Other Parts Discussed in Thread: TAS5825PEVM, TAS5825MEVM, TAS5825M
I have a PUREPATH-CMBEVM with TAS5825MEVM and a separate TAS5825PEVM board. I'd like to connect the two setups using an optical cable.
Ideally, the PUREPATH-CMBEVM with TAS5825MEVM setup should use USB as audio source, the digital audio looped back to the OPTO-OUT connector, from there an optical cable would connect to the OPTO-IN of the TAS5825PEVM board and be used as source.
Is this possible to set up?
