Other Parts Discussed in Thread: TPS7A39
Dear Ti Support Team,
I followed the original thread regarding applying Vbias oo noninverting inputs of Transimpedance Amplifier and would like to confirm this again.
I copied the original schematic provided on "Figure 3. Amplifiers Schematic (±10-V Power Supply)" of the sboa237 document for my new PCM1794A DAC based PCB design, except for the noninverting inputs of Transimpedance Amplifier being grounded as in original PCM1794A datasheet.
My question is, If I plan to supply the OPAMPs of both stage with ±12V or even a bit higher, then will I have to add any Vbias to the noninverting inputs of Transimpedance Amplifier in order to reduce the common mode voltage of the differential amp to nearly 0V?
Many thanks and best regards,
