp ESDn S_VSWITCH_1 SW4 ESDn VCC ESDn VCC S_VSWITCH_3 SW3 VEE ESDn VEE ESDn S_VSWITCH_3 SW2 ESDp VCC ESDp VCC S_VSWITCH_3 SW1 VEE ESDp VEE ESDp S_VSWITCH_3 .MODEL S_VSWITCH_1 VSWITCH (RON=50 ROFF=1e12 VON=700e-3 VOFF=650e-3) .MODEL S_VSWITCH_3 VSWITCH (RON=50 ROFF=1e12 VON=500e-3 VOFF=450e-3) .ENDS * .subckt VOS_DRIFT_LMP7721 VOS+ VOS- .param DC = -0.00024694 .param POL = -1 .param DRIFT = 1.50E-06 E1 VOS+ VOS- VALUE={DC+POL*DRIFT*(TEMP-27)} .ENDS * .SUBCKT PSRR_CMRR_0_LMP7721 psrr_in psrr_vccb mid .model R_NOISELESS RES ( TCE=0 T_ABS=-273.15) R74 mid psrr_in R_NOISELESS 1 G_2 psrr_in mid 4 mid -26.6667 R2b mid 4 R_NOISELESS 3896103.8961 C2a 4 5 1.061e-13 R73 5 4 R_NOISELESS 100MEG R49 mid 5 R_NOISELESS 1 GVCCS7 5 mid 6 mid -1 R2a mid 6 R_NOISELESS 31578947.3684 C1a 6 7 2.6526e-13 R48 7 6 R_NOISELESS 100MEG G_1 7 mid psrr_vccb mid -0.0001145 Rsrc mid 7 R_NOISELESS 1 .ENDS * .SUBCKT PSRR_CMRR_1_LMP7721 psrr_in psrr_vccb mid .model R_NOISELESS RES ( TCE=0 T_ABS=-273.15) R74 mid psrr_in R_NOISELESS 1 G_2 psrr_in mid 4 mid -150 R2b mid 4 R_NOISELESS 671140.9396 C2a 4 5 1.5915e-15 R73 5 4 R_NOISELESS 100MEG R49 mid 5 R_NOISELESS 1 GVCCS7 5 mid 6 mid -1 R2a mid 6 R_NOISELESS 502512.5628 C1a 6 7 2.1221e-15 R48 7 6 R_NOISELESS 100MEG G_1 7 mid psrr_vccb mid -0.012943 Rsrc mid 7 R_NOISELESS 1 .ENDS * .SUBCKT PSRR_CMRR_2_LMP7721 psrr_in psrr_vccb mid .model R_NOISELESS RES ( TCE=0 T_ABS=-273.15) R74 mid psrr_in R_NOISELESS 1 G_2 psrr_in mid 4 mid -20 R2b mid 4 R_NOISELESS 5263157.8947 C2a 4 5 3.1831e-15 R73 5 4 R_NOISELESS 100MEG R49 mid 5 R_NOISELESS 1 GVCCS7 5 mid 6 mid -1 R2a mid 6 R_NOISELESS 100100.1001 C1a 6 7 1.5915e-12 R48 7 6 R_NOISELESS 100MEG G_1 7 mid psrr_vccb mid -0.044463 Rsrc mid 7 R_NOISELESS 1 .ENDS * .SUBCKT VCCS_LIM_2_0_LMP7721 VC+ VC- IOUT+ IOUT- .PARAM GAIN = 0.011375 .PARAM IPOS = 0.10266 .PARAM INEG = -0.12559 G1 IOUT+ IOUT- VALUE={LIMIT(GAIN*V(VC+,VC-),INEG,IPOS)} .ENDS * .SUBCKT VCCS_LIM_1_0_LMP7721 VC+ VC- IOUT+ IOUT- .PARAM GAIN = 1E-4 .PARAM IPOS = .5 .PARAM INEG = -.5 G1 IOUT+ IOUT- VALUE={LIMIT(GAIN*V(VC+,VC-),INEG,IPOS)} .ENDS * .SUBCKT AOL_ZO_0_LMP7721 AOL_INP AOL_INN CLAMP VSENSE CLAW_CLAMP CL_CLAMP ZO_CLEFT ZO_CRIGHT ZO_OUT MID .MODEL R_NOISELESS RES ( TCE=0 T_ABS=-273.15) C1_A0 CLAMP MID 9.532e-09 R4_A0 MID CLAMP R_NOISELESS 1MEG XVCCS_LIM_2_A0 4_A0 MID MID CLAMP VCCS_LIM_2_0_LMP7721 R3_A0 MID 