Other Parts Discussed in Thread: PCF8575, PMP, TVP5158
Tool/software: Linux
\0x00
U-Boot SPL 2016.05-00011-ge4824e9 (Jul 19 2018 - 19:33:06)
ti_i2c_eeprom_init failed 1
no pinctrl for hs200_1_8v
no\0xb0pinctrl for ddr_1_8v
** First descriptor is NOT a primary desc on 1:1 **
i2c_write: error waiting for data ACK (status=0x116)
Trying to boot from MMC1
reading dra7-ipu2-fw.lzop
reading dra7-dsp1-fw.lzop
reading dra7-dsp2-fw.lzop
spl_load_file_fat: error reading file dra7-dsp2-fw.lzop, err - -1
spl: error reading image dra7-dsp2-fw.lzop, err - -1
Error loading remotecore DSP2!,Continuing with boot ...
reading dra7-ipu1-fw.lzop
spl_load_file_fat: error reading file dra7-ipu1-fw.lzop, err - -1
spl: error reading image dra7-ipu1-fw.lzop, err - -1
Error loading remotecore IPU1!,Continuing with boot ...
reading u-boot.img
reading u-boot.img
reading u-boot.img
reading u-boot.img
U-Boot 2016.05-00011-ge4824e9 (Jul 19 2018 - 19:33:06 +0800)
CPU : DRA722-GP ES1.0
Model: TI DRA722
Board: DRA72x EVM REV
DRAM: 1 GiB
[lin]gpio_request 921_RST failed
MMC: i2c_write: error waiting for data ACK (status=0x116)
pcf8575_i2c_write_le16 i2c write failed to addr 21
OMAP SD/MMC: 0, OMAP SD/MMC: 1
Warning: fastboot.board_rev: unknown board revision
GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
part_get_info_efi: *** ERROR: Invalid GPT ***
part_get_info_efi: *** ERROR: Invalid Backup GPT ***
ERROR: cannot find partition: 'userdata'
at arch/arm/cpu/armv7/omap-common/utils.c:199/mmc_get_part_size()
Warning: fastboot.userdata_size: unable to calc
SCSI: SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
scanning bus for devices...
Found 0 device(s).
Net: <ethaddr> not set. Validating first E-fuse MAC
Could not get PHY for cpsw: addr 3
cpsw
Hit any key to stop autoboot: 2 \0x08\0x08\0x08 1 \0x08\0x08\0x08 0
switch to partitions #0, OK
mmc1(part 0) is current device
SD/MMC found on device 1
** Unrecognized filesystem type **
3548768 bytes read in 167 ms (20.3 MiB/s)
102219 bytes read in 37 ms (2.6 MiB/s)
Booting from mmc1 ...
Kernel image @ 0x82000000 [ 0x000000 - 0x362660 ]
Loading Device Tree to 8ffe4000, end 8fffff4a ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.84-00027-g018eb62-dirty (fredy@Latitude-5289) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #3 SMP PREEMPT Thu Jul 19 19:34:01 CST 2018
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine model: TI DRA722
[ 0.000000] Reserved memory: created CMA memory pool at 0x95800000, size 56 MiB
[ 0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x99000000, size 64 MiB
[ 0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x9d000000, size 32 MiB
[ 0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 24 MiB at 0xbe000000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] OMAP4: Map 0xbfe00000 to fe600000 for dram barrier
[ 0.000000] DRA722 ES1.0
[ 0.000000] PERCPU: Embedded 11 pages/cpu @ef64a000 s14912 r8192 d21952 u45056
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 258624
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=PARTUUID=29f7a82e-02 rw rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 840396K/1041408K available (6643K kernel code, 317K rwdata, 2384K rodata, 336K init, 286K bss, 20788K reserved, 180224K cma-reserved, 234496K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc08d900c (9029 kB)
[ 0.000000] .init : 0xc08da000 - 0xc092e000 ( 336 kB)
[ 0.000000] .data : 0xc092e000 - 0xc097d560 ( 318 kB)
[ 0.000000] .bss : 0xc097f000 - 0xc09c6980 ( 287 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] \0x09Build-time adjustment of leaf fanout to 32.
[ 0.000000] \0x09RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] ti_dt_clocks_register: failed to lookup clock node gmac_gmii_ref_clk_div
[ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
[ 0.000000] Architected cp15 timer(s) running at 6.14MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000004] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[ 0.000015] Switching to timer-based delay loop, resolution 162ns
[ 0.000333] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000341] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000777] Console: colour dummy device 80x30
[ 0.000793] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.000799] This ensures that you still see kernel messages. Please
[ 0.000804] update your kernel commandline.
[ 0.000817] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[ 0.000829] pid_max: default: 32768 minimum: 301
[ 0.000928] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000939] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001490] Initializing cgroup subsys io
[ 0.001507] Initializing cgroup subsys memory
[ 0.001530] Initializing cgroup subsys devices
[ 0.001543] Initializing cgroup subsys freezer
[ 0.001553] Initializing cgroup subsys perf_event
[ 0.001564] Initializing cgroup subsys pids
[ 0.001589] CPU: Testing write buffer coherency: ok
[ 0.001796] /cpus/cpu@0 missing clock-frequency property
[ 0.001808] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001851] Setting up static identity map for 0x80008340 - 0x800083a0
[ 0.050010] Brought up 1 CPUs
[ 0.050021] SMP: Total of 1 processors activated (12.29 BogoMIPS).
[ 0.050028] CPU: All CPU(s) started in HYP mode.
[ 0.050034] CPU: Virtualization extensions available.
[ 0.051001] devtmpfs: initialized
[ 0.080021] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.081038] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.261120] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.261144] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.273594] pinctrl core: initialized pinctrl subsystem
[ 0.274496] NET: Registered protocol family 16
[ 0.275409] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.300167] cpuidle: using governor ladder
[ 0.330191] cpuidle: using governor menu
[ 0.339263] OMAP GPIO hardware version 0.1
[ 0.343467] GPIO line 161 (radio_rst) hogged as output/low
[ 0.345877] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
[ 0.372278] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.372290] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.372798] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.372808] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.373313] OMAP DMA hardware revision 0.0
[ 0.451171] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[ 0.452399] edma 43300000.edma: memcpy is disabled
[ 0.457094] edma 43300000.edma: TI EDMA DMA engine driver
[ 0.461709] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 0.461888] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 0.462053] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.462217] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.480910] pcf857x: probe of 0-0020 failed with error -121
[ 0.481196] pcf857x: probe of 0-0021 failed with error -121
[ 0.481558] palmas 0-0058: Irq flag is 0x00000000
[ 0.483462] palmas 0-0058: Muxing GPIO 51, PWM 0, LED 2
[ 0.531883] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.551009] pcf857x: probe of 3-0021 failed with error -121
[ 0.551049] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz
[ 0.571029] pcf857x: probe of 4-0026 failed with error -121
[ 0.571355] pca953x 4-0020: failed reading register
[ 0.571372] pca953x: probe of 4-0020 failed with error -121
[ 0.571977] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
[ 0.572208] media: Linux media interface: v0.10
[ 0.572262] Linux video capture interface: v2.00
[ 0.572303] pps_core: LinuxPPS API ver. 1 registered
[ 0.572311] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.572335] PTP clock support registered
[ 0.572384] EDAC MC: Ver: 3.0.0
[ 0.581557] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 0.581751] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 0.582114] Advanced Linux Sound Architecture Driver Initialized.
[ 0.582943] clocksource: Switched to clocksource arch_sys_counter
[ 0.593083] NET: Registered protocol family 2
[ 0.593597] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.593661] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.593786] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.593838] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.593868] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.594076] NET: Registered protocol family 1
[ 0.604369] RPC: Registered named UNIX socket transport module.
[ 0.604377] RPC: Registered udp transport module.
[ 0.604384] RPC: Registered tcp transport module.
[ 0.604390] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.605426] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.624647] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.635288] NFS: Registering the id_resolver key type
[ 0.635320] Key type id_resolver registered
[ 0.635328] Key type id_legacy registered
[ 0.635386] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.636901] bounce: pool size: 64 pages
[ 0.637046] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.637062] io scheduler noop registered
[ 0.637075] io scheduler deadline registered
[ 0.637107] io scheduler cfq registered (default)
[ 0.639397] evm_5v0: supplied by evm_12v0
[ 0.639456] ldo4: supplied by evm_5v0
[ 0.642492] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[ 0.642614] pinctrl-single 4a002e8c.pinmux: 1 pins at pa fc002e8c size 4
[ 0.645983] PCI host bridge /ocp/axi@0/pcie_rc@51000000 ranges:
[ 0.645996] No bus range found for /ocp/axi@0/pcie_rc@51000000, using [bus 00-ff]
[ 0.646030] IO 0x20003000..0x20012fff -> 0x00000000
[ 0.646050] MEM 0x20013000..0x2fffffff -> 0x20013000
[ 0.675756] dra7-pcie 51000000.pcie_rc: link is not up
[ 0.675924] dra7-pcie 51000000.pcie_rc: PCI host bridge to bus 0000:00
[ 0.675937] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.675948] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.675958] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[ 0.676368] PCI: bus0: Fast back to back transfers disabled
[ 0.676491] PCI: bus1: Fast back to back transfers enabled
[ 0.676580] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
[ 0.676595] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
[ 0.676608] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.676833] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 0.733327] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.736669] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 301, base_baud = 3000000) is a 8250
[ 1.696587] console [ttyS0] enabled
[ 1.700992] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 302, base_baud = 3000000) is a 8250
[ 1.711086] [drm] Initialized drm 1.1.0 20060810
[ 1.717664] vsys_3v3: supplied by evm_12v0
[ 1.721817] ldo5: supplied by vsys_3v3
[ 1.726164] OMAP DSS rev 6.1
[ 1.729925] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[ 1.738436] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops)
[ 1.747360] connector-hdmi connector: failed to find video source
[ 1.839844] loop: module loaded
[ 1.843514] vmemexp device MAJOR num = 245
[ 1.847640] vmemexp class registered
[ 1.851341] /dev/vmemexp device registered
[ 1.855472] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120
[ 1.862996] libphy: Fixed MDIO Bus: probed
[ 1.868789] cpsw 48484000.ethernet: gpio request failed, ret -517
[ 1.876052] mousedev: PS/2 mouse device common for all mice
[ 1.892447] i2c /dev entries driver
[ 1.896538] tvp5158 4-0058: Unable to of_probe
[ 1.901293] ov490 4-0024: Failed reading register 0x300a!
