Hi TI Experts,
Please let me confirm the following question.
[Question]
Would you please provide the settings value for AM5728EVM that we can confirm them on Clock Tree Tool?
Best regards.
Kaka
Hi TI Experts,
[Question]
Best regards.
Kaka
I tested the omapconf tool on my AM57xx GP evm, indeed in the end of the log the tool shows:
omapconf: powerdm_deinit(): cpu not supported!!!
omapconf: clockdm_deinit(): cpu not supported!!!
This is displayed after every omapconf command (even omapconf read & omapconf set bit, omapconf clear bit, etc..). The messages at the end are probably because the soc is labeled as AM57xx in the kernel instead of DRA75x/DRA74x.
However the tool functions properly (it displays the required information). See the log from omapconf show dpll (file attached):
root@am57xx-evm:~# omapconf show dpll
OMAPCONF (rev v1.72 built Fri Jan 8 18:26:05 EST 2016)
HW Platform:
Generic DRA74X (Flattened Device Tree)
DRA75X ES1.1 GP Device (STANDARD performance (1.0GHz))
TPS659038 ES2.2
SW Build Details:
Build:
Version: _____ _____ _ _
Kernel:
Version: 4.1.13-g8dc6617
Author: x0155517@mms
Toolchain: gcc version 4.9.3 20150413 (prerelease) (Linaro GCC 4.9-2015.05)
Type: #1 SMP PREEMPT
Date: Fri Mar 11 16:38:41 EET 2016
| DPLL Configuration | DPLL_USB | DPLL_PCIE_REF |
| Status | Locked | Locked |
| Mode | Lock | Lock |
| Automatic Control | Auto LPST | Auto LPST |
| LPST = Low-Power STop | | |
| FRST = Fast-Relock STop | | |
| LPBP = Low-Power ByPass | | |
| FRBP = Fast-Relock ByPass | | |
| MNBP = MN ByPass | | |
| Sigma-Delta Divider | 4 | 4 |
| SELFREQDCO | 0 | 0 |
| Ref. Frequency (MHz) | 20.000 | 20.000 |
| M Multiplier Factor | 480 | 75 |
| N Divider Factor | 9 | 0 |
| Lock Frequency (MHz) | 960 | 1500 |
| CLKOUT Output | | |
| Status | Enabled | Gated |
| Clock Divider | 2 (x2) | 15 (x2) |
| Clock Speed (MHz) | 480 | 100 |
| CLK_DCO_LDO Output | | |
| Status | Enabled | N/A |
| Clock Speed (MHz) | 960 | |
| CLKOUTX2_M2_LDO Output | | |
| Status | N/A | Enabled |
| Clock Speed (MHz) | | 100 |
| DPLL Configuration | DPLL_MPU | DPLL_IVA | DPLL_CORE | DPLL_PER | DPLL_ABE |
| Status | Locked | Stopped | Locked | Locked | Stopped |
| Mode | Lock | Lock | Lock | Lock | LPBP |
| Automatic Control | Auto LPST | Auto LPST | Auto LPST | Auto LPST | Auto LPST |
| LPST = Low-Power STop | | | | | |
| FRST = Fast-Relock STop | | | | | |
| LPBP = Low-Power ByPass | | | | | |
| FRBP = Fast-Relock ByPass | | | | | |
| MNBP = MN ByPass | | | | | |
| Low-Power Mode | Disabled | Disabled | Disabled | Disabled | Disabled |
| Automatic Recalibration | Disabled | Disabled | Disabled | Disabled | Disabled |
| Clock Ramping during Relock | Disabled | Disabled | Disabled | Disabled | Disabled |
| Ramping Rate (x REFCLK(s)) | 2 | 2 | 2 | 2 | 2 |
| Ramping Levels | No Ramp | No Ramp | No Ramp | No Ramp | No Ramp |
| Bypass Clock | CLKINPULOW | CLKINP | CLKINP | CLKINP | CLKINPULOW |
