I was comparing the TLV320AIC3254 and its automotive coutnerpart TLV320AIC3254-Q1 when I found a possible mistake in the datasheet:
In the pin functionality section of the TLV320AIC3254-Q1 it states that LDO_Select must be connected to DVss, however, that would permanently ground LDO_Select:
vs the TLV320AIC3254's pin functionality section:
That being said, I later checked the typical circuit application of the Q1, which shows LDO_Select being connected to IOVDD:
Putting this aside, from what I saw the parts have the same functionality, pinout and size and should be interchangeable, am I correct?
Yours Sincerely,
Simeon Aleksandrov