[ 1.906766] ov490: probe of 4-0024 failed with error -121
[ 1.912924] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
[ 1.920024] vip 48970000.vip: loading firmware vpdma-1b8.bin
[ 1.930555] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 1.935415] vpe 489d0000.vpe: Device registered as /dev/video0
[ 1.942213] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 1.948674] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 1.955231] evm_3v3: supplied by vsys_3v3
[ 1.962983] vip 48970000.vip: VPDMA firmware loaded
[ 1.993427] omap_hsmmc 480d1000.mmc: no pinctrl state for sdr25 mode
[ 2.000871] omap_hsmmc 480d1000.mmc: no pinctrl state for sdr12 mode
[ 2.009306] omap_hsmmc 480d1000.mmc: no pinctrl state for hs mode
[ 2.046486] mmc0: MAN_BKOPS_EN bit is not set
[ 2.053800] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.353933] clock: dpll_abe_ck failed transition to 'locked'
[ 4.657727] clock: dpll_abe_ck failed transition to 'locked'
[ 4.666000] ------------[ cut here ]------------
[ 4.670644] WARNING: CPU: 0 PID: 1 at drivers/clk/clk.c:680 clk_core_disable+0x68/0x6c()
[ 4.678766] Modules linked in:
[ 4.681842] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.4.84-00027-g018eb62-dirty #3
[ 4.689616] Hardware name: Generic DRA72X (Flattened Device Tree)
[ 4.695732] Backtrace:
[ 4.698208] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
[ 4.705807] r7:c050f9b0 r6:20000093 r5:00000000 r4:c094d590
[ 4.711528] [<c0013d00>] (show_stack) from [<c02b39a8>] (dump_stack+0x8c/0xa0)
[ 4.718784] [<c02b391c>] (dump_stack) from [<c003581c>] (warn_slowpath_common+0x88/0xb8)
[ 4.726906] r7:c050f9b0 r6:000002a8 r5:00000009 r4:00000000
[ 4.732621] [<c0035794>] (warn_slowpath_common) from [<c00358f0>] (warn_slowpath_null+0x24/0x2c)
[ 4.741440] r8:00000004 r7:c093bc58 r6:c093f108 r5:80000093 r4:ef025980
[ 4.748209] [<c00358cc>] (warn_slowpath_null) from [<c050f9b0>] (clk_core_disable+0x68/0x6c)
[ 4.756685] [<c050f948>] (clk_core_disable) from [<c050fb34>] (clk_disable+0x2c/0x38)
[ 4.764545] r5:80000093 r4:ef1b0040
[ 4.768152] [<c050fb08>] (clk_disable) from [<c00246b0>] (_disable_clocks+0x20/0x84)
[ 4.775924] r5:fffffff0 r4:c093f108
[ 4.779531] [<c0024690>] (_disable_clocks) from [<c002568c>] (_enable+0x218/0x2d8)
[ 4.787129] r7:c093bc58 r6:c097f5d8 r5:fffffff0 r4:c093f108
[ 4.792844] [<c0025474>] (_enable) from [<c0025ecc>] (omap_hwmod_enable+0x2c/0x4c)
[ 4.800442] r7:c0027128 r6:a0000093 r5:c093f168 r4:c093f108
[ 4.806156] [<c0025ea0>] (omap_hwmod_enable) from [<c00270d8>] (omap_device_enable+0x48/0x98)
[ 4.814714] r7:c0027128 r6:ef2249c0 r5:00000000 r4:00000001
[ 4.820429] [<c0027090>] (omap_device_enable) from [<c0027140>] (_od_runtime_resume+0x18/0x2c)
[ 4.829074] r7:c0027128 r6:c0027128 r5:ef225674 r4:ef225610
[ 4.834789] [<c0027128>] (_od_runtime_resume) from [<c03ee1f4>] (__rpm_callback+0x34/0x68)
[ 4.843085] r5:ef225674 r4:ef225610
[ 4.846689] [<c03ee1c0>] (__rpm_callback) from [<c03ee250>] (rpm_callback+0x28/0x88)
[ 4.854461] r7:c0027128 r6:ef1c1410 r5:ef225610 r4:ef225610
[ 4.860174] [<c03ee228>] (rpm_callback) from [<c03ef134>] (rpm_resume+0x374/0x56c)
[ 4.867773] r7:c0027128 r6:ef1c1410 r5:c0930100 r4:ef225610
[ 4.873487] [<c03eedc0>] (rpm_resume) from [<c03ef380>] (__pm_runtime_resume+0x54/0x6c)
[ 4.881521] r10:00000000 r9:c08da600 r8:00000000 r7:60000013 r6:00000004 r5:ef225674
[ 4.889422] r4:ef225610
[ 4.891973] [<c03ef32c>] (__pm_runtime_resume) from [<c05177cc>] (of_dra7_atl_clk_probe+0x6c/0x23c)
[ 4.901054] r7:eea62bd0 r6:ef69d174 r5:ef225610 r4:ef225610
[ 4.906772] [<c0517760>] (of_dra7_atl_clk_probe) from [<c03e71c4>] (platform_drv_probe+0x54/0xb8)
[ 4.915678] r10:00000000 r9:c08da600 r8:00000000 r7:fffffdfb r6:c097070c r5:ef225610
[ 4.923576] r4:c09b9a40
[ 4.926129] [<c03e7170>] (platform_drv_probe) from [<c03e574c>] (driver_probe_device+0x204/0x2f8)
[ 4.935035] r7:c097070c r6:00000000 r5:ef225610 r4:c09b9a40
[ 4.940751] [<c03e5548>] (driver_probe_device) from [<c03e58d4>] (__driver_attach+0x94/0x98)
[ 4.949221] r9:c08da600 r8:000000ab r7:00000000 r6:ef225644 r5:c097070c r4:ef225610
[ 4.957038] [<c03e5840>] (__driver_attach) from [<c03e39d4>] (bus_for_each_dev+0x70/0xa4)
[ 4.965247] r7:00000000 r6:c03e5840 r5:c097070c r4:00000000
[ 4.970962] [<c03e3964>] (bus_for_each_dev) from [<c03e5038>] (driver_attach+0x24/0x28)
[ 4.978996] r6:c095ded0 r5:eea64280 r4:c097070c
[ 4.983657] [<c03e5014>] (driver_attach) from [<c03e4c74>] (bus_add_driver+0x1a8/0x220)
[ 4.991698] [<c03e4acc>] (bus_add_driver) from [<c03e6074>] (driver_register+0x80/0x100)
[ 4.999819] r7:eea62b80 r6:c09336f0 r5:c09093fc r4:c097070c
[ 5.005536] [<c03e5ff4>] (driver_register) from [<c03e70ec>] (__platform_driver_register+0x48/0x50)
[ 5.014617] r5:c09093fc r4:c095ded0
[ 5.018224] [<c03e70a4>] (__platform_driver_register) from [<c0909418>] (dra7_atl_clk_driver_init+0x1c/0x20)
[ 5.028089] r5:c09093fc r4:c09336f0
[ 5.031695] [<c09093fc>] (dra7_atl_clk_driver_init) from [<c000988c>] (do_one_initcall+0x98/0x1e4)
[ 5.040696] [<c00097f4>] (do_one_initcall) from [<c08daf40>] (kernel_init_freeable+0x1d4/0x268)
[ 5.049428] r10:00000007 r9:c08da600 r8:000000ab r7:c091a834 r6:c0928914 r5:c097f000
[ 5.057327] r4:c097f000
[ 5.059881] [<c08dad6c>] (kernel_init_freeable) from [<c067e79c>] (kernel_init+0x18/0xf4)
[ 5.068091] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c067e784
[ 5.075990] r4:c097f000
[ 5.078542] [<c067e784>] (kernel_init) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
[ 5.086140] r5:c067e784 r4:00000000
[ 5.089753] ---[ end trace d490fee65f167e39 ]---
[ 5.094388] omap_hwmod: atl: _wait_target_ready failed: -16
[ 5.101440] ------------[ cut here ]------------
[ 5.106082] WARNING: CPU: 0 PID: 1 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x25c/0x368()
[ 5.115427] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Idle): Data Access in Supervisor mode during Functional access
[ 5.127559] Modules linked in:
[ 5.130632] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.4.84-00027-g018eb62-dirty #3
[ 5.139628] Hardware name: Generic DRA72X (Flattened Device Tree)
[ 5.145743] Backtrace:
[ 5.148211] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
[ 5.155810] r7:c02e0130 r6:20000193 r5:00000000 r4:c094d590
[ 5.161529] [<c0013d00>] (show_stack) from [<c02b39a8>] (dump_stack+0x8c/0xa0)
[ 5.168784] [<c02b391c>] (dump_stack) from [<c003581c>] (warn_slowpath_common+0x88/0xb8)
[ 5.176906] r7:c02e0130 r6:00000093 r5:00000009 r4:ef08da80
[ 5.182619] [<c0035794>] (warn_slowpath_common) from [<c0035884>] (warn_slowpath_fmt+0x38/0x40)
[ 5.191351] r8:00000017 r7:c08419e0 r6:00000000 r5:c0841aa0 r4:c0841b44
[ 5.198122] [<c0035850>] (warn_slowpath_fmt) from [<c02e0130>] (l3_interrupt_handler+0x25c/0x368)
[ 5.207029] r3:ef1b8d80 r2:c0841b44
[ 5.210631] r4:80080003
[ 5.213185] [<c02dfed4>] (l3_interrupt_handler) from [<c0082048>] (handle_irq_event_percpu+0xb4/0x160)
[ 5.222528] r10:c097c7cb r9:ef1c3000 r8:00000017 r7:00000000 r6:00000000 r5:ef1c3060
[ 5.230429] r4:ef1c4280
[ 5.232982] [<c0081f94>] (handle_irq_event_percpu) from [<c0082134>] (handle_irq_event+0x40/0x64)
[ 5.241890] r10:00000000 r9:00000000 r8:ef006000 r7:00000000 r6:c0935c84 r5:ef1c3060
[ 5.249789] r4:ef1c3000
[ 5.252342] [<c00820f4>] (handle_irq_event) from [<c0085478>] (handle_fasteoi_irq+0xc0/0x194)
[ 5.260900] r7:00000000 r6:c0935c84 r5:ef1c3060 r4:ef1c3000
[ 5.266617] [<c00853b8>] (handle_fasteoi_irq) from [<c0081674>] (generic_handle_irq+0x2c/0x3c)
[ 5.275261] r7:00000000 r6:00000000 r5:00000017 r4:c092a40c
[ 5.280977] [<c0081648>] (generic_handle_irq) from [<c008194c>] (__handle_domain_irq+0x64/0xbc)
[ 5.289713] [<c00818e8>] (__handle_domain_irq) from [<c00094f0>] (gic_handle_irq+0x40/0x7c)
