TPA2011D1: Pop sound occurred when audio play ends.
Part Number: TPA2011D1
We repeat an audio file by media payer, Pop sound occurred when audio play ends.
How to fix it?
Thank you.
  • Hi Mark,
    What is your audio source? Is the input of TPA2011D1 connected to the analog output from a PC?
    Pop can be caused by impedance mismatch or current transients at the input, perhaps the PC is transitioning the analog output to Hi-Z such that there is a transient at the input of TPA2011D1.
    If there is a sleep signal or similar you may use that to control the EN pin on TPA2011D1.
    -Ivan Salazar
    Applications Engineer
