Hi
I need to play audio alerts from my board through 3.5mm jack to external speaker.
Is this device can do it?
How i will burn the files into device in production?
I need to play files from my MCU (NXP iMX8)
Thank you
Hi
Thank you
Here is an example of a path from MIC input to Speaker output. You can use other paths as well depend on your requirement.
Just a note only MIX-L is connected to Speaker.
We have Linux driver located here in the product folder.
https://www.ti.com/product/TLV320AIC3100
For unused MIC input, you can place a 0.47uF cap to gnd.
Regards.
OK, Those digital SAI will go to your host/MCU and MIC1 is analog input.
Regards.
Please refer to the schematic below for reference of the codec connection.
It looks like what you need is probably just a DAC with class D. You don't need a codec, here is the device link.
https://www.ti.com/product/TLV320DAC3100
The schematic is the same except without the analog inputs.
Regards.
