How should I know what kind of the tuning tool I will be used with different device? Is it PPC1,PPC2 or PPC3?
Hi Jean,
You have to install PPC3, once that software is installed then you login using your same myTI credentials and you should be able to install the TAS2770 plugin within PPC3 itself.
Let us know if you face any trouble during the installation.
-Ivan Salazar
Applications Engineer
I see, I should follow the Installation guide. each of the device will give a advice that which app can be use. Am I right? (before this I didn't read the guide)
I already installed the PPC3, but I didn't see the TAS2700 tool. The PPC3 tool I just download yeasterday. It name is“ ppc3_platform_winInstaller.exe”.
In normally, I can see all the device APP in PPC3 tool when I installate the PPC3 ,then I can download what I want of the device ,am I right?
By the way, there have some irror during I install the PPC3 tool. After it can't download the data from Web, I ignored it.
After that progress, I installed the PPC3, the window that I can't update the TAS2770 APP in tool.
