Part Number: PCM1864-Q1
Hi team,
Would you please answer the following question?
Regarding Antialiasing filter, the datasheet recommends 100ohm/0.01uF for single-ended and 47ohm/0.01uF for differential. This is about fc=160kHz. When considering audio bandwidth 20 ~ 20kHz, the fc=160kHz looks high. If fc is lowered, the SNR expected to be better, isn’t it? Can you explain why you set it higher?
Sam Lee
