Other Parts Discussed in Thread: NE5534
Hi,TI !
I want to convert the gradient data digital-to-analog.I used PCM1704 before, and I plan to use PCM1794 .
Can I use external filter mode when one path gradient data is fed into PCM1794.
When using the external filter mode for digital-to-analog conversion, two pairs of differential outputs are used simultaneously on the datasheet.
Is there any difference between the left channel differential output and the right channel differential output?Can we just use a pair of differential outputs like IOUTL– and IOUTL+?
Thanks for any help in this.
tq
