Other Parts Discussed in Thread: TAS5805, , TAS5756M, TAS5731, TAS5727
Hi Team,
Do we have an alternative chip for tas5754m? I know TAS5805 is similar with TAS5754M but it is not p2p. Do you have any recommendation P2P chip for TAS5754?
BR
Gust
Hi Gust,
Off the top of my head we have TAS5756M that is pin to pin compatible. However TAS5756M uses BD modulation compared to TAS5754M's 1SPW. Not sure if that's ok for you.
Let us know if TAS5756M would be a good alternative. We will have to check to see if we have any other parts that are pin to pin compatible. I'm assuming you need pin 2 pin compatible since the board layout has already been completed?
Robert Clifton
Hi Robert,
Thanks for your reply. Yes, the board has been completed. One more question is that the alternative for TAS5731, do we have the alternative chip? P2P is better.
Gust
Hi Gust,
For TAS5731 p2p replacement take a look at TAS5727. I'm not sure if it will meet all of your requirements but it is p2p.
Is the TAS5756M a good alternative for TAS5754M in your application?
Robert Clifton
