Tool/software: Linux
WARNING: ti-cg-xml-2_41_00-r0 do_fetch: Failed to fetch URL software-dl.ti.com/.../cg_xml-v2_41_00-Linux-x86-Install;name=cgxmlbin_linux, attempting MIRRORS if available
ERROR: ti-cg-xml-2_41_00-r0 do_fetch: Fetcher failure: Fetch command export PATH="/home/jack/openembedded/tisdk-am437x-v4.03/sources/oe-core/scripts:/home/jack/openembedded/tisdk-am437x-v4.03/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin/arm-linux-gnueabi:/home/jack/openembedded/tisdk-am437x-v4.03/build/arago-tmp-external-linaro-toolchain/sysroots/am57xx-evm/usr/bin/crossscripts:/home/jack/openembedded/tisdk-am437x-v4.03/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/sbin:/home/jack/openembedded/tisdk-am437x-v4.03/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin:/home/jack/openembedded/tisdk-am437x-v4.03/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/sbin:/home/jack/openembedded/tisdk-am437x-v4.03/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/bin:/home/jack/am437x/toolchain/gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf/bin:/home/jack/am437x/toolchain/gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf/bin:/home/jack/openembedded/tisdk-am437x-v4.03/sources/oe-core/scripts:/home/jack/openembedded/tisdk-am437x-v4.03/sources/meta-browser/scripts:/home/jack/openembedded/tisdk-am437x-v4.03/sources/meta-ros/scripts:/home/jack/openembedded/tisdk-am437x-v4.03/sources/bitbake/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/home/tenny/jdk1.8.0_161/bin:/home/tenny/jdk1.8.0_161/jre/bin"; export HOME="/home/jack"; /usr/bin/env wget -t 2 -T 30 -nv --passive-ftp --no-check-certificate -P /home/jack/openembedded/tisdk-am437x-v4.03/downloads 'software-dl.ti.com/.../cg_xml-v2_41_00-Linux-x86-Install' --progress=dot -v failed with exit code 8, output:
--2018-04-23 22:26:34-- software-dl.ti.com/.../cg_xml-v2_41_00-Linux-x86-Install
Resolving software-dl.ti.com (software-dl.ti.com)... 118.123.105.8, 118.123.105.19
Connecting to software-dl.ti.com (software-dl.ti.com)|118.123.105.8|:80... connected.
HTTP request sent, awaiting response... 302 Moved Temporarily
Location: www.ti.com/.../anonymousproddownload.tsp [following]
--2018-04-23 22:26:34-- www.ti.com/.../anonymousproddownload.tsp
Resolving www.ti.com (www.ti.com)... 183.61.92.241
Connecting to www.ti.com (www.ti.com)|183.61.92.241|:443... connected.
Location: software-dl.ti.com/.../cg_xml-v2_41_00-Linux-x86-Install [following]
HTTP request sent, awaiting response... 403 Forbidden
2018-04-23 22:26:34 ERROR 403: Forbidden
