Part Number: OPA1679-Q1
Other Parts Discussed in Thread: OPA1678, OPA1679, TINA-TI
The datasheet for OPA1678 specifies -V. I've looked hard through the OPA1679 datasheet but do not see a signal specified. I was curious to know if GND can be used instead or if that will create issues.
The circuits I plan to use these opamps in run between +/-12V and +/-18V. The ground planes have significantly better thermal conductivity than V-, which may or may not be on a separate signal layer.
Thank you for your time answering this possibly amateurish question. I'm trying to create a library for these parts in EAGLE so I'd like to get the pin assignments right on the part itself.
