TLV320AIC3101: Recording and Playback enabled simultaneously
Part Number: TLV320AIC3101
Hi, I am using HPLout (L channel) for the speaker and MIC1RP/M (R channel) for the MIC, I have two questions, thank you for advice.
1. Can I enable Recording (process MIC signal to Dout) and Playback (process Din to Speaker) at the same time ?
2. Since I use L for Playback and R for Recording, can Playback use L channel "Effects" block and Recording use R channel "Effects" block
    if both Recording and Playback can be enabled at the same time (Question #1) ?  as in the image below ?