4_A0 R_NOISELESS 1MEG XVCCS_LIM_1_A0 AOL_INP AOL_INN MID 4_A0 VCCS_LIM_1_0_LMP7721 R4_VS VSENSE MID R_NOISELESS 1K GVCCS4_VS VSENSE MID CLAMP MID -1M C2_A2 out2 MID 2.532e-15 R3_A2 out2 MID R_NOISELESS 1MEG GVCCS3_A2 out2 MID VSENSE MID -1U C2_A3 out3 MID 2.8937e-15 R3_A3 out3 MID R_NOISELESS 1MEG GVCCS3_A3 out3 MID out2 MID -1U C2_A4 out4 MID 2.8937e-15 R3_A4 out4 MID R_NOISELESS 1MEG GVCCS3_A4 out4 MID out3 MID -1U R4_CC CLAW_CLAMP MID R_NOISELESS 1K GVCCS4_CC CLAW_CLAMP MID out4 MID -1M R4_CL CL_CLAMP MID R_NOISELESS 1K GVCCS4_CL CL_CLAMP MID CLAW_CLAMP MID -1M G_Aol_Zo Zo_Cleft MID CL_CLAMP ZO_OUT -89.047 GVCCS1_1 outz1 MID Zo_Cright MID -60.5303 C1_1 Zo_Cleft Zo_Cright 1.1821e-06 R2_1 Zo_Cright MID R_NOISELESS 167.9817 R1_1 Zo_Cright Zo_Cleft R_NOISELESS 10K Rdc_1 Zo_Cleft MID R_NOISELESS 1 GVCCS2_2 outz2 MID net2 MID -1 C2_2 5_2 MID 1.5347e-09 R5_2 net2 5_2 R_NOISELESS 10K R4_2 net2 outz1 R_NOISELESS 1083.3333 R7_2 outz1 MID R_NOISELESS 1 R1_3 2_3 MID R_NOISELESS 1 R11_3 5_3 MID R_NOISELESS 2.2803 C4_3 5_3 outz2 1.3263e-13 R10_3 5_3 outz2 R_NOISELESS 10K XVCVS_LIM_1 5_3 MID MID 2_3 VCCS_LIM_ZO_0_LMP7721 R9_3 outz2 MID R_NOISELESS 1 Rdummy MID ZO_OUT R_NOISELESS 10000 Rx ZO_OUT 2_3 R_NOISELESS 100000 .ENDS * .SUBCKT VCCS_LIM_ZO_0_LMP7721 VC+ VC- IOUT+ IOUT- .PARAM GAIN = 4386.4386 .PARAM IPOS = 9395.72e3 .PARAM INEG = -3994.66e3 G1 IOUT+ IOUT- VALUE={LIMIT(GAIN*V(VC+,VC-),INEG,IPOS)} .ENDS * .subckt FEMT_0_LMP7721 1 2 .param NVRF=10 .param RNVF={1.184*PWR(NVRF,2)} E1 3 0 5 0 10 R1 5 0 {RNVF} R2 5 0 {RNVF} G1 1 2 3 0 1e-6 .ends * .SUBCKT VNSE_0_LMP7721 1 2 .PARAM FLW=10 .PARAM NLF=40 .PARAM NVR=6.5 .PARAM GLF={PWR(FLW,0.25)*NLF/1164} .PARAM RNV={1.184*PWR(NVR,2)} .MODEL DVN D KF={PWR(FLW,0.5)/1E11} IS=1.0E-16 I1 0 7 10E-3 I2 0 8 10E-3 D1 7 0 DVN D2 8 0 DVN E1 3 6 7 8 {GLF} R1 3 0 1E9 R2 3 0 1E9 R3 3 6 1E9 E2 6 4 5 0 10 R4 5 0 {RNV} R5 5 0 {RNV} R6 3 4 1E9 R7 4 0 1E9 E3 1 2 3 4 1 .ENDS * .SUBCKT VCCS_LIMIT_IQ_0_LMP7721 VC+ VC- IOUT+ IOUT- .PARAM GAIN = 1E-3 G1 IOUT- IOUT+ VALUE={IF( (V(VC+,VC-)<=0),0,GAIN*V(VC+,VC-) )} .ENDS * .SUBCKT CLAMP_AMP_LO_0_LMP7721 VC+ VC- VIN COM VO+ VO- .PARAM G=1 GVO+ COM VO+ VALUE = {IF(V(VIN,COM)>V(VC+,COM),((V(VIN,COM)-V(VC+,COM))*G),0)} GVO- COM VO- VALUE = {IF(V(VIN,COM)<V(VC-,COM),((V(VC-,COM)-V(VIN,COM))*G),0)} .ENDS * .SUBCKT CLAMP_AMP_HI_0_LMP7721 VC+ VC- VIN COM VO+ VO- .PARAM