PCM1681-Q1: Datasheet inquiry
Part Number: PCM1681-Q1
Hello team,
I'm wondering if FMT[0:3] has any difference between 0100 and 0110 when using I2S 24bit. Can you explain what is the difference?
Sam Lee
  • Hi Sam,
    Check the TDM diagram in Figure 24 in the datasheet. There is a "I2S mode" that shows how it differs from typical Left Justified TDM. The primary difference between the formats you highlighted is that 0100 will only support 2 channels per dataline. 0110 will support up to 4 or 8 channels depending on your BCLK/FSYNC ratio.