| Bypass Clock Divider | 1 | 1 | | | |
| REGM4XEN Mode | Disabled | Disabled | Disabled | Disabled | Disabled |
| Duty Cycle Correction (DCC) | Disabled | Disabled | Disabled | Disabled | Disabled |
| Ref. Frequency (MHz) | 20.000 | 20.000 | 20.000 | 20.000 | 20.000 |
| M Multiplier Factor | 50 | 266 | 266 | 96 | 0 |
| N Divider Factor | 0 | 4 | 4 | 4 | 0 |
| Lock Frequency (MHz) | 2000 | 2128 (2128) | 2128 | 768 | 0 (0) |
| M2 Output | | | | | |
| Status | Enabled | Gated | Gated | Gated | Gated |
| Clock Divider | 1 (x2) | 2 (x2) | 2 (x2) | 4 (x2) | 1 (x2) |
| Clock Speed (MHz) | 1000 | 0 (532) | 532 | 96 | 0 (0) |
| X2_M2 Output | | | | | |
| Status | | | | Enabled | Gated |
| Clock Divider | | | | 4 | 1 |
| Clock Speed (MHz) | | | | 192 | 0 (0) |
| X2_M3 Output | | | | | |
| Status | | Gated | Gated | Gated | Gated |
| Clock Divider | | 1 | 1 | 1 | 1 |
| Clock Speed (MHz) | | 0 (2128) | 2128 | 768 | 0 (0) |
| H11 Output | | | | | |
| Status | | | Gated | Gated | |
| Clock Divider | | | 1 | 3 | |
| Clock Speed (MHz) | | | 2128 | 256 | |
| H12 Output | | | | | |
| Status | | | Enabled | Enabled | |
| Clock Divider | | | 4 | 4 | |
| Clock Speed (MHz) | | | 532 | 192 | |
| H13 Output | | | | | |
| Status | | | Enabled | Gated | |
| Clock Divider | | | 62 | 4 | |
| Clock Speed (MHz) | | | 34 | 192 | |
| H14 Output | | | | | |
| Clock Divider | | | 5 | 2 | |
| Clock Speed (MHz) | | | 212 | 384 | |
| H21 Output | | | | | |
| Status | | | Gated | | |
| Clock Divider | | | 1 | | |
| Clock Speed (MHz) | | | 2128 | | |
| H22 Output | | | | | |
| Clock Divider | | | 5 | | |
| Clock Speed (MHz) | | | 425 | | |
| H23 Output | | | | | |
| Status | | | Enabled | | |
| Clock Divider | | | 4 | | |
| Clock Speed (MHz) | | | 532 | | |
| H24 Output | | | | | |
| Clock Divider | | | 6 | | |
| Clock Speed (MHz) | | | 354 | | |
| DPLL Configuration | DPLL_EVE | DPLL_DSP | DPLL_GMAC | DPLL_GPU | DPLL_DDR |
| Status | Stopped | Locked | Locked | Stopped | Locked |
| Mode | LPBP | Lock | Lock | LPBP | Lock |
| Bypass Clock | CLKINP | CLKINP | CLKINP | CLKINP | CLKINP |
| M Multiplier Factor | 0 | 75 | 250 | 0 | 266 |
| N Divider Factor | 0 | 1 | 4 | 0 | 4 |
| Lock Frequency (MHz) | 0 (0) | 1500 | 2000 | 0 (0) | 2128 |
| Status | Gated | Enabled | Enabled | Gated | Enabled |
| Clock Divider | 1 (x2) | 1 (x2) | 4 (x2) | 1 (x2) | 2 (x2) |
| Clock Speed (MHz) | 0 (0) | 750 | 250 | 0 (0) | 532 |
| Status | Gated | Gated | Gated | Gated | Gated |
| Clock Divider | 1 | 3 | 10 | 1 | 1 |
| Clock Speed (MHz) | 0 (0) | 500 | 200 | 0 (0) | 2128 |
| Status | | | Enabled | | Enabled |
| Clock Divider | | | 40 | | 8 |
| Clock Speed (MHz) | | | 50 | | 266 |
| Clock Divider | | | 8 | | |
| Clock Speed (MHz) | | | 250 | | |
| Clock Divider | | | 10 | | |
| Clock Speed (MHz) | | | 200 | | |
| Clock Speed (MHz) | | | 2000 | | |
root@am57xx-evm:~#
Yordan
