Hello Sir,
I want to control power of this audio amplifier.
Can you guide me if i want to use this amplifier for 4ohm speaker with 5W instead of 10W or 7W then how i can limit the power ?
Denish
Hello Sir,
Denish
Hi Denish
First of all, you can use the Gain Settings to set the Amplifier Gain of the device. Please refer to chapter 7.3.1 in the datasheet. After you chosen a fixed Gain, you can control the input signal to control the output level.
Hello Shadow,
Thanks for your inputs
So if i apply pull up resistor with 1.2V at power limit pin no 10 of chipset then i can set 5W power for 4ohm speaker right?
Correct me if i can wrong?
Waiting for your inputs.