G=10 GVO+ COM VO+ VALUE = {IF(V(VIN,COM)>V(VC+,COM),((V(VIN,COM)-V(VC+,COM))*G),0)} GVO- COM VO- VALUE = {IF(V(VIN,COM)<V(VC-,COM),((V(VC-,COM)-V(VIN,COM))*G),0)} .ENDS * .SUBCKT VCCS_LIM_GR_0_LMP7721 VC+ VC- IOUT+ IOUT- .PARAM GAIN = 1 .PARAM IPOS = 0.20532e1 .PARAM INEG = -0.20532e1 G1 IOUT+ IOUT- VALUE={LIMIT(GAIN*V(VC+,VC-),INEG,IPOS)} .ENDS * .SUBCKT VCCS_LIM_4_0_LMP7721 VC+ VC- IOUT+ IOUT- .PARAM GAIN = 1 .PARAM IPOS = 0.4494e1 .PARAM INEG = -0.336e1 G1 IOUT+ IOUT- VALUE={LIMIT(GAIN*V(VC+,VC-),INEG,IPOS)} .ENDS * .SUBCKT VCCS_LIM_CLAW+_0_LMP7721 VC+ VC- IOUT+ IOUT- G1 IOUT+ IOUT- TABLE {(V(VC+,VC-))} = +(0, 35E-6) +(3.59, 1.00E-04) +(11.4, 2.40E-04) +(27.42, 5.10E-04) +(33.3, 6.90E-04) +(37.78, 9.90E-04) +(43.21, 1.49E-03) +(46.06, 2.00E-03) +(46.5, 2.24E-03) +(46.98, 2.49E-03) .ENDS * .SUBCKT VCCS_LIM_CLAW-_0_LMP7721 VC+ VC- IOUT+ IOUT- G1 IOUT+ IOUT- TABLE {(V(VC+,VC-))} = +(0, 26.9E-6) +(13.7761, 0.00068134) +(16.1308, 0.000855) +(17.2481, 0.001011) +(18.0841, 0.00121) +(18.5977, 0.0015755) +(19.0569, 0.0019018) +(19.5161, 0.0022172) +(19.7514, 0.0023199) +(19.9733, 0.0025) .ENDS * .SUBCKT VCCS_LIM_3_0_LMP7721 VC+ VC- IOUT+ IOUT- .PARAM GAIN = 1 .PARAM IPOS = 0.2247e1 .PARAM INEG = -0.168e1 G1 IOUT+ IOUT- VALUE={LIMIT(GAIN*V(VC+,VC-),INEG,IPOS)} .ENDS * .SUBCKT OL_SENSE_0_LMP7721 COM SW+ OLN OLP GSW+ COM SW+ VALUE = {IF((V(OLN,COM)>10E-3 | V(OLP,COM)>10E-3),1,0)} .ENDS * .SUBCKT VCCS_EXT_LIM_0_LMP7721 VIN+ VIN- IOUT- IOUT+ VP+ VP- .PARAM GAIN = 1 G1 IOUT+ IOUT- VALUE={LIMIT(GAIN*V(VIN+,VIN-),V(VP-,VIN-), V(VP+,VIN-))} .ENDS *
Hi Jari,
LMP7721 TINA-TI Spice model should be compatible with PSpice model. You are able to download via the link below. We do not use HSPICE Model.
https://www.ti.com/product/LMP7721#design-development
Enclosed is the copy of LMP7721.LIB.
/cfs-file/__key/communityserver-discussions-components-files/14/LMP7721.LIB
If you have additional questions, please let us know.
Raymond
Running this model with afs (HSPICE compatible simulator) gives below SIM_ERRORs:
* Version: AFS 64-bit (2017.3 : 2017-09-19) *
* Build date: Tue Sep 19 07:53:13 PDT 2017 *
***** Command-Line Options
afs -i PCM_sim.afs -f fsdb
'parhier=global'. Global parameter assignments will take precedence over local assignments
SIM_ERROR[HIN273]: /home/jari/project2/LMP7721.txt:222: Incomplete controlled source specification.
