PCM3168A: Default delay given by Audio Codec
Part Number: PCM3168A
I am using PCM3168APAP in my design. I am using 6 audio input and 4 audio outputs in my design. The clock frequency details are as below:
LRCK - 48kHz
SCLK - 3.072MHz
MCLK - 12.28MHz
Will the IC introduce any default delay between audio input and audio output. When the audio input signal is fed to the audio codec, will be audio output signal will be obtained after any certain delay instroduced by the IC
