We are using PCM5101APWR for our production ,we have following questions.
could you let me know your reply ASAP?
Is XSMT terminal related with RESET funcition? If yes, How is the related with RESET fucntion?
Though We thought XSMT terminal is related with MUTE function and it's no mentioned on datasheet.
「The best way to ensure a reset for the device would be set XSMT to GND
and then lower the AVDD/DVDD/CPVDD supply to as low a value as possible, ideally 0V, but likely <1.2V would suffice.」
Though you says the above for other customer,
Is only AVDD/DVDD/CPVDD supply to as low, <1.2V would suffice, not enough(without XSMT terminal) for this device reset?
How do we find RESET is completely worked?
And if RESET is not completely worked, do you think how is the possibility such as DAC no output?
Because we need your reply ASAP, please follow.
For sending the data which is confidential, please let me your mailing address.
