Other Parts Discussed in Thread: TAS2552
HI TI Team,
In one of our Consumer product we are planning to use Audio codec# TLV320AIC3256. Here we have the following queries to be resolved.
1) We require to drive a Mono Speaker with 3W, so it seems it will require an external 3W Audio amplifier. In order to interface an external audio amplifier can you confirm which output can be used?
We suspect using HPL and HPR, either in differential mode or single-ended mode. Is this correct understanding?
2) As per the datasheet it supports Digital PDM microphones, we are planning to use 2x PDM microphones. Please confirm that PDM 2x Mic is possible.
3) Can you please also suggest the best suitable audio amplifier considering an 8Ohm Mono speaker of 3W?
4) can you confirm the status is active and share if there is any near future EOL plan for this part.
Looking for your quick support on this.