[ 5.298095] r9:00000000 r8:fa213000 r7:fa212000 r6:ef08dc40 r5:fa21200c r4:c09308e4
[ 5.305913] [<c00094b0>] (gic_handle_irq) from [<c0014854>] (__irq_svc+0x54/0x90)
[ 5.313424] Exception stack(0xef08dc40 to 0xef08dc88)
[ 5.318498] dc40: c09bb230 60000013 00000000 0000b162 c09bb230 ef69d27c 60000013 c0885fe0
[ 5.326712] dc60: ef08dcd8 00000000 00000000 ef08dc9c ef08dca0 ef08dc90 c0503f08 c06833dc
[ 5.334922] dc80: a0000013 ffffffff
[ 5.338422] r9:00000000 r8:ef08dcd8 r7:ef08dc74 r6:ffffffff r5:a0000013 r4:c06833dc
[ 5.346241] [<c06833b4>] (_raw_spin_unlock_irqrestore) from [<c0503f08>] (of_find_property+0x4c/0x54)
[ 5.355503] [<c0503ebc>] (of_find_property) from [<c050585c>] (__of_parse_phandle_with_args+0x30/0x250)
[ 5.364932] r9:00000000 r8:00000214 r7:eea62bd0 r6:00000000 r5:00000000 r4:ef225610
[ 5.372752] [<c050582c>] (__of_parse_phandle_with_args) from [<c0505c04>] (of_parse_phandle_with_args+0x2c/0x3c)
[ 5.382966] r10:00000000 r9:ef08dd50 r8:00000214 r7:eea62bd0 r6:ef69d174 r5:00000000
[ 5.390866] r4:ef225610
[ 5.393418] [<c0505bd8>] (of_parse_phandle_with_args) from [<c0517834>] (of_dra7_atl_clk_probe+0xd4/0x23c)
[ 5.403116] [<c0517760>] (of_dra7_atl_clk_probe) from [<c03e71c4>] (platform_drv_probe+0x54/0xb8)
[ 5.412021] r10:00000000 r9:c08da600 r8:00000000 r7:fffffdfb r6:c097070c r5:ef225610
[ 5.419921] r4:c09b9a40
[ 5.422473] [<c03e7170>] (platform_drv_probe) from [<c03e574c>] (driver_probe_device+0x204/0x2f8)
[ 5.431378] r7:c097070c r6:00000000 r5:ef225610 r4:c09b9a40
[ 5.437094] [<c03e5548>] (driver_probe_device) from [<c03e58d4>] (__driver_attach+0x94/0x98)
[ 5.445565] r9:c08da600 r8:000000ab r7:00000000 r6:ef225644 r5:c097070c r4:ef225610
[ 5.453383] [<c03e5840>] (__driver_attach) from [<c03e39d4>] (bus_for_each_dev+0x70/0xa4)
[ 5.461592] r7:00000000 r6:c03e5840 r5:c097070c r4:00000000
[ 5.467306] [<c03e3964>] (bus_for_each_dev) from [<c03e5038>] (driver_attach+0x24/0x28)
[ 5.475341] r6:c095ded0 r5:eea64280 r4:c097070c
[ 5.480004] [<c03e5014>] (driver_attach) from [<c03e4c74>] (bus_add_driver+0x1a8/0x220)
[ 5.488044] [<c03e4acc>] (bus_add_driver) from [<c03e6074>] (driver_register+0x80/0x100)
[ 5.496166] r7:eea62b80 r6:c09336f0 r5:c09093fc r4:c097070c
[ 5.501882] [<c03e5ff4>] (driver_register) from [<c03e70ec>] (__platform_driver_register+0x48/0x50)
[ 5.510964] r5:c09093fc r4:c095ded0
[ 5.514572] [<c03e70a4>] (__platform_driver_register) from [<c0909418>] (dra7_atl_clk_driver_init+0x1c/0x20)
[ 5.524438] r5:c09093fc r4:c09336f0
[ 5.528044] [<c09093fc>] (dra7_atl_clk_driver_init) from [<c000988c>] (do_one_initcall+0x98/0x1e4)
[ 5.537044] [<c00097f4>] (do_one_initcall) from [<c08daf40>] (kernel_init_freeable+0x1d4/0x268)
[ 5.545776] r10:00000007 r9:c08da600 r8:000000ab r7:c091a834 r6:c0928914 r5:c097f000
[ 5.553676] r4:c097f000
[ 5.556228] [<c08dad6c>] (kernel_init_freeable) from [<c067e79c>] (kernel_init+0x18/0xf4)
[ 5.564437] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c067e784
[ 5.572335] r4:c097f000
[ 5.574887] [<c067e784>] (kernel_init) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
[ 5.582486] r5:c067e784 r4:00000000
[ 5.586086] ---[ end trace d490fee65f167e3a ]---
[ 5.590812] ------------[ cut here ]------------
[ 5.595453] WARNING: CPU: 0 PID: 1 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x25c/0x368()
[ 5.604798] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Idle): Data Access in Supervisor mode during Functional access
[ 5.616931] Modules linked in:
[ 5.620004] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.4.84-00027-g018eb62-dirty #3
[ 5.628997] Hardware name: Generic DRA72X (Flattened Device Tree)
[ 5.635111] Backtrace:
[ 5.637579] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
[ 5.645177] r7:c02e0130 r6:20000193 r5:00000000 r4:c094d590
[ 5.650895] [<c0013d00>] (show_stack) from [<c02b39a8>] (dump_stack+0x8c/0xa0)
[ 5.658149] [<c02b391c>] (dump_stack) from [<c003581c>] (warn_slowpath_common+0x88/0xb8)
[ 5.666271] r7:c02e0130 r6:00000093 r5:00000009 r4:ef08da80
[ 5.671985] [<c0035794>] (warn_slowpath_common) from [<c0035884>] (warn_slowpath_fmt+0x38/0x40)
[ 5.680718] r8:00000017 r7:c08419e0 r6:00000000 r5:c0841aa0 r4:c0841b44
[ 5.687487] [<c0035850>] (warn_slowpath_fmt) from [<c02e0130>] (l3_interrupt_handler+0x25c/0x368)
[ 5.696393] r3:ef1b8d80 r2:c0841b44
[ 5.699995] r4:80080003
[ 5.702547] [<c02dfed4>] (l3_interrupt_handler) from [<c0082048>] (handle_irq_event_percpu+0xb4/0x160)
[ 5.711890] r10:c097c7cb r9:ef1c3000 r8:00000017 r7:00000000 r6:00000000 r5:ef1c3060
[ 5.719791] r4:ef1c4280
[ 5.722344] [<c0081f94>] (handle_irq_event_percpu) from [<c0082134>] (handle_irq_event+0x40/0x64)
[ 5.731251] r10:00000000 r9:00000002 r8:ef006000 r7:00000000 r6:c0935c84 r5:ef1c3060
[ 5.739149] r4:ef1c3000
[ 5.741702] [<c00820f4>] (handle_irq_event) from [<c0085478>] (handle_fasteoi_irq+0xc0/0x194)
[ 5.750259] r7:00000000 r6:c0935c84 r5:ef1c3060 r4:ef1c3000
[ 5.755974] [<c00853b8>] (handle_fasteoi_irq) from [<c0081674>] (generic_handle_irq+0x2c/0x3c)
[ 5.764619] r7:00000000 r6:00000000 r5:00000017 r4:c092a40c
[ 5.770334] [<c0081648>] (generic_handle_irq) from [<c008194c>] (__handle_domain_irq+0x64/0xbc)
[ 5.779071] [<c00818e8>] (__handle_domain_irq) from [<c00094f0>] (gic_handle_irq+0x40/0x7c)
[ 5.787453] r9:00000002 r8:fa213000 r7:fa212000 r6:ef08dc40 r5:fa21200c r4:c09308e4
[ 5.795269] [<c00094b0>] (gic_handle_irq) from [<c0014854>] (__irq_svc+0x54/0x90)
[ 5.802780] Exception stack(0xef08dc40 to 0xef08dc88)
[ 5.807854] dc40: c09bb230 20000013 00000000 0000b16a c09bb230 ef69d27c 20000013 c0885fe0
[ 5.816067] dc60: ef08dcd8 00000002 00000000 ef08dc9c ef08dca0 ef08dc90 c0503f08 c06833dc
[ 5.824276] dc80: a0000013 ffffffff
[ 5.827776] r9:00000002 r8:ef08dcd8 r7:ef08dc74 r6:ffffffff r5:a0000013 r4:c06833dc
[ 5.835594] [<c06833b4>] (_raw_spin_unlock_irqrestore) from [<c0503f08>] (of_find_property+0x4c/0x54)
[ 5.844856] [<c0503ebc>] (of_find_property) from [<c050585c>] (__of_parse_phandle_with_args+0x30/0x250)
[ 5.854285] r9:00000002 r8:00000314 r7:eea62c40 r6:00000000 r5:00000002 r4:ef02fc44
[ 5.862102] [<c050582c>] (__of_parse_phandle_with_args) from [<c0505c04>] (of_parse_phandle_with_args+0x2c/0x3c)
[ 5.872317] r10:00000000 r9:ef08dd50 r8:00000314 r7:eea62c40 r6:ef69d174 r5:00000002
[ 5.880217] r4:ef02fc44
[ 5.882769] [<c0505bd8>] (of_parse_phandle_with_args) from [<c0517834>] (of_dra7_atl_clk_probe+0xd4/0x23c)
[ 5.892467] [<c0517760>] (of_dra7_atl_clk_probe) from [<c03e71c4>] (platform_drv_probe+0x54/0xb8)
[ 5.901374] r10:00000000 r9:c08da600 r8:00000000 r7:fffffdfb r6:c097070c r5:ef225610
[ 5.909274] r4:c09b9a40
[ 5.911828] [<c03e7170>] (platform_drv_probe) from [<c03e574c>] (driver_probe_device+0x204/0x2f8)
[ 5.920734] r7:c097070c r6:00000000 r5:ef225610 r4:c09b9a40
[ 5.926450] [<c03e5548>] (driver_probe_device) from [<c03e58d4>] (__driver_attach+0x94/0x98)
[ 5.934921] r9:c08da600 r8:000000ab r7:00000000 r6:ef225644 r5:c097070c r4:ef225610
[ 5.942738] [<c03e5840>] (__driver_attach) from [<c03e39d4>] (bus_for_each_dev+0x70/0xa4)
[ 5.950947] r7:00000000 r6:c03e5840 r5:c097070c r4:00000000
[ 5.956660] [<c03e3964>] (bus_for_each_dev) from [<c03e5038>] (driver_attach+0x24/0x28)
[ 5.964693] r6:c095ded0 r5:eea64280 r4:c097070c
[ 5.969356] [<c03e5014>] (driver_attach) from [<c03e4c74>] (bus_add_driver+0x1a8/0x220)
[ 5.977397] [<c03e4acc>] (bus_add_driver) from [<c03e6074>] (driver_register+0x80/0x100)
[ 5.985519] r7:eea62b80 r6:c09336f0 r5:c09093fc r4:c097070c
[ 5.991236] [<c03e5ff4>] (driver_register) from [<c03e70ec>] (__platform_driver_register+0x48/0x50)
[ 6.000317] r5:c09093fc r4:c095ded0
[ 6.003924] [<c03e70a4>] (__platform_driver_register) from [<c0909418>] (dra7_atl_clk_driver_init+0x1c/0x20)
