I want to output I2S data to a speaker using TAS2505.
I made the settings with reference to SLAU472, but no sound is output.
When I dump the register, Page 1 / Register 45 is "0x00", and it seems that SPK output has not started.
Is this because the settings are wrong?
I will describe the format of the audio you want to output, the I2S input, and the register settings, so please let me know if there are any mistakes.
Audio format
Sampling rate: 48kHz
Bit frame: 16bit
Number of data slots: 2 slots (because it is monaural)
Port Input frequency
MCLK: 12.288 [MHz]
BCLK: 1.53 [MHz]
WCLK: 96 [kHz]
Register Settings
# Page switch to Page 0
w 30 00 00
#Assert Software reset (P0, R1, D0 = 1)
w 30 01 01
# Page Switch to Page 1
w 30 00 01
# LDO output programmed as 1.8V and Level shifters powered up. (P1, R2, D5-D4 = 00, D3 = 0)
w 30 02 00
w 30 00 00
#PLL_clkin = MCLK, codec_clkin = MCLK, MCLK (P0, R4, D1-D0 = 00)
w 30 04 00
# CLKOUT: DAC_MOD_CLK
w 30 19 05
# CLKOUT: ON
w 30 1A 81
#DAC NDAC Powered up, NDAC = 1 (P0, R11, D7 = 1, D6-D0 = 0000001)
w 30 0B 81
#DAC MDAC Powered up, MDAC = 2 (P0, R12, D7 = 1, D6-D0 = 0000010)
w 30 0C 82
#DAC OSR (9: 0)-> DOSR = 128 (P0, R12, D1-D0 = 00)
w 30 0D 00
#DAC OSR (9: 0)-> DOSR = 128 (P0, R13, D7-D0 = 10000000)
w 30 0E 80
#Codec Interface control Word length = 16bits, BCLK & WCLK inputs, I2S mode. (P0, R27, D7-D6 = 00, D5-D4 = 00, D3-D2 = 00)
w 30 1B 00
# Data slot offset 00 (P0, R28, D7-D0 = 0000)
w 30 1C 00
#Dac Instruction programming PRB # 2 for Mono routing. Type interpolation (x8) and 3 programmable Biquads. (P0, R60, D4-D0 = 0010)
w 30 3C 02
w 30 00 01
# Master Reference Powered on (P1, R1, D4 = 1)
w 30 01 10
# Output common mode for DAC set to 0.9V (default) (P1, R10)
w 30 0A 00
#DAC output is connected to HP Out Mixer (P1, R12, D2 = 1)
w 30 0C 00
#SPK attn. Gain = 0dB (P1, R46, D6-D0 = 000000)
w 30 2E 00
#SPK driver Gain = 6.0dB (P1, R48, D6-D4 = 001)
w 30 30 10
#SPK powered up (P1, R45, D1 = 1)
w 30 2D 02
w 30 00 00
# GPIO: CLKOUT
w 30 34 11
#DAC powered up, Soft step 1 per Fs. (P0, R63, D7 = 1, D5-D4 = 01, D3-D2 = 00, D1-D0 = 00)
w 30 3F 90
#DAC digital gain 0dB (P0, R65, D7-D0 = 00000000)
w 30 41 00
#DAC volume not muted. (P0, R64, D3 = 0, D2 = 1)
w 30 40 04
