Other Parts Discussed in Thread: OPA810, OPA2810, BUF634A
hi team,
Please give some solution to replace competitor as attached
Hi Eric,
What is the customers application?
Brian
hi Brian,
the EE is UPS and it work as V&I sampling signal conditioning.
I will double confirm with customer whether the current device is over spec
Since this is not an audio application, it would be better to ask the question to the liner amps team.
Brian
Hi Eric,
I filtered some of the parameters from the ANX device in our OpAmp portfolio, perhaps OPA810 is an option?: https://www.ti.com/amplifier-circuit/op-amps/products.html#p22typ=70;8000&~p78=In;Out
I'm also reassigning this thread to a more relevant team for further support.
-Ivan Salazar
Applications Engineer
Hi Ivan,
OPA2810 seems like a good alternative to the competitor part. If high output current is required, you may need to add a BUF634A at the output in a composite loop, as described in the BUF datasheet.
What is the application? We might be able to suggest a better part based for their needs instead of just a comparison to a competitor part.
Sean