[ 6.013791] r5:c09093fc r4:c09336f0
[ 6.017396] [<c09093fc>] (dra7_atl_clk_driver_init) from [<c000988c>] (do_one_initcall+0x98/0x1e4)
[ 6.026396] [<c00097f4>] (do_one_initcall) from [<c08daf40>] (kernel_init_freeable+0x1d4/0x268)
[ 6.035129] r10:00000007 r9:c08da600 r8:000000ab r7:c091a834 r6:c0928914 r5:c097f000
[ 6.043027] r4:c097f000
[ 6.045579] [<c08dad6c>] (kernel_init_freeable) from [<c067e79c>] (kernel_init+0x18/0xf4)
[ 6.053788] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c067e784
[ 6.061686] r4:c097f000
[ 6.064239] [<c067e784>] (kernel_init) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
[ 6.071837] r5:c067e784 r4:00000000
[ 6.075437] ---[ end trace d490fee65f167e3b ]---
[ 6.081326] ------------[ cut here ]------------
[ 6.085967] WARNING: CPU: 0 PID: 1 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x25c/0x368()
[ 6.095312] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Idle): Data Access in Supervisor mode during Functional access
[ 6.107444] Modules linked in:
[ 6.110519] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.4.84-00027-g018eb62-dirty #3
[ 6.119513] Hardware name: Generic DRA72X (Flattened Device Tree)
[ 6.125628] Backtrace:
[ 6.128096] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
[ 6.135694] r7:c02e0130 r6:20000193 r5:00000000 r4:c094d590
[ 6.141410] [<c0013d00>] (show_stack) from [<c02b39a8>] (dump_stack+0x8c/0xa0)
[ 6.148665] [<c02b391c>] (dump_stack) from [<c003581c>] (warn_slowpath_common+0x88/0xb8)
[ 6.156786] r7:c02e0130 r6:00000093 r5:00000009 r4:ef08da80
[ 6.162500] [<c0035794>] (warn_slowpath_common) from [<c0035884>] (warn_slowpath_fmt+0x38/0x40)
[ 6.171232] r8:00000017 r7:c08419e0 r6:00000000 r5:c0841aa0 r4:c0841b44
[ 6.178001] [<c0035850>] (warn_slowpath_fmt) from [<c02e0130>] (l3_interrupt_handler+0x25c/0x368)
[ 6.186908] r3:ef1b8d80 r2:c0841b44
[ 6.190509] r4:80080003
[ 6.193062] [<c02dfed4>] (l3_interrupt_handler) from [<c0082048>] (handle_irq_event_percpu+0xb4/0x160)
[ 6.202404] r10:c097c7cb r9:ef1c3000 r8:00000017 r7:00000000 r6:00000000 r5:ef1c3060
[ 6.210304] r4:ef1c4280
[ 6.212857] [<c0081f94>] (handle_irq_event_percpu) from [<c0082134>] (handle_irq_event+0x40/0x64)
[ 6.221764] r10:00000000 r9:00000003 r8:ef006000 r7:00000000 r6:c0935c84 r5:ef1c3060
[ 6.229663] r4:ef1c3000
[ 6.232214] [<c00820f4>] (handle_irq_event) from [<c0085478>] (handle_fasteoi_irq+0xc0/0x194)
[ 6.240771] r7:00000000 r6:c0935c84 r5:ef1c3060 r4:ef1c3000
[ 6.246485] [<c00853b8>] (handle_fasteoi_irq) from [<c0081674>] (generic_handle_irq+0x2c/0x3c)
[ 6.255130] r7:00000000 r6:00000000 r5:00000017 r4:c092a40c
[ 6.260845] [<c0081648>] (generic_handle_irq) from [<c008194c>] (__handle_domain_irq+0x64/0xbc)
[ 6.269582] [<c00818e8>] (__handle_domain_irq) from [<c00094f0>] (gic_handle_irq+0x40/0x7c)
[ 6.277965] r9:00000003 r8:fa213000 r7:fa212000 r6:ef08dc40 r5:fa21200c r4:c09308e4
[ 6.285781] [<c00094b0>] (gic_handle_irq) from [<c0014854>] (__irq_svc+0x54/0x90)
[ 6.293293] Exception stack(0xef08dc40 to 0xef08dc88)
[ 6.298367] dc40: c09bb230 20000013 00000000 0000b16f c09bb230 ef69d27c 20000013 c0885fe0
[ 6.306581] dc60: ef08dcd8 00000003 00000000 ef08dc9c ef08dca0 ef08dc90 c0503f08 c06833dc
[ 6.314791] dc80: a0000013 ffffffff
[ 6.318290] r9:00000003 r8:ef08dcd8 r7:ef08dc74 r6:ffffffff r5:a0000013 r4:c06833dc
[ 6.326110] [<c06833b4>] (_raw_spin_unlock_irqrestore) from [<c0503f08>] (of_find_property+0x4c/0x54)
[ 6.335372] [<c0503ebc>] (of_find_property) from [<c050585c>] (__of_parse_phandle_with_args+0x30/0x250)
[ 6.344800] r9:00000003 r8:00000394 r7:eea62c80 r6:00000000 r5:00000003 r4:ef0038c4
[ 6.352621] [<c050582c>] (__of_parse_phandle_with_args) from [<c0505c04>] (of_parse_phandle_with_args+0x2c/0x3c)
[ 6.362835] r10:00000000 r9:ef08dd50 r8:00000394 r7:eea62c80 r6:ef69d174 r5:00000003
[ 6.370735] r4:ef0038c4
[ 6.373288] [<c0505bd8>] (of_parse_phandle_with_args) from [<c0517834>] (of_dra7_atl_clk_probe+0xd4/0x23c)
[ 6.382986] [<c0517760>] (of_dra7_atl_clk_probe) from [<c03e71c4>] (platform_drv_probe+0x54/0xb8)
[ 6.391892] r10:00000000 r9:c08da600 r8:00000000 r7:fffffdfb r6:c097070c r5:ef225610
[ 6.399791] r4:c09b9a40
[ 6.402344] [<c03e7170>] (platform_drv_probe) from [<c03e574c>] (driver_probe_device+0x204/0x2f8)
[ 6.411250] r7:c097070c r6:00000000 r5:ef225610 r4:c09b9a40
[ 6.416967] [<c03e5548>] (driver_probe_device) from [<c03e58d4>] (__driver_attach+0x94/0x98)
[ 6.425437] r9:c08da600 r8:000000ab r7:00000000 r6:ef225644 r5:c097070c r4:ef225610
[ 6.433255] [<c03e5840>] (__driver_attach) from [<c03e39d4>] (bus_for_each_dev+0x70/0xa4)
[ 6.441463] r7:00000000 r6:c03e5840 r5:c097070c r4:00000000
[ 6.447179] [<c03e3964>] (bus_for_each_dev) from [<c03e5038>] (driver_attach+0x24/0x28)
[ 6.455214] r6:c095ded0 r5:eea64280 r4:c097070c
[ 6.459876] [<c03e5014>] (driver_attach) from [<c03e4c74>] (bus_add_driver+0x1a8/0x220)
[ 6.467917] [<c03e4acc>] (bus_add_driver) from [<c03e6074>] (driver_register+0x80/0x100)
[ 6.476038] r7:eea62b80 r6:c09336f0 r5:c09093fc r4:c097070c
[ 6.481757] [<c03e5ff4>] (driver_register) from [<c03e70ec>] (__platform_driver_register+0x48/0x50)
[ 6.490839] r5:c09093fc r4:c095ded0
[ 6.494446] [<c03e70a4>] (__platform_driver_register) from [<c0909418>] (dra7_atl_clk_driver_init+0x1c/0x20)
[ 6.504311] r5:c09093fc r4:c09336f0
[ 6.507918] [<c09093fc>] (dra7_atl_clk_driver_init) from [<c000988c>] (do_one_initcall+0x98/0x1e4)
[ 6.516917] [<c00097f4>] (do_one_initcall) from [<c08daf40>] (kernel_init_freeable+0x1d4/0x268)
[ 6.525650] r10:00000007 r9:c08da600 r8:000000ab r7:c091a834 r6:c0928914 r5:c097f000
[ 6.533548] r4:c097f000
[ 6.536101] [<c08dad6c>] (kernel_init_freeable) from [<c067e79c>] (kernel_init+0x18/0xf4)
[ 6.544310] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c067e784
[ 6.552211] r4:c097f000
[ 6.554763] [<c067e784>] (kernel_init) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
[ 6.562361] r5:c067e784 r4:00000000
[ 6.565961] ---[ end trace d490fee65f167e3c ]---
[ 6.575218] mmc0: new HS200 MMC card at address 0001
[ 6.582407] hwspinlock_user gatemp: requested 20 hwspinlocks
[ 6.589532] aic_dvdd: supplied by evm_3v3
[ 7.840841] clock: dpll_abe_ck failed transition to 'locked'
[ 9.130745] clock: dpll_abe_ck failed transition to 'locked'
[ 9.137797] ------------[ cut here ]------------
[ 9.142442] WARNING: CPU: 0 PID: 1 at drivers/clk/clk.c:680 clk_core_disable+0x68/0x6c()
[ 9.150564] Modules linked in:
[ 9.153640] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.4.84-00027-g018eb62-dirty #3
[ 9.162635] Hardware name: Generic DRA72X (Flattened Device Tree)
[ 9.168751] Backtrace:
[ 9.171223] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
[ 9.178822] r7:c050f9b0 r6:20000093 r5:00000000 r4:c094d590
[ 9.184541] [<c0013d00>] (show_stack) from [<c02b39a8>] (dump_stack+0x8c/0xa0)
[ 9.191797] [<c02b391c>] (dump_stack) from [<c003581c>] (warn_slowpath_common+0x88/0xb8)
[ 9.199919] r7:c050f9b0 r6:000002a8 r5:00000009 r4:00000000
[ 9.205633] [<c0035794>] (warn_slowpath_common) from [<c00358f0>] (warn_slowpath_null+0x24/0x2c)
[ 9.214452] r8:ef029680 r7:00000004 r6:ef02ef80 r5:20000013 r4:ef02ef80
[ 9.221222] [<c00358cc>] (warn_slowpath_null) from [<c050f9b0>] (clk_core_disable+0x68/0x6c)
[ 9.229699] [<c050f948>] (clk_core_disable) from [<c050fb64>] (__clk_set_parent_after.part.6+0x24/0x40)
[ 9.239129] r5:20000013 r4:ef029680
[ 9.242736] [<c050fb40>] (__clk_set_parent_after.part.6) from [<c0510f58>] (clk_core_set_parent+0x17c/0x190)
[ 9.252602] r7:00000004 r6:ef02e880 r5:00000000 r4:ef02ef80
[ 9.258317] [<c0510ddc>] (clk_core_set_parent) from [<c0510f90>] (clk_set_parent+0x24/0x28)
[ 9.266699] r9:c0884168 r8:eea6ae80 r7:ef08dd50 r6:00000000 r5:ef69d92c r4:eea6aec0
