Hi
Customer to check different settings to achieve the highest level possible with the TPA3118D2, also asked us the evaluation process and if there is any standardized tool we could use to approve the recommended solution.
The tool or file could be a test program and/or audio file which we can try and measure the waveform as a final check.
It’ll help to know how TI tests/approves its amplifier solution so that our procedures are on the same baseline.
If you have such test file, is there any way we could do same test for Windows 10/Ubuntu environment?