SIM_ERROR[HIN273]: /home/jari/project2/LMP7721.txt:222: Unable to resolve e1.
SIM_ERROR[HIN273]: /home/jari/project2/LMP7721.txt:85: Unable to resolve xv_os.
SIM_ERROR[HIN273]: /home/jari/project2/DSUDS150_REV2/PCM/PCM_current_amp/eldonet/PCM_current_amp_eldonet.spi:20: Unable to resolve x_lmp7721.
So this would mean that this model is not 100% hspice compatible.
I'm just guessing that having hspice model would be the best options.
Jari
Do you know if I can make the afs (hspice compatible simulator) pspice compatible somehow?
Jari
Hi Jari,
I know this doesn't answer your question, but why not using TINA-TI, at least for the simulation of the part of the circuit with the LMP7721? I'm also doing so. The most parts I simulate with TINA-TI, some other with LTSpice.
Divide and conquer :-)
Kai
Hi Jari,
There is Netlist Export function in Tina for PSpice with *.CIR extension. That is a way to send out PSpice compatible file. If you'd like, we can try that.
I agreed with Kai's comments. I just imported the LMP7721.LIB into LTSpice, it seems working as well.
If you need additional assistant, please let us know.
Raymond
Hi
Sorry, for the delay. The E2E server is upgrading while I attempted to reply to your inquiry in the late afternoon last Friday.
LMP7721.CIR file (Netlist file) is only compatible with pspice simulation tools; I am not sure that it will be compatible with hspice simulation.
* END MODEL LMP7718
* BEGIN MODEL LMP7721
* Rev.A March-2008
* (C) National Semiconductor, Corporation.
* Models developed and under copyright by:
* National Semiconductor, Corporation.
* Legal Notice:
* The model may be copied, and distributed without any modifications;
* however, reselling or licensing the material is illegal.
* We reserve the right to make changes to the model without prior notice.
* PSPICE Models are provided "AS IS, WITH NO WARRANTY OF ANY KIND"
* MODEL FEATURES INCLUDE OUTPUT SWING, OUTPUT CURRENT THRU THE SUPPLY RAILS, * OUTPUT CURRENT LIMIT, OPEN LOOP GAIN AND PHASE WITH RL AND CL EFFECTS, SLEW * RATE, COMMON MODE REJECTION WITH FREQ EFFECTS, POWER SUPPLY REJECTION WITH
* FREQ EFFECTS, INPUT VOLTAGE NOISE WITH 1/F, INPUT CURRENT NOISE, INPUT BIAS * CURRENT, INPUT BIAS CURRENT TEMPERATURE EFFECTS, INPUT COMMON MODE RANGE, * INPUT OFFSET VOLTAGE WITH TEMPERATURE EFFECTS, AND QUIESCENT CURRENT VS
* VOLTAGE AND TEMPERATURE.
* MODEL TEMP RANGE IS -40 TO +125 DEG C. NOTE THAT MODEL IS FUNCTIONAL OVER THIS * RANGE BUT NOT ALL PARAMETERS TRACK THOSE OF THE REAL PART
* PINOUT ORDER +IN -IN +V -V OUT
* PINOUT ORDER 3 4 5 2 1
.SUBCKT LMP7721 3 4 5 2 1
* USE V44 BELOW TO ADJUST OFFSET
* PRESENT VALUE OF 248.7 UV GIVES 26 UV NET
* NOTE THAT VOS CHANGES VIA CMRR,PSRR, AND TCVOS
* ADJUST UP OR DN FROM 248.7 UV
V44 26 11 248.7E-6
* USE R325 BELOW TO ADJUST BIAS CURRENT
* PRESENT VALUE OF 1E7 GIVES TYPICAL IB
* USE 1E8 FOR WORST CASE IB
R325 0 100 1E7