[ 9.274517] [<c0510f6c>] (clk_set_parent) from [<c051482c>] (of_clk_set_defaults+0x120/0x348)
[ 9.283084] [<c051470c>] (of_clk_set_defaults) from [<c03e7190>] (platform_drv_probe+0x20/0xb8)
[ 9.291816] r10:00000000 r9:c08da600 r8:00000000 r7:c097359c r6:c097359c r5:ef225810
[ 9.299714] r4:c09b9a40
[ 9.302267] [<c03e7170>] (platform_drv_probe) from [<c03e574c>] (driver_probe_device+0x204/0x2f8)
[ 9.311174] r7:c097359c r6:00000000 r5:ef225810 r4:c09b9a40
[ 9.316891] [<c03e5548>] (driver_probe_device) from [<c03e58d4>] (__driver_attach+0x94/0x98)
[ 9.325361] r9:c08da600 r8:000000ab r7:00000000 r6:ef225844 r5:c097359c r4:ef225810
[ 9.333179] [<c03e5840>] (__driver_attach) from [<c03e39d4>] (bus_for_each_dev+0x70/0xa4)
[ 9.341388] r7:00000000 r6:c03e5840 r5:c097359c r4:00000000
[ 9.347101] [<c03e3964>] (bus_for_each_dev) from [<c03e5038>] (driver_attach+0x24/0x28)
[ 9.355134] r6:c095ded0 r5:eea6c000 r4:c097359c
[ 9.359795] [<c03e5014>] (driver_attach) from [<c03e4c74>] (bus_add_driver+0x1a8/0x220)
[ 9.367835] [<c03e4acc>] (bus_add_driver) from [<c03e6074>] (driver_register+0x80/0x100)
[ 9.375956] r7:eea6ae40 r6:c09336f0 r5:c090a298 r4:c097359c
[ 9.381673] [<c03e5ff4>] (driver_register) from [<c03e70ec>] (__platform_driver_register+0x48/0x50)
[ 9.390755] r5:c090a298 r4:c095ded0
[ 9.394362] [<c03e70a4>] (__platform_driver_register) from [<c090a2b4>] (davinci_mcasp_driver_init+0x1c/0x20)
[ 9.404314] r5:c090a298 r4:c09336f0
[ 9.407920] [<c090a298>] (davinci_mcasp_driver_init) from [<c000988c>] (do_one_initcall+0x98/0x1e4)
[ 9.417008] [<c00097f4>] (do_one_initcall) from [<c08daf40>] (kernel_init_freeable+0x1d4/0x268)
[ 9.425740] r10:00000007 r9:c08da600 r8:000000ab r7:c091a834 r6:c092893c r5:c097f000
[ 9.433640] r4:c097f000
[ 9.436192] [<c08dad6c>] (kernel_init_freeable) from [<c067e79c>] (kernel_init+0x18/0xf4)
[ 9.444400] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c067e784
[ 9.452299] r4:c097f000
[ 9.454850] [<c067e784>] (kernel_init) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
[ 9.462448] r5:c067e784 r4:00000000
[ 9.466049] ---[ end trace 5aba3efb8442f3ff ]---
[ 9.470682] ------------[ cut here ]------------
[ 9.475321] WARNING: CPU: 0 PID: 1 at drivers/clk/clk.c:680 clk_core_disable+0x68/0x6c()
[ 9.483442] Modules linked in:
[ 9.486516] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.4.84-00027-g018eb62-dirty #3
[ 9.495509] Hardware name: Generic DRA72X (Flattened Device Tree)
[ 9.501623] Backtrace:
[ 9.504090] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
[ 9.511688] r7:c050f9b0 r6:20000093 r5:00000000 r4:c094d590
[ 9.517404] [<c0013d00>] (show_stack) from [<c02b39a8>] (dump_stack+0x8c/0xa0)
[ 9.524657] [<c02b391c>] (dump_stack) from [<c003581c>] (warn_slowpath_common+0x88/0xb8)
[ 9.532779] r7:c050f9b0 r6:000002a8 r5:00000009 r4:00000000
[ 9.538491] [<c0035794>] (warn_slowpath_common) from [<c00358f0>] (warn_slowpath_null+0x24/0x2c)
[ 9.547310] r8:ef029680 r7:00000004 r6:ef02ef80 r5:20000013 r4:ef029680
[ 9.554078] [<c00358cc>] (warn_slowpath_null) from [<c050f9b0>] (clk_core_disable+0x68/0x6c)
[ 9.562554] [<c050f948>] (clk_core_disable) from [<c050fb6c>] (__clk_set_parent_after.part.6+0x2c/0x40)
[ 9.571984] r5:20000013 r4:ef029680
[ 9.575591] [<c050fb40>] (__clk_set_parent_after.part.6) from [<c0510f58>] (clk_core_set_parent+0x17c/0x190)
[ 9.585455] r7:00000004 r6:ef02e880 r5:00000000 r4:ef02ef80
[ 9.591171] [<c0510ddc>] (clk_core_set_parent) from [<c0510f90>] (clk_set_parent+0x24/0x28)
[ 9.599554] r9:c0884168 r8:eea6ae80 r7:ef08dd50 r6:00000000 r5:ef69d92c r4:eea6aec0
[ 9.607372] [<c0510f6c>] (clk_set_parent) from [<c051482c>] (of_clk_set_defaults+0x120/0x348)
[ 9.615936] [<c051470c>] (of_clk_set_defaults) from [<c03e7190>] (platform_drv_probe+0x20/0xb8)
[ 9.624666] r10:00000000 r9:c08da600 r8:00000000 r7:c097359c r6:c097359c r5:ef225810
[ 9.632565] r4:c09b9a40
[ 9.635117] [<c03e7170>] (platform_drv_probe) from [<c03e574c>] (driver_probe_device+0x204/0x2f8)
[ 9.644023] r7:c097359c r6:00000000 r5:ef225810 r4:c09b9a40
[ 9.649739] [<c03e5548>] (driver_probe_device) from [<c03e58d4>] (__driver_attach+0x94/0x98)
[ 9.658208] r9:c08da600 r8:000000ab r7:00000000 r6:ef225844 r5:c097359c r4:ef225810
[ 9.666025] [<c03e5840>] (__driver_attach) from [<c03e39d4>] (bus_for_each_dev+0x70/0xa4)
[ 9.674234] r7:00000000 r6:c03e5840 r5:c097359c r4:00000000
[ 9.679949] [<c03e3964>] (bus_for_each_dev) from [<c03e5038>] (driver_attach+0x24/0x28)
[ 9.687982] r6:c095ded0 r5:eea6c000 r4:c097359c
[ 9.692643] [<c03e5014>] (driver_attach) from [<c03e4c74>] (bus_add_driver+0x1a8/0x220)
[ 9.700682] [<c03e4acc>] (bus_add_driver) from [<c03e6074>] (driver_register+0x80/0x100)
[ 9.708803] r7:eea6ae40 r6:c09336f0 r5:c090a298 r4:c097359c
[ 9.714519] [<c03e5ff4>] (driver_register) from [<c03e70ec>] (__platform_driver_register+0x48/0x50)
[ 9.723598] r5:c090a298 r4:c095ded0
[ 9.727204] [<c03e70a4>] (__platform_driver_register) from [<c090a2b4>] (davinci_mcasp_driver_init+0x1c/0x20)
[ 9.737157] r5:c090a298 r4:c09336f0
[ 9.740762] [<c090a298>] (davinci_mcasp_driver_init) from [<c000988c>] (do_one_initcall+0x98/0x1e4)
[ 9.749848] [<c00097f4>] (do_one_initcall) from [<c08daf40>] (kernel_init_freeable+0x1d4/0x268)
[ 9.758580] r10:00000007 r9:c08da600 r8:000000ab r7:c091a834 r6:c092893c r5:c097f000
[ 9.766477] r4:c097f000
[ 9.769028] [<c08dad6c>] (kernel_init_freeable) from [<c067e79c>] (kernel_init+0x18/0xf4)
[ 9.777236] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c067e784
[ 9.785133] r4:c097f000
[ 9.787683] [<c067e784>] (kernel_init) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
[ 9.795281] r5:c067e784 r4:00000000
[ 9.798883] ---[ end trace 5aba3efb8442f400 ]---
[ 9.804698] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 9.809414] davinci-mcasp 48464000.mcasp: DAI is shared
[ 11.099296] clock: dpll_abe_ck failed transition to 'locked'
[ 12.389514] clock: dpll_abe_ck failed transition to 'locked'
[ 13.679479] clock: dpll_abe_ck failed transition to 'locked'
[ 13.687735] ------------[ cut here ]------------
[ 13.692375] WARNING: CPU: 0 PID: 1 at drivers/clk/clk.c:680 clk_core_disable+0x68/0x6c()
[ 13.700497] Modules linked in:
[ 13.703571] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.4.84-00027-g018eb62-dirty #3
[ 13.712565] Hardware name: Generic DRA72X (Flattened Device Tree)
[ 13.718680] Backtrace:
[ 13.721148] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
[ 13.728746] r7:c050f9b0 r6:20000093 r5:00000000 r4:c094d590
[ 13.734464] [<c0013d00>] (show_stack) from [<c02b39a8>] (dump_stack+0x8c/0xa0)
[ 13.741718] [<c02b391c>] (dump_stack) from [<c003581c>] (warn_slowpath_common+0x88/0xb8)
[ 13.749840] r7:c050f9b0 r6:000002a8 r5:00000009 r4:00000000
[ 13.755554] [<c0035794>] (warn_slowpath_common) from [<c00358f0>] (warn_slowpath_null+0x24/0x2c)
[ 13.764373] r8:00000000 r7:c093bc58 r6:c093c67c r5:80000093 r4:ef029c00
[ 13.771145] [<c00358cc>] (warn_slowpath_null) from [<c050f9b0>] (clk_core_disable+0x68/0x6c)
[ 13.779620] [<c050f948>] (clk_core_disable) from [<c050fb34>] (clk_disable+0x2c/0x38)
[ 13.787480] r5:80000093 r4:ef1b0440
[ 13.791087] [<c050fb08>] (clk_disable) from [<c00246b0>] (_disable_clocks+0x20/0x84)
[ 13.798861] r5:fffffff0 r4:c093c67c
[ 13.802466] [<c0024690>] (_disable_clocks) from [<c002568c>] (_enable+0x218/0x2d8)
[ 13.810063] r7:c093bc58 r6:c097f5d8 r5:fffffff0 r4:c093c67c
[ 13.815777] [<c0025474>] (_enable) from [<c0025ecc>] (omap_hwmod_enable+0x2c/0x4c)
[ 13.823376] r7:c0027128 r6:a0000013 r5:c093c6dc r4:c093c67c
[ 13.829091] [<c0025ea0>] (omap_hwmod_enable) from [<c00270d8>] (omap_device_enable+0x48/0x98)
[ 13.837650] r7:c0027128 r6:ef224c40 r5:00000000 r4:00000001
[ 13.843367] [<c0027090>] (omap_device_enable) from [<c0027140>] (_od_runtime_resume+0x18/0x2c)
