Tool/software: Linux
Hello:
Checked with this post https://e2e.ti.com/support/arm/sitara_arm/f/791/t/604490
root@dra7xx-evm:~# ./dso_dataset files=images.zip gamma=pcalib.txt vignette=vignette.png preset=0 mode=0
loading data from images.zip!
loading gammaCalib from pcalib.txt!
loading vignette from vignette.png!
=============== PRESET Settings: ===============
DEFAULT settings:
- no real-time enforcing
- 2000 active points
- 5-7 active frames
- 1-6 LM iteration each KF
- original image resolution
PHOTOMETRIC MODE WITH CALIBRATION!
ERROR 4 reading archive images.zip!
CMEM Error: registerAlloc: ioctl CMEM_IOCREGUSER failed for phys addr 0xa9000000: -1
TIOCL FATAL: The TI Multicore Tools daemon (/usr/bin/ti-mctd) is not running. Re-run application after starting the daemon. Refer User Guide for details.
Aborted (core dumped)
root@dra7xx-evm:~#
root@dra7xx-evm:~# /usr/bin/ti-mctd
ti-mctd: /jenkins/psdkla-krogoth/release/dra7xx/yocto/tisdk/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl/1.1.12.0-r0.0/git/host/mct-daemon/cmem_allocator.h:80: CmemAllocator::CmemAllocator(): Assertion `ddr_alloc_dsp_addr_ == ddr_addr' failed.
root@dra7xx-evm:~#
- buildc onfiguration is MAKECONFIG?=tda2px_evm_linux_all
- run 'vecadd"
root@dra7xx-evm:/usr/share/ti/examples/opencl/vecadd# ./vecadd
- cmem info
root@dra7xx-evm:/usr/share/ti/examples/opencl/vecadd# cat /proc/cmem
Block 0: Pool 0: 4 bufs size 0x7e9000 (0x7e9000 requested)
Pool 0 busy bufs:
Pool 0 free bufs:
id 0: phys addr 0xaa7bb000
id 1: phys addr 0xa9fd2000
id 2: phys addr 0xa97e9000