* NOTE
* USE ANALYSIS OPTION GMIN OF 1E-13 TO 1E-15 AND
* RELTOL = 0.00001 TO 0.000001 FOR ACCURATE INPUT
* BIAS CURRENT
* THE SUPPLY RAILS, OUTPUT CURRENT LIMIT, OPEN LOOP GAIN
* AND PHASE WITH RL AND CL EFFECTS, SLEW RATE, COMMON MODE
* REJECTION WITH FREQ EFFECTS, POWER SUPPLY REJECTION WITH
* NOISE, INPUT BIAS CURRENT, INPUT BIAS CURRENT TEMPERATURE
* EFFECTS, INPUT COMMON MODE RANGE, INPUT OFFSET VOLTAGE
* WITH TEMPERATURE EFFECTS, AND QUIESCENT CURRENT VS
D17 6 0 DIN
D18 7 0 DIN
I14 0 6 0.1E-3
I15 0 7 0.1E-3
D19 8 0 DVN
D20 9 0 DVN
I16 0 8 0.1E-3
I17 0 9 0.1E-3
E15 10 4 8 9 0.7
G5 11 10 6 7 1.1E-14
E16 12 0 13 0 1
E17 14 0 15 0 1
E18 16 0 17 0 1
R56 12 18 1E6
R57 14 19 1E6
R58 16 20 1E6
R59 0 18 10
R60 0 19 10
R61 0 20 10
E19 21 22 20 0 1.4
R62 23 17 1E3
R63 17 24 1E3
C15 12 18 1E-12
C16 14 19 1E-12
C17 16 20 10E-12
E20 25 21 19 0 -6
E21 26 25 18 0 6
R64 0 27 1E12
G12 11 10 28 0 1.1E-6
R136 0 28 10E3
R137 0 28 10E3
R138 22 21 1E9
R139 21 25 1E9
R140 25 26 1E9
E54 24 0 11 0 1
E55 23 0 10 0 1
C23 11 10 0.05E-12
E57 22 3 29 0 8.45E-4
R146 22 3 1E9
R147 0 27 1E12
Q41 30 31 15 QLN
R148 31 32 1E3
R149 33 34 1E3
R150 35 13 5
R151 15 36 5
R153 37 38 200
R154 39 13 5
R155 15 40 5
D22 41 5 DD
D23 2 41 DD
E58 15 0 2 0 1
E59 13 0 5 0 1
R156 2 5 10E6
E67 42 15 13 15 0.5
D24 43 13 DD
D25 15 44 DD
R157 45 46 100
R158 47 48 100
G14 37 42 49 42 0.1E-3
R159 42 37 3.3E7
C24 38 50 5.25E-12
C25 41 0 0.5E-12
D26 48 30 DD
D27 51 46 DD
Q42 51 34 13 QLP
R160 41 52 1
R161 53 41 1
E61 54 42 55 56 1
R162 54 49 1E4
C26 49 42 0.3E-12
G15 57 42 37 42 -1E-3
G16 42 58 37 42 1E-3
G17 42 59 60 15 1E-3
G18 61 42 13 62 1E-3
D28 61 57 DD
D29 58 59 DD
R163 57 61 100E6
R164 59 58 100E6
R165 61 13 1E3
R166 15 59 1E3
R167 58 42 1E6
R168 59 42 1E6
R169 42 61 1E6
R170 42 57 1E6
G19 5 2 63 0 0.95E-3
R171 42 49 1E9
R172 45 13 1E9
R173 15 47 1E9
G20 62 60 27 0 0.1E-3
L2 41 1 0.4E-9
R175 41 1 400
R176 62 13 1E8
R177 15 60 1E8
R178 36 48 1E8
R179 35 46 1E8
R180 0 27 1E9
E99 13 33 13 35 1.9
E100 32 15 36 15 6.5
E124 50 0 41 0 1
R219 37 50 3.3E9
I30 0 64 1E-3
D46 64 0 DD
R278 0 64 10E6
V27 64 29 0.65
R279 0 29 10E6
Q52 52 46 35 QOP
Q53 53 48 36 QON
Q54 60 60 40 QON
Q55 62 62 39 QOP
E144 13 45 13 61 1
E145 47 15 59 15 1
I33 0 65 1E-3
D49 65 0 DD
R287 0 65 10E6
V130 65 66 1.2301
R288 0 66 10E6
E50 67 0 66 0 -1.75
R289 0 67 10E6
R290 68 67 10E6
M3 68 69 0 0 NEN L=2U W=1000U
G22 70 71 68 0 3E-6
V32 72 0 1
R791 72 69 1E6
M4 69 27 0 0 NEN L=2U W=100U
E51 37 44 42 15 0.7
E52 43 37 13 42 0.7
G23 5 0 52 41 1
G24 2 0 41 53 -1
V35 13 73 1
M45 74 75 76 76 NEN L=3U W=3000U
R293 76 77 1E4
R294 74 13 1E6
V36 13 76 1
C110 13 73 1E-12
E53 27 0 78 76 1
V37 74 78 1.111E-6
R295 76 78 1E12
R296 73 13 1E6
C111 77 76 3E-15
C112 13 74 3E-15
M20 79 80 76 76 NEN L=3U W=300U
M21 75 79 76 76 NEN L=3U W=300U
R297 79 13 1E4
R298 75 13 1E4
C113 13 79 55E-12
C114 13 75 150E-12
E154 81 37 27 0 30
E155 82 42 27 0 -30