[ 13.852012] r7:c0027128 r6:c0027128 r5:ef225874 r4:ef225810
[ 13.857726] [<c0027128>] (_od_runtime_resume) from [<c03ee1f4>] (__rpm_callback+0x34/0x68)
[ 13.866022] r5:ef225874 r4:ef225810
[ 13.869628] [<c03ee1c0>] (__rpm_callback) from [<c03ee250>] (rpm_callback+0x28/0x88)
[ 13.877401] r7:c0027128 r6:ef1c1410 r5:ef225810 r4:ef225810
[ 13.883115] [<c03ee228>] (rpm_callback) from [<c03ef134>] (rpm_resume+0x374/0x56c)
[ 13.890713] r7:c0027128 r6:ef1c1410 r5:c0930100 r4:ef225810
[ 13.896428] [<c03eedc0>] (rpm_resume) from [<c03ef5e8>] (pm_runtime_forbid+0x58/0x64)
[ 13.904287] r10:00000000 r9:ef223300 r8:eea6c210 r7:ef225810 r6:ef225800 r5:ef225874
[ 13.912187] r4:ef225810
[ 13.914740] [<c03ef590>] (pm_runtime_forbid) from [<c0558340>] (davinci_mcasp_probe+0x580/0xb74)
[ 13.923559] r5:eea6c210 r4:eea6e210
[ 13.927167] [<c0557dc0>] (davinci_mcasp_probe) from [<c03e71c4>] (platform_drv_probe+0x54/0xb8)
[ 13.935898] r10:00000000 r9:c08da600 r8:00000000 r7:fffffdfb r6:c097359c r5:ef225810
[ 13.943798] r4:c09b9a40
[ 13.946351] [<c03e7170>] (platform_drv_probe) from [<c03e574c>] (driver_probe_device+0x204/0x2f8)
[ 13.955257] r7:c097359c r6:00000000 r5:ef225810 r4:c09b9a40
[ 13.960974] [<c03e5548>] (driver_probe_device) from [<c03e58d4>] (__driver_attach+0x94/0x98)
[ 13.969444] r9:c08da600 r8:000000ab r7:00000000 r6:ef225844 r5:c097359c r4:ef225810
[ 13.977261] [<c03e5840>] (__driver_attach) from [<c03e39d4>] (bus_for_each_dev+0x70/0xa4)
[ 13.985470] r7:00000000 r6:c03e5840 r5:c097359c r4:00000000
[ 13.991185] [<c03e3964>] (bus_for_each_dev) from [<c03e5038>] (driver_attach+0x24/0x28)
[ 13.999220] r6:c095ded0 r5:eea6c000 r4:c097359c
[ 14.003882] [<c03e5014>] (driver_attach) from [<c03e4c74>] (bus_add_driver+0x1a8/0x220)
[ 14.011922] [<c03e4acc>] (bus_add_driver) from [<c03e6074>] (driver_register+0x80/0x100)
[ 14.020044] r7:eea6ae40 r6:c09336f0 r5:c090a298 r4:c097359c
[ 14.025760] [<c03e5ff4>] (driver_register) from [<c03e70ec>] (__platform_driver_register+0x48/0x50)
[ 14.034841] r5:c090a298 r4:c095ded0
[ 14.038450] [<c03e70a4>] (__platform_driver_register) from [<c090a2b4>] (davinci_mcasp_driver_init+0x1c/0x20)
[ 14.048403] r5:c090a298 r4:c09336f0
[ 14.052010] [<c090a298>] (davinci_mcasp_driver_init) from [<c000988c>] (do_one_initcall+0x98/0x1e4)
[ 14.061098] [<c00097f4>] (do_one_initcall) from [<c08daf40>] (kernel_init_freeable+0x1d4/0x268)
[ 14.069830] r10:00000007 r9:c08da600 r8:000000ab r7:c091a834 r6:c092893c r5:c097f000
[ 14.077729] r4:c097f000
[ 14.080281] [<c08dad6c>] (kernel_init_freeable) from [<c067e79c>] (kernel_init+0x18/0xf4)
[ 14.088490] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c067e784
[ 14.096388] r4:c097f000
[ 14.098939] [<c067e784>] (kernel_init) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
[ 14.106538] r5:c067e784 r4:00000000
[ 14.110139] ---[ end trace 5aba3efb8442f401 ]---
[ 14.114774] ------------[ cut here ]------------
[ 14.119412] WARNING: CPU: 0 PID: 1 at drivers/clk/clk.c:680 clk_core_disable+0x68/0x6c()
[ 14.127533] Modules linked in:
[ 14.130605] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.4.84-00027-g018eb62-dirty #3
[ 14.139600] Hardware name: Generic DRA72X (Flattened Device Tree)
[ 14.145714] Backtrace:
[ 14.148181] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
[ 14.155779] r7:c050f9b0 r6:20000093 r5:00000000 r4:c094d590
[ 14.161497] [<c0013d00>] (show_stack) from [<c02b39a8>] (dump_stack+0x8c/0xa0)
[ 14.168750] [<c02b391c>] (dump_stack) from [<c003581c>] (warn_slowpath_common+0x88/0xb8)
[ 14.176872] r7:c050f9b0 r6:000002a8 r5:00000009 r4:00000000
[ 14.182586] [<c0035794>] (warn_slowpath_common) from [<c00358f0>] (warn_slowpath_null+0x24/0x2c)
[ 14.191405] r8:00000000 r7:c093bc58 r6:c093c67c r5:80000093 r4:ef02ef80
[ 14.198175] [<c00358cc>] (warn_slowpath_null) from [<c050f9b0>] (clk_core_disable+0x68/0x6c)
[ 14.206651] [<c050f948>] (clk_core_disable) from [<c050fb34>] (clk_disable+0x2c/0x38)
[ 14.214511] r5:80000093 r4:ef1b0500
[ 14.218117] [<c050fb08>] (clk_disable) from [<c0024680>] (_disable_optional_clocks+0x34/0x44)
[ 14.226673] r5:00000002 r4:c093c704
[ 14.230278] [<c002464c>] (_disable_optional_clocks) from [<c002470c>] (_disable_clocks+0x7c/0x84)
[ 14.239184] r5:c093c6c8 r4:00000003
[ 14.242789] [<c0024690>] (_disable_clocks) from [<c002568c>] (_enable+0x218/0x2d8)
[ 14.250387] r7:c093bc58 r6:c097f5d8 r5:fffffff0 r4:c093c67c
[ 14.256100] [<c0025474>] (_enable) from [<c0025ecc>] (omap_hwmod_enable+0x2c/0x4c)
[ 14.263699] r7:c0027128 r6:a0000013 r5:c093c6dc r4:c093c67c
[ 14.269414] [<c0025ea0>] (omap_hwmod_enable) from [<c00270d8>] (omap_device_enable+0x48/0x98)
[ 14.277971] r7:c0027128 r6:ef224c40 r5:00000000 r4:00000001
[ 14.283688] [<c0027090>] (omap_device_enable) from [<c0027140>] (_od_runtime_resume+0x18/0x2c)
[ 14.292332] r7:c0027128 r6:c0027128 r5:ef225874 r4:ef225810
[ 14.298045] [<c0027128>] (_od_runtime_resume) from [<c03ee1f4>] (__rpm_callback+0x34/0x68)
[ 14.306342] r5:ef225874 r4:ef225810
[ 14.309946] [<c03ee1c0>] (__rpm_callback) from [<c03ee250>] (rpm_callback+0x28/0x88)
[ 14.317719] r7:c0027128 r6:ef1c1410 r5:ef225810 r4:ef225810
[ 14.323434] [<c03ee228>] (rpm_callback) from [<c03ef134>] (rpm_resume+0x374/0x56c)
[ 14.331032] r7:c0027128 r6:ef1c1410 r5:c0930100 r4:ef225810
[ 14.336747] [<c03eedc0>] (rpm_resume) from [<c03ef5e8>] (pm_runtime_forbid+0x58/0x64)
[ 14.344607] r10:00000000 r9:ef223300 r8:eea6c210 r7:ef225810 r6:ef225800 r5:ef225874
[ 14.352507] r4:ef225810
[ 14.355059] [<c03ef590>] (pm_runtime_forbid) from [<c0558340>] (davinci_mcasp_probe+0x580/0xb74)
[ 14.363878] r5:eea6c210 r4:eea6e210
[ 14.367485] [<c0557dc0>] (davinci_mcasp_probe) from [<c03e71c4>] (platform_drv_probe+0x54/0xb8)
[ 14.376217] r10:00000000 r9:c08da600 r8:00000000 r7:fffffdfb r6:c097359c r5:ef225810
[ 14.384115] r4:c09b9a40
[ 14.386668] [<c03e7170>] (platform_drv_probe) from [<c03e574c>] (driver_probe_device+0x204/0x2f8)
[ 14.395574] r7:c097359c r6:00000000 r5:ef225810 r4:c09b9a40
[ 14.401289] [<c03e5548>] (driver_probe_device) from [<c03e58d4>] (__driver_attach+0x94/0x98)
[ 14.409759] r9:c08da600 r8:000000ab r7:00000000 r6:ef225844 r5:c097359c r4:ef225810
[ 14.417578] [<c03e5840>] (__driver_attach) from [<c03e39d4>] (bus_for_each_dev+0x70/0xa4)
[ 14.425786] r7:00000000 r6:c03e5840 r5:c097359c r4:00000000
[ 14.431501] [<c03e3964>] (bus_for_each_dev) from [<c03e5038>] (driver_attach+0x24/0x28)
[ 14.439534] r6:c095ded0 r5:eea6c000 r4:c097359c
[ 14.444195] [<c03e5014>] (driver_attach) from [<c03e4c74>] (bus_add_driver+0x1a8/0x220)
[ 14.452235] [<c03e4acc>] (bus_add_driver) from [<c03e6074>] (driver_register+0x80/0x100)
[ 14.460357] r7:eea6ae40 r6:c09336f0 r5:c090a298 r4:c097359c
[ 14.466072] [<c03e5ff4>] (driver_register) from [<c03e70ec>] (__platform_driver_register+0x48/0x50)
[ 14.475153] r5:c090a298 r4:c095ded0
[ 14.478762] [<c03e70a4>] (__platform_driver_register) from [<c090a2b4>] (davinci_mcasp_driver_init+0x1c/0x20)
[ 14.488715] r5:c090a298 r4:c09336f0
[ 14.492321] [<c090a298>] (davinci_mcasp_driver_init) from [<c000988c>] (do_one_initcall+0x98/0x1e4)
[ 14.501408] [<c00097f4>] (do_one_initcall) from [<c08daf40>] (kernel_init_freeable+0x1d4/0x268)
[ 14.510140] r10:00000007 r9:c08da600 r8:000000ab r7:c091a834 r6:c092893c r5:c097f000
[ 14.518038] r4:c097f000
[ 14.520590] [<c08dad6c>] (kernel_init_freeable) from [<c067e79c>] (kernel_init+0x18/0xf4)
[ 14.528799] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c067e784
[ 14.536699] r4:c097f000
[ 14.539251] [<c067e784>] (kernel_init) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
[ 14.546850] r5:c067e784 r4:00000000
[ 14.550452] ---[ end trace 5aba3efb8442f402 ]---
