Part Number: TAS5622A
Hi Team,
I measured about 32.5mA with no signal standby mode,
It is twice as large as the specification of 12mA, Is this normal please?
Hi Team,
Hi Kevin
Did you measure them at the same condition with datasheet?
could you share more detail how you perform the test?
BTW, I found that the circuit is a little different with our recommend circuit, they seem missing one 10uF capacitor be connected to GVDD.
It will better to add that and test again.
Jesse
Hi Jesse,
The measurement method is no load,
No signal to test IGVDD,
According to the suggestion, add a 10U capacitor test in the place close to VDD,
IGVDD_AB and IGVDD_CD have a decrease of 0.8mA,
IGVDD measurement is about 21.2mA,
What I want to confirm is that the datasheet indicates that IGVDDX is 12mA current,
But my current test is 21.2mA, is there any risk?
Hi Kevin
it should have no problem. 12mA is just a typical value.
can you inform me what kind of tester you use?
Jesse
Hi Kevin
Just for confirming the accuracy of measurement method.
I think your method is OK.
thanks.
Jesse