V138 83 82 15
V139 84 81 -15
R300 81 0 1E12
R301 82 0 1E12
M12 42 84 37 85 PSW L=1.5U W=150U
M13 37 83 42 86 NSW L=1.5U W=150U
R302 85 0 1E12
R303 86 0 1E12
M14 77 73 13 13 PEN L=6U W=60U
E156 87 76 77 76 -1
R304 76 87 10E6
R305 76 87 10E6
V40 80 87 1
R306 76 80 10E6
M55 88 89 2 2 NEN L=2U W=1000U
R809 88 5 100E3
E37 89 2 27 0 3
M56 63 90 0 0 NEN L=2U W=10M
R811 63 67 850E3
E60 91 0 27 0 -1
R312 0 91 10E6
R313 0 91 10E6
V43 90 91 1
R814 0 90 10E6
G25 5 2 27 0 -0.33E-3
G26 5 2 92 0 0.7E-4
E161 93 0 5 2 1
M57 92 90 0 0 NEN L=2U W=10M
R815 92 93 75E3
R317 4 10 1E9
R319 94 56 2E3
R320 94 55 2E3
C47 56 55 1.2E-12
M58 56 95 96 96 PIN L=3U W=650U
M59 55 97 98 98 PIN L=3U W=650U
Q58 99 70 71 QPI
R321 11 95 40
R322 10 97 40
R323 96 99 1
R324 98 99 1
V145 13 71 0.2
V46 94 15 0
D50 100 101 DL
V47 101 0 3
G51 10 0 100 0 1.6E-11
I61 10 0 1E-15
G52 11 0 100 0 1.6E-11
I62 11 0 1E-15
J1 102 95 102 JC
J2 95 103 95 JC
J3 102 97 102 JC
J4 97 103 97 JC
V48 13 102 0.48
V49 103 15 0.15
G53 104 3 104 3 2.5E-13
G54 104 4 104 4 2.5E-13
V146 104 15 1
.MODEL DL D IS=0.95E-11 N=1.9 XTI=1.5
.MODEL JC NJF IS=1E-18
.MODEL QPI PNP
.MODEL QON NPN RC=5
.MODEL QOP PNP RC=5
.MODEL DD D
.MODEL DVN D KF=2.5E-15
.MODEL DIN D KF=8E-17
.MODEL QLN NPN
.MODEL QLP PNP
.MODEL PIN PMOS KP=200U VTO=-0.7
.MODEL NIQS NMOS KP=200U VTO=0.7 IS=1E-18
.MODEL NEN NMOS KP=200U VTO=0.5 IS=1E-18
.MODEL PEN PMOS KP=200U VTO=-0.7 IS=1E-18
.MODEL PSW PMOS KP=200U VTO=-7.5 IS=1E-18
.MODEL NSW NMOS KP=200U VTO=7.5 IS=1E-18
.ENDS
https://www.youtube.com/watch?v=QE7jUcWWi5M
If you have additional questions. please let us know.
Raymond
But it looks I have only the afs (hspice compatible) for this job.
The last model you provided seemed to simulate:
******** SIMULATION finished with 0 error(s) and 49 warning(s) ********
I'm not sure though if the results will be correct, but it gives now results.
It looks like it is oscillating in the noisetran simulation, while in transient simulation without noise, the curve is stable.
In the simulation file it is hard to find the OPTION for transient timestep that work with noistran simulation:
* Component: $DSUDS150_REV2/PCM/PCM_sim Viewpoint: eldonet
*.INCLUDE /home/jari/project2/ADA4530.cir
*.INCLUDE /home/jari/project2/LMP7721.txt
*.INCLUDE ./PCM_sim.ic00
.INCLUDE ./PCM_current_amp_eldonet.spi
.CONNECT VEE 0
.OPTION GMIN = 1E-21
*.OPTION voltageltefactor=0.25
*.OPTION MINSTEP = 1e-14
*.OPTION LTECHECK = 0
*.OPTION AFSMODE = GOLD
.OPTION ERRPRESET = 3
.OPTION ITL4 = 500
.OPTION METHOD = GEAR
.OPTION LTEMETHOD = 2
*.PARAM VDC=1
* --- Singles
.PROBE I(*)
.PROBE V(*)
* - Analysis Setup - DC
*.DC
* - Analysis Setup - Trans
.TRAN 0.1n 20m
*.TRAN 0.1n 10 noisefmin=1k noisefmax=100Meg noiseseed=nbrun sweep nbrun start=1 stop=1 step=1
*.SAVE file=PCM_sim.ic0 type=nodeset
* --- Params
.TEMP 27
It looks difficult to attach the waveform image here (that is png file).
