Hi team,
PVDD capacitance is 220uF in recommended application circuit for 45W 2ohm.
In my use case output is only 10W/2ohm 2channel.
In that case, is how much I can reduce the PVDD capacitance?
I would like to use as high as 44uF.
Could you also advise which parameter or condition should I evaluate to find the minimum PVDD capacitance?
regards,
