Other Parts Discussed in Thread: TAS2764
Hi
How to check TAS2764 speaker resistance, open resistance, short resistance(load diagnosis mode)
I am using TAS2764 EVM
I am reading the values of LDG_RES1~4, but it is difficult to distinguish the resistance value when connecting an open, short, or speaker.
What value should be read in case of open, short, speaker (8 ohm)
When diagnosing the load, the settings are as follows.
page 0
0x02(MODE_CTRL) : ISNS_PD active, VSNS_PD active, MODE: 100(standard diagnostics)
0x19(DG_0) : DG_CLK internal or external, DG_SIG 0E(programmable DC)
0x04(DC_BLK0) : HPF_FREQ_PB disable
0x05(DC_BLK1) : HPF_FREQ_REC disable
0x65 (MISC_CFG4): LDG_CLK is changed to 0 or 1, LDG_IVSNS_AVG is changed from 2ms to 50ms
page4
DG_DC_VAL1~4 : 40 26 40 00 (idle value)
I set LDG_RES_LT to 200ohm and LDG_RES_UT to 1900ohm.
When reading the value, write 100b to the register of MODE (2:0) at address 0x02 (Standalone Load Diagnostic, after completion these bits are self reset to 010b), and read 0x4a~0x4d of page 4.
Repeat the above process several times.
When the value is read and converted to a resistance value, it comes out randomly between 200 ohm and 2100 ohm
I'd appreciate it if you could point out something wrong