Hi Jari,
The E2E editing tool is changed two days ago, but I think that certain things are made easier. Since the tool is new, there may be some learning curve because of the new menu system.
To insert an image file, you may cut (e.g. snipping tool) and paste an image directly into the inquiry text. You may also use Insert command below and click image/video/file tab to upload a file.
Can you send us the schematic that you are working with and see if we are able to simulate via Tina first? I do not work with hspice tool, so we may not be able to reply certain issues that you encountered with the tool.
Raymond
Hi Jari,
There may be some restrictions in uploading certain file extensions for security reasons. I am not sure the reasons behind these protections, since the tool is new to us as well.
Please use snipping tool, cut and paste the image file in the text.
Raymond
I'll check... This looks working well with paste.
TRAN simulation result:
NoiseTRAN simulation result:
And a lot of case where the noisetran stops with wrong or too small timestep error.
The issue that TRAN & NOISETRAN results are quite much different, could point for some error here (maybe timestep related, etc).
Jari
Hi Jari,
Could you share the LMP7721 schematic with me? You can draw by hand and cut and paste into the inquiry. If you want to keep private, please send me a "friendship" request via E2E and we are able to share the ideas via E2E private messaging, which it will not be view over public forum.
I am going ask our model engineer to take a look at your hspice errors. I am not sure that if he is familiar with the hspice tool either. If he is unable, then you may have to find alternative way to simulate your circuit.
Raymond
The schematics as above is quite simple, I guess this could be published here openly.
Main issues is NOISETRAN-case where it fails to operate, or maybe is it possible that it really would oscillate that case?
But that could be modeling failure that affects noise simulations in the spice model...
The used capacitor values may have been different than here in the earlier simulation cases.
Hi Jari,
LMP7721's supply voltage, Vs (V+ - V-) is rated up to 5.5Vdc. Enclosed is an example of TIA circuit from 1nA to 100nA, since I am not clear that the photodiode's parameters are. If you are able to provide us the TIA's application requirements, I can help you to simulate one via Tina.
Our pspice model engineer is not familiar enough in supporting hspice issues. Enclosed is the link of Tina-TI simulation tool in our website and it can be downloaded for free.
https://www.ti.com/tool/TINA-TI#downloads
Raymond
Ok. I might check if I get it working with the Tina.
However the system has dual boot for Windows10 + Linux dualboot and mainly I'm operating with LinuxMint20.1
I simulated it with 5.5V supply (hspice) now result is as below:
So still in hspice case the transient noise has strange oscillating and different voltage results.
I would rather use the hspice, because it works here in linux mode.
Does the TINA have transient noise option?
Alse diode model is for hspice, and it can not be translated to the Tina:
So the diode would be missing in the simulation if I use Tina.
As shown below, the different model blocks should be combined into same simulation:
Hi Jari,
I am enclosing two TIA application notes in how to calculate relevant TIA design parameters.
I can assist you to simulate a TIA circuit, if you are able to provide me with photodiode equivalent pspice model or actual photodiode part number, which it should have the following parameters (minimum) in junction capacitance, shunt resistance and nominal current (that is proportional to the incident light, or min. and max. of incident light current).
Raymond
This photodiode is not commercial photodiode part and has no part number.
It has only HSPICE -model. I should combine the hspice photodiode part and Tina/pspice LMP7721 in the same simulation.
The hspice diode model is something like below, but I can not give all the parameter values here:
* Nwell/Psub Field Edged Junction Diode
.model nwdio d
+ level = 3.0000e+00 shrink = 1.0000e+00 tlev = 0.0000e+00
+ bv = ibv =
+ tlevc = 0.0000e+00 cj = mj =
+ pb = 1.0000e+00 cjsw = mjsw =
+ php = 4.0000e-01 js = jsw =
+ n = rs = area =
+ pj = trs = tref =
Hi Jari,
The photodiode's current is a function of incident light. The diode model may not reflect the current response vs. light intensity, even you provide me with the entire diode model parameters.