[ 14.555085] ------------[ cut here ]------------
[ 14.559723] WARNING: CPU: 0 PID: 1 at drivers/clk/clk.c:680 clk_core_disable+0x68/0x6c()
[ 14.567844] Modules linked in:
[ 14.570916] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.4.84-00027-g018eb62-dirty #3
[ 14.579910] Hardware name: Generic DRA72X (Flattened Device Tree)
[ 14.586023] Backtrace:
[ 14.588490] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
[ 14.596088] r7:c050f9b0 r6:20000093 r5:00000000 r4:c094d590
[ 14.601805] [<c0013d00>] (show_stack) from [<c02b39a8>] (dump_stack+0x8c/0xa0)
[ 14.609059] [<c02b391c>] (dump_stack) from [<c003581c>] (warn_slowpath_common+0x88/0xb8)
[ 14.617179] r7:c050f9b0 r6:000002a8 r5:00000009 r4:00000000
[ 14.622892] [<c0035794>] (warn_slowpath_common) from [<c00358f0>] (warn_slowpath_null+0x24/0x2c)
[ 14.631712] r8:00000000 r7:c093bc58 r6:c093c67c r5:80000093 r4:ef02ef00
[ 14.638482] [<c00358cc>] (warn_slowpath_null) from [<c050f9b0>] (clk_core_disable+0x68/0x6c)
[ 14.646958] [<c050f948>] (clk_core_disable) from [<c050fb34>] (clk_disable+0x2c/0x38)
[ 14.654817] r5:80000093 r4:ef1b0540
[ 14.658424] [<c050fb08>] (clk_disable) from [<c0024680>] (_disable_optional_clocks+0x34/0x44)
[ 14.666981] r5:00000001 r4:c093c710
[ 14.670586] [<c002464c>] (_disable_optional_clocks) from [<c002470c>] (_disable_clocks+0x7c/0x84)
[ 14.679493] r5:c093c6c8 r4:00000003
[ 14.683098] [<c0024690>] (_disable_clocks) from [<c002568c>] (_enable+0x218/0x2d8)
[ 14.690696] r7:c093bc58 r6:c097f5d8 r5:fffffff0 r4:c093c67c
[ 14.696412] [<c0025474>] (_enable) from [<c0025ecc>] (omap_hwmod_enable+0x2c/0x4c)
[ 14.704010] r7:c0027128 r6:a0000013 r5:c093c6dc r4:c093c67c
[ 14.709727] [<c0025ea0>] (omap_hwmod_enable) from [<c00270d8>] (omap_device_enable+0x48/0x98)
[ 14.718284] r7:c0027128 r6:ef224c40 r5:00000000 r4:00000001
[ 14.723997] [<c0027090>] (omap_device_enable) from [<c0027140>] (_od_runtime_resume+0x18/0x2c)
[ 14.732642] r7:c0027128 r6:c0027128 r5:ef225874 r4:ef225810
[ 14.738356] [<c0027128>] (_od_runtime_resume) from [<c03ee1f4>] (__rpm_callback+0x34/0x68)
[ 14.746652] r5:ef225874 r4:ef225810
[ 14.750257] [<c03ee1c0>] (__rpm_callback) from [<c03ee250>] (rpm_callback+0x28/0x88)
[ 14.758030] r7:c0027128 r6:ef1c1410 r5:ef225810 r4:ef225810
[ 14.763745] [<c03ee228>] (rpm_callback) from [<c03ef134>] (rpm_resume+0x374/0x56c)
[ 14.771342] r7:c0027128 r6:ef1c1410 r5:c0930100 r4:ef225810
[ 14.777056] [<c03eedc0>] (rpm_resume) from [<c03ef5e8>] (pm_runtime_forbid+0x58/0x64)
[ 14.784916] r10:00000000 r9:ef223300 r8:eea6c210 r7:ef225810 r6:ef225800 r5:ef225874
[ 14.792813] r4:ef225810
[ 14.795366] [<c03ef590>] (pm_runtime_forbid) from [<c0558340>] (davinci_mcasp_probe+0x580/0xb74)
[ 14.804185] r5:eea6c210 r4:eea6e210
[ 14.807792] [<c0557dc0>] (davinci_mcasp_probe) from [<c03e71c4>] (platform_drv_probe+0x54/0xb8)
[ 14.816524] r10:00000000 r9:c08da600 r8:00000000 r7:fffffdfb r6:c097359c r5:ef225810
[ 14.824421] r4:c09b9a40
[ 14.826975] [<c03e7170>] (platform_drv_probe) from [<c03e574c>] (driver_probe_device+0x204/0x2f8)
[ 14.835882] r7:c097359c r6:00000000 r5:ef225810 r4:c09b9a40
[ 14.841600] [<c03e5548>] (driver_probe_device) from [<c03e58d4>] (__driver_attach+0x94/0x98)
[ 14.850069] r9:c08da600 r8:000000ab r7:00000000 r6:ef225844 r5:c097359c r4:ef225810
[ 14.857888] [<c03e5840>] (__driver_attach) from [<c03e39d4>] (bus_for_each_dev+0x70/0xa4)
[ 14.866096] r7:00000000 r6:c03e5840 r5:c097359c r4:00000000
[ 14.871809] [<c03e3964>] (bus_for_each_dev) from [<c03e5038>] (driver_attach+0x24/0x28)
[ 14.879843] r6:c095ded0 r5:eea6c000 r4:c097359c
[ 14.884505] [<c03e5014>] (driver_attach) from [<c03e4c74>] (bus_add_driver+0x1a8/0x220)
[ 14.892545] [<c03e4acc>] (bus_add_driver) from [<c03e6074>] (driver_register+0x80/0x100)
[ 14.900667] r7:eea6ae40 r6:c09336f0 r5:c090a298 r4:c097359c
[ 14.906383] [<c03e5ff4>] (driver_register) from [<c03e70ec>] (__platform_driver_register+0x48/0x50)
[ 14.915463] r5:c090a298 r4:c095ded0
[ 14.919071] [<c03e70a4>] (__platform_driver_register) from [<c090a2b4>] (davinci_mcasp_driver_init+0x1c/0x20)
[ 14.929023] r5:c090a298 r4:c09336f0
[ 14.932628] [<c090a298>] (davinci_mcasp_driver_init) from [<c000988c>] (do_one_initcall+0x98/0x1e4)
[ 14.941716] [<c00097f4>] (do_one_initcall) from [<c08daf40>] (kernel_init_freeable+0x1d4/0x268)
[ 14.950447] r10:00000007 r9:c08da600 r8:000000ab r7:c091a834 r6:c092893c r5:c097f000
[ 14.958348] r4:c097f000
[ 14.960899] [<c08dad6c>] (kernel_init_freeable) from [<c067e79c>] (kernel_init+0x18/0xf4)
[ 14.969107] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c067e784
[ 14.977006] r4:c097f000
[ 14.979556] [<c067e784>] (kernel_init) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
[ 14.987155] r5:c067e784 r4:00000000
[ 14.990757] ---[ end trace 5aba3efb8442f403 ]---
[ 14.995391] omap_hwmod: mcasp2: _wait_target_ready failed: -16
[ 15.002548] ------------[ cut here ]------------
[ 15.007191] WARNING: CPU: 0 PID: 1 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x25c/0x368()
[ 15.016537] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Read): Data Access in User mode during Functional access
[ 15.028147] Modules linked in:
[ 15.031223] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.4.84-00027-g018eb62-dirty #3
[ 15.040217] Hardware name: Generic DRA72X (Flattened Device Tree)
[ 15.046332] Backtrace:
[ 15.048799] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
[ 15.056398] r7:c02e0130 r6:20000193 r5:00000000 r4:c094d590
[ 15.062116] [<c0013d00>] (show_stack) from [<c02b39a8>] (dump_stack+0x8c/0xa0)
[ 15.069370] [<c02b391c>] (dump_stack) from [<c003581c>] (warn_slowpath_common+0x88/0xb8)
[ 15.077492] r7:c02e0130 r6:00000093 r5:00000009 r4:ef08db00
[ 15.083205] [<c0035794>] (warn_slowpath_common) from [<c0035884>] (warn_slowpath_fmt+0x38/0x40)
[ 15.091937] r8:00000017 r7:c08419e0 r6:00000002 r5:c0841aa0 r4:c0841b44
[ 15.098709] [<c0035850>] (warn_slowpath_fmt) from [<c02e0130>] (l3_interrupt_handler+0x25c/0x368)
[ 15.107616] r3:ef1b8d80 r2:c0841b44
[ 15.111218] r4:80080003
[ 15.113773] [<c02dfed4>] (l3_interrupt_handler) from [<c0082048>] (handle_irq_event_percpu+0xb4/0x160)
[ 15.123115] r10:c097c7cb r9:ef1c3000 r8:00000017 r7:00000000 r6:00000000 r5:ef1c3060
[ 15.131014] r4:ef1c4280
[ 15.133568] [<c0081f94>] (handle_irq_event_percpu) from [<c0082134>] (handle_irq_event+0x40/0x64)
[ 15.142474] r10:00000000 r9:00000000 r8:ef006000 r7:00000000 r6:c0935c84 r5:ef1c3060
[ 15.150376] r4:ef1c3000
[ 15.152929] [<c00820f4>] (handle_irq_event) from [<c0085478>] (handle_fasteoi_irq+0xc0/0x194)
[ 15.161486] r7:00000000 r6:c0935c84 r5:ef1c3060 r4:ef1c3000
[ 15.167202] [<c00853b8>] (handle_fasteoi_irq) from [<c0081674>] (generic_handle_irq+0x2c/0x3c)
[ 15.175847] r7:00000000 r6:00000000 r5:00000017 r4:c092a40c
[ 15.181565] [<c0081648>] (generic_handle_irq) from [<c008194c>] (__handle_domain_irq+0x64/0xbc)
[ 15.190303] [<c00818e8>] (__handle_domain_irq) from [<c00094f0>] (gic_handle_irq+0x40/0x7c)
[ 15.198687] r9:00000000 r8:fa213000 r7:fa212000 r6:ef08dcc0 r5:fa21200c r4:c09308e4
[ 15.206504] [<c00094b0>] (gic_handle_irq) from [<c0014854>] (__irq_svc+0x54/0x90)
[ 15.214017] Exception stack(0xef08dcc0 to 0xef08dd08)
[ 15.219092] dcc0: ef225810 00000005 00000000 ef2258d8 ef225810 00000005 00000000 ef225810
[ 15.227306] dce0: 00000000 00000000 00000000 ef08dd2c ef08dd30 ef08dd10 c05587cc c03eed60
[ 15.235516] dd00: 20000013 ffffffff
[ 15.239016] r9:00000000 r8:00000000 r7:ef08dcf4 r6:ffffffff r5:20000013 r4:c03eed60
[ 15.246836] [<c03eed3c>] (__pm_runtime_idle) from [<c05587cc>] (davinci_mcasp_probe+0xa0c/0xb74)
[ 15.255656] r7:ef225810 r6:00000000 r5:eea6c210 r4:eea6e210
[ 15.261373] [<c0557dc0>] (davinci_mcasp_probe) from [<c03e71c4>] (platform_drv_probe+0x54/0xb8)
