I could not find in the datasheet the timing associated with the enable pin, i.e., how long it takes for the device to be enabled and disabled with the assertion of the enable pin. I am not asking about the startup time, well described in the datasheet. I am asking after the TPA2011D1 is up and running and, upon command, had to be disabled and then enabled. Some other forum questions mention about a 30µs time to disable the device, in the discussions about pop sounds. Can you confirm that number? I also need the enabling time.
Thank you!