I think that it will be the best to work with the Tina or similar simulation tool to work on the project. We have series of training videos in Tina to cut down your learning curve.
Please let me know if you need additional assistant.
Raymond
I should know how to get the diode model prepared for TINA or LMP7721 model prepared for hspice.
The light condition is not problem here, as this is for dark condition leakage measurement.
If I transfer the diode model to TINA, the results show Out = 0.000 V !
So I guess this still does not work properly... But why?
And there could not be found transient noise analysis (TNA) in TINA-simulator:
DC analysis case the output shows voltage of about 1.76V, but that seems wrong also and like if the diode current flowing from anode to cathode rather than c to a.
Hi Jari,
Enclosed is a simulation with photodiode current from 1pA to 1nA. The transfer function Vout = Rf * IG1, where 1pA <= IG1 <= 1nA.
With single supply rail and DC bias of 2.2V, Vout = 2.2V + Rf*IG1 = 2.2V + 1x10^9*1nA = 3.20V at IG1=1nA.
Here is the simulation.
Please modify the simulation for your photodiode sensor. Once you are getting the correct response, we can check the TIA stability.
BTW, what your sensor's BW required for the TIA application. The dominated pole in the above TIA circuit is reduced at approx. 159Hz currently.
Raymond
Can you recheck the simulation with feedback resistor value of 1T (not 1G)?
The measurement range would be 1f-1000f (about x1000 times smaller current that what you used).
It looks also temperature sweep case the result shows zero.
It could be also that the diode model for the nwdio is not 100% compatible here...
The current of R4 in below image is 'negative'.. this is strange.
Maybe this opamp could not handle such small current or what can be causing this?
Simulator accuracy settings wrong?
The below circuit seems to be going right:
I think this case is correct, the V(Out1)=4V is correct.
However if resistor value 1T is used the results does not seem to be what is requeseted:
This case of course if the opamp has low leakage the V(Out1) would be 4V as well.
But I could not find what actually is causing this...
Hi Jari,
Q: Maybe this opamp could not handle such small current or what can be causing this? The measurement range would be 1f-1000f (about x1000 times smaller current that what you used).
LMP7721 is unable to meet your 1fA-1pA TIA design requirements. LMP7721 is also the best fA amplifier we have, and we do not have lower Ibias op amp part.
The use of 1 TΩ Feedback resistor will not be feasible in TIA application. If you need to higher gain output, you have to use multiple stages to gain up the I-to-V conversion. Without knowing your application, I placed 1GΩ Feedback in the TIA circuit, which the gain is already high enough (You may modify the working circuit to increase the gains). You also have to consider op amp stability, BW and taken into account other environmental consideration. It is possible that your environmental noises are already exceeded 1fA under regular lab environmental conditions.
You may have a chance to use LMP7721 for 1pA or may be slightly lower in IV conversion. If you are able to lower operating temperature in LMP7721 and purge with low dew point gas (e.g. N2), you may be able to stabilize the Ibias current and improve the sensitivity of the part. However, it is going to be difficult to detect 1 fA of current because of the level, which is already exceeded the part's specification.
BTW, Digikey does sell 500GΩ resistor from Ohmite ($5.737/each). However, if you use the type of resistor, the BW of TIA will be very low, down to Hz or subHz range. However, the issues are that 1fA current range is lower than the LMP7721 can handle. If you still want to use LMP7721, I can put together a simulation, but I need to know your BW requirements.
LMP7721 up to 10pA E2E 03232021.TSC
I simulated the TIA from 1fA to 10pA for you with 100GΩ feedback resistor, but it does not mean that the simulation will work in the real part (maybe not in the 1-50fA range).. In fact, I already see some model issues with Vbias voltage from the plotted data. The BW is configured approx. 5Hz currently.
If you have other questions, please let us know.
Raymond.
If you find better circuit or better opamp for this 1fA application, let me know your idea.
Maybe it is available somewhere.
It looks the opamp then might be good (with low leakage input), but just it can not run in the TINA if I put 1T feedback resistors.
Hi Jari,
Ok, there are a lot of research in attoA application. Maybe these are existed in discrete design. Currently, we do not have this type of precision op amp. Have you checked with our competitors?
Can you send "friendship" request via E2E private message?
Raymond
Hi Jari,
even if the LM7721 shows an input bias current of +/-3nA, it can nevertheless be used in your circuit.
Can you tell more about your specimen you want to measure?
Kai
