Hi TIDL experts,
I am using TIDL.01.01.01.00 , and i found some layers give mismatching result.
on the caffe-jacinto , the inference result is proper.
My model have 6 heads and we know the first head is for smaller objects.
The import is okay, also the import output bin file is proper, but the small object is gone.
I put the imported files to OD use-case and initial frames have a lot of unexpected small boxs.
And after the initial frames , the mismatching is compensated by the quantization statistics.
But there is no small object on the output monitor.
I observe that the first head of the SSD model cause this mismatching result.
If i delete the first head, the result is matching.
This is cause by the deconvloution layer before the first head.
Below file is the model and the config.
I mark the issue layer inside the prototxt.
Please help me to solver this.
Thank you.
Eric Lai
