PCM1690-Q1: About Thermal resistance
Guru 21045 points
Part Number: PCM1690-Q1
Other Parts Discussed in Thread: PCM1690,
Hi Team,
We would like to know the difference between Thermal resistance of PCM1690-Q1 and PCM1690(Non Q1).
I understand that ΘJA of PCM1690-Q1 is 23/W but I can’t find other parameters(RθJC(top),RθJB, ψJT, ψJB, RθJC(bot) ).
Could you please let us know the values of PCM1690-Q1?
<PCM1690-Q1 datasheet>
<PCM1690(Non Q1 datasheet)>
Hide
  • Hi Hide,
    Here are the thermal coefficients for the PCM1690-Q1:
    Paul
  • Hi Paul-san,
    Thank you for the information.
    I understand that PCM1690-Q1 and PCM1690(Non Q1) packages are the same so guess that thermal resistances are same.
    However, there is a little difference.
    We would like to know the reason.
    (For example, “Measurement error” etc.)
    I’d greatly appreciate your verification.
    Hide
  • The thermal coefficients were generated at separate times, so our thermal model may have been updated.  In addition, the devices technically have different DIE and maybe have different mold, die-attach, and bonding options, which can effect the coefficients as well.  The coefficients are dependent on more than just the package itself.
    Paul
  • Hi Paul-san,
    I greatly appreciate your cooperation.
    Hide
