We are using the AMC1200 to measure the AC input supply voltage. We are able to detect the Peak voltage from the opamp output voltage wave, Here the question is which give the relationship between the ac input voltage and opamp voltage(AMC1200).
Hi Vikram,
If you are asking about the gain of the AMC1200, it is fixed at 8. This should be mentioned in the datasheet. Vout would be Vin * 8 centered on output common mode voltage which is dependent on VDD2.