[ 15.270105] r10:00000000 r9:c08da600 r8:00000000 r7:fffffdfb r6:c097359c r5:ef225810
[ 15.278004] r4:c09b9a40
[ 15.280558] [<c03e7170>] (platform_drv_probe) from [<c03e574c>] (driver_probe_device+0x204/0x2f8)
[ 15.289465] r7:c097359c r6:00000000 r5:ef225810 r4:c09b9a40
[ 15.295182] [<c03e5548>] (driver_probe_device) from [<c03e58d4>] (__driver_attach+0x94/0x98)
[ 15.303651] r9:c08da600 r8:000000ab r7:00000000 r6:ef225844 r5:c097359c r4:ef225810
[ 15.311473] [<c03e5840>] (__driver_attach) from [<c03e39d4>] (bus_for_each_dev+0x70/0xa4)
[ 15.319682] r7:00000000 r6:c03e5840 r5:c097359c r4:00000000
[ 15.325398] [<c03e3964>] (bus_for_each_dev) from [<c03e5038>] (driver_attach+0x24/0x28)
[ 15.333432] r6:c095ded0 r5:eea6c000 r4:c097359c
[ 15.338094] [<c03e5014>] (driver_attach) from [<c03e4c74>] (bus_add_driver+0x1a8/0x220)
[ 15.346135] [<c03e4acc>] (bus_add_driver) from [<c03e6074>] (driver_register+0x80/0x100)
[ 15.354255] r7:eea6ae40 r6:c09336f0 r5:c090a298 r4:c097359c
[ 15.359972] [<c03e5ff4>] (driver_register) from [<c03e70ec>] (__platform_driver_register+0x48/0x50)
[ 15.369053] r5:c090a298 r4:c095ded0
[ 15.372661] [<c03e70a4>] (__platform_driver_register) from [<c090a2b4>] (davinci_mcasp_driver_init+0x1c/0x20)
[ 15.382614] r5:c090a298 r4:c09336f0
[ 15.386219] [<c090a298>] (davinci_mcasp_driver_init) from [<c000988c>] (do_one_initcall+0x98/0x1e4)
[ 15.395306] [<c00097f4>] (do_one_initcall) from [<c08daf40>] (kernel_init_freeable+0x1d4/0x268)
[ 15.404038] r10:00000007 r9:c08da600 r8:000000ab r7:c091a834 r6:c092893c r5:c097f000
[ 15.411939] r4:c097f000
[ 15.414491] [<c08dad6c>] (kernel_init_freeable) from [<c067e79c>] (kernel_init+0x18/0xf4)
[ 15.422700] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c067e784
[ 15.430601] r4:c097f000
[ 15.433152] [<c067e784>] (kernel_init) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
[ 15.440751] r5:c067e784 r4:00000000
[ 15.444352] ---[ end trace 5aba3efb8442f404 ]---
[ 15.449041] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[ 15.455113] Unhandled fault: imprecise external abort (0x1406) at 0x00000000
[ 15.462191] pgd = c0004000
[ 15.464906] [00000000] *pgd=00000000
[ 15.468504] Internal error: : 1406 [#1] PREEMPT SMP ARM
[ 15.473748] Modules linked in:
[ 15.476821] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.4.84-00027-g018eb62-dirty #3
[ 15.485815] Hardware name: Generic DRA72X (Flattened Device Tree)
[ 15.491932] task: ef088000 ti: ef08c000 task.ti: ef08c000
[ 15.497352] PC is at __pm_runtime_idle+0x24/0x84
[ 15.501989] LR is at davinci_mcasp_probe+0xa0c/0xb74
[ 15.506974] pc : [<c03eed60>] lr : [<c05587cc>] psr: 20000013
[ 15.506974] sp : ef08dd10 ip : ef08dd30 fp : ef08dd2c
[ 15.518499] r10: 00000000 r9 : 00000000 r8 : 00000000
[ 15.523743] r7 : ef225810 r6 : 00000000 r5 : 00000005 r4 : ef225810
[ 15.530296] r3 : ef2258d8 r2 : 00000000 r1 : 00000005 r0 : ef225810
[ 15.536850] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
[ 15.544014] Control: 10c5387d Table: 8000406a DAC: 00000051
[ 15.549782] Process swapper/0 (pid: 1, stack limit = 0xef08c210)
[ 15.555811] Stack: (0xef08dd10 to 0xef08e000)
[ 15.560186] dd00: eea6e210 eea6c210 00000000 ef225810
[ 15.568399] dd20: ef08ddc4 ef08dd30 c05587cc c03eed48 ef08dd50 c0183d3c c0884920 c0884910
[ 15.576612] dd40: 00000001 00000000 ef08dd6c 00000008 ef65df4c 00000002 00000082 00000001
[ 15.584826] dd60: ef08dd8c eea6b500 00000000 eea6b5a0 ef226c80 c084f0e0 00000001 00000000
[ 15.593039] dd80: ef08ddb4 ef08dd90 c0186530 c0182cfc ef225810 00000000 ef225818 c09b9a40
[ 15.601252] dda0: ef225810 c097359c fffffdfb 00000000 c08da600 00000000 ef08dde4 ef08ddc8
[ 15.609464] ddc0: c03e71c4 c0557dcc c09b9a40 ef225810 00000000 c097359c ef08de0c ef08dde8
[ 15.617678] dde0: c03e574c c03e717c ef225810 c097359c ef225844 00000000 000000ab c08da600
[ 15.625891] de00: ef08de2c ef08de10 c03e58d4 c03e5554 00000000 c097359c c03e5840 00000000
[ 15.634105] de20: ef08de54 ef08de30 c03e39d4 c03e584c ef05905c ef2233b4 ef059070 c097359c
[ 15.642317] de40: eea6c000 c095ded0 ef08de64 ef08de58 c03e5038 c03e3970 ef08de8c ef08de68
[ 15.650531] de60: c03e4c74 c03e5020 c088c4b0 ef08de78 c097359c c090a298 c09336f0 eea6ae40
[ 15.658743] de80: ef08dea4 ef08de90 c03e6074 c03e4ad8 c095ded0 c090a298 ef08debc ef08dea8
[ 15.666955] dea0: c03e70ec c03e6000 c09336f0 c090a298 ef08decc ef08dec0 c090a2b4 c03e70b0
[ 15.675168] dec0: ef08df4c ef08ded0 c000988c c090a2a4 ef08def4 ef08dee0 c0050b18 c02ba7f0
[ 15.683382] dee0: ef657d00 c06a4dbc ef08df4c ef08def8 c0050e28 c08da60c ef08df34 c081d290
[ 15.691594] df00: c081d2dc c081cc84 00000006 00000006 00000000 c08d6d7c c086b358 00000000
[ 15.699807] df20: 00000478 c097f000 c097f000 c092893c c091a834 000000ab c08da600 00000007
[ 15.708020] df40: ef08df94 ef08df50 c08daf40 c0009800 00000006 00000006 00000000 c08da600
[ 15.716233] df60: ffffffff c08d6d7c ffffffff c097f000 c067e784 00000000 00000000 00000000
[ 15.724446] df80: 00000000 00000000 ef08dfac ef08df98 c067e79c c08dad78 00000000 c067e784
[ 15.732659] dfa0: 00000000 ef08dfb0 c000fd18 c067e790 00000000 00000000 00000000 00000000
[ 15.740872] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 15.749084] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 ffffffff ffffffff
[ 15.757291] Backtrace:
[ 15.759757] [<c03eed3c>] (__pm_runtime_idle) from [<c05587cc>] (davinci_mcasp_probe+0xa0c/0xb74)
[ 15.768577] r7:ef225810 r6:00000000 r5:eea6c210 r4:eea6e210
[ 15.774293] [<c0557dc0>] (davinci_mcasp_probe) from [<c03e71c4>] (platform_drv_probe+0x54/0xb8)
[ 15.783026] r10:00000000 r9:c08da600 r8:00000000 r7:fffffdfb r6:c097359c r5:ef225810
[ 15.790926] r4:c09b9a40
[ 15.793479] [<c03e7170>] (platform_drv_probe) from [<c03e574c>] (driver_probe_device+0x204/0x2f8)
[ 15.802386] r7:c097359c r6:00000000 r5:ef225810 r4:c09b9a40
[ 15.808102] [<c03e5548>] (driver_probe_device) from [<c03e58d4>] (__driver_attach+0x94/0x98)
[ 15.816572] r9:c08da600 r8:000000ab r7:00000000 r6:ef225844 r5:c097359c r4:ef225810
[ 15.824391] [<c03e5840>] (__driver_attach) from [<c03e39d4>] (bus_for_each_dev+0x70/0xa4)
[ 15.832600] r7:00000000 r6:c03e5840 r5:c097359c r4:00000000
[ 15.838315] [<c03e3964>] (bus_for_each_dev) from [<c03e5038>] (driver_attach+0x24/0x28)
[ 15.846349] r6:c095ded0 r5:eea6c000 r4:c097359c
[ 15.851011] [<c03e5014>] (driver_attach) from [<c03e4c74>] (bus_add_driver+0x1a8/0x220)
[ 15.859052] [<c03e4acc>] (bus_add_driver) from [<c03e6074>] (driver_register+0x80/0x100)
[ 15.867174] r7:eea6ae40 r6:c09336f0 r5:c090a298 r4:c097359c
[ 15.872890] [<c03e5ff4>] (driver_register) from [<c03e70ec>] (__platform_driver_register+0x48/0x50)
[ 15.881971] r5:c090a298 r4:c095ded0
[ 15.885578] [<c03e70a4>] (__platform_driver_register) from [<c090a2b4>] (davinci_mcasp_driver_init+0x1c/0x20)
[ 15.895531] r5:c090a298 r4:c09336f0
[ 15.899138] [<c090a298>] (davinci_mcasp_driver_init) from [<c000988c>] (do_one_initcall+0x98/0x1e4)
[ 15.908224] [<c00097f4>] (do_one_initcall) from [<c08daf40>] (kernel_init_freeable+0x1d4/0x268)
[ 15.916956] r10:00000007 r9:c08da600 r8:000000ab r7:c091a834 r6:c092893c r5:c097f000
[ 15.924854] r4:c097f000
[ 15.927405] [<c08dad6c>] (kernel_init_freeable) from [<c067e79c>] (kernel_init+0x18/0xf4)
[ 15.935613] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c067e784
[ 15.943512] r4:c097f000
[ 15.946063] [<c067e784>] (kernel_init) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
[ 15.953661] r5:c067e784 r4:00000000
[ 15.957266] Code: e1a04000 0a00000a f57ff05b e28030c8 (f593f000)
[ 15.963386] ---[ end trace 5aba3efb8442f405 ]---
[ 15.969290] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 15.969290]
[ 15.978467] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 15.978467]
