PCM5142EVM-U: No I2S output with USB input
Part Number: PCM5142EVM-U
Other Parts Discussed in Thread: SRC4392, PCM5141, PCM5142
Hi team,
I am testing PCM5142EVM-U for customer. I used USB input because I don't have SPDIF source in our lab.
I configured EVM based on this thread: https://e2e.ti.com/support/audio-group/audio/f/audio-forum/399753/split-pcm5141-96k-not-working?tisearch=e2e-sitesearch&keymatch=PCM5141%2096K#
And I used Audacity as audio source. Headers are placed as below:
When I play an audio signal(1kHz Tone), I can't get SDIN signal(BCLK and WCLK were normal) in the output of TAS1020B and no signal on the SRC4392 I2S output.
If the configuration don't support USB input? Any other possibilities?
BRs
Kian
BRs
Kian
  • Hi Kian,
    I tested the EVM in 2 different methods :
    With  optical cable ( with AP)  and then with USB with Audacity as you wanted.
    In both cases i can see the output and Din as well as BCLK and LRCLK clocks.
    Just follow the diagram on the GUI for the jumpers, then load the following script (PCM5141_SRC_96k) and click EXECUTE .
    you should see the output coming up on the scope along with  all clks and Din.
    I also created  the register dump for you, in case you want to check it against your file.
     PCM5142_SRC_96kHz.cfg
    PCM5141USB_register Dump.txt
    Executing Command...
    Executing Finished
    Memory Dump Started...
    # Page 0x00
    w E0 00 00
    w E0 01 00
    w E0 02 00
    w E0 03 00
    w E0 04 00
    w E0 05 00
    w E0 06 00
    w E0 07 00
    w E0 08 00
    w E0 09 00
    w E0 0A 00
    w E0 0B 00
    w E0 0C 00
    w E0 0D 00
    w E0 0E 00
    w E0 0F 00
    w E0 10 00
    w E0 11 00
    w E0 12 00
    w E0 13 00
    w E0 14 00
    w E0 15 00
    w E0 16 00
    w E0 17 00
    w E0 18 00
    w E0 19 00
    w E0 1A 00
    w E0 1B 00
    w E0 1C 00
    w E0 1D 00
    w E0 1E 00
    w E0 1F 00
    w E0 20 00
    w E0 21 00
    w E0 22 00
    w E0 23 00
    w E0 24 00
    w E0 25 00
    w E0 26 00
    w E0 27 00
    w E0 28 00
    w E0 29 00
    w E0 2A 00
    w E0 2B 00
    w E0 2C 00
    w E0 2D 00
    w E0 2E 00
    w E0 2F 00
    w E0 30 00
    w E0 31 00
    w E0 32 00
    w E0 33 00
    w E0 34 00
    w E0 35 00
    w E0 36 00
    w E0 37 00
    w E0 38 00
    w E0 39 00
    w E0 3A 00
    w E0 3B 00
    w E0 3C 00
    w E0 3D 00
    w E0 3E 00
    w E0 3F 00
    w E0 40 FF
    w E0 41 FF
    w E0 42 FF
    w E0 43 FF
    w E0 44 FF
    w E0 45 FF
    w E0 46 FF
    w E0 47 FF
    w E0 48 FF
    w E0 49 FF
    w E0 4A FF
    w E0 4B FF
    w E0 4C FF
    w E0 4D FF
    w E0 4E FF
    w E0 4F FF
    w E0 50 FF
    w E0 51 FF
    w E0 52 FF
    w E0 53 FF
    w E0 54 FF
    w E0 55 FF
    w E0 56 FF
    w E0 57 FF
    w E0 58 FF
    w E0 59 FF
    w E0 5A FF
    w E0 5B FF
    w E0 5C FF
    w E0 5D FF
    w E0 5E FF
    w E0 5F FF
    w E0 60 FF
    w E0 61 FF
    w E0 62 FF
    w E0 63 FF
    w E0 64 FF
    w E0 65 FF
    w E0 66 FF
    w E0 67 FF
    w E0 68 FF
    w E0 69 FF
    w E0 6A FF
    w E0 6B FF
    w E0 6C FF
    w E0 6D FF
    w E0 6E FF
    w E0 6F FF
    w E0 70 FF
    w E0 71 FF
    w E0 72 FF
    w E0 73 FF
    w E0 74 FF
    w E0 75 FF
    w E0 76 FF
    w E0 77 FF
    w E0 78 FF
    w E0 79 FF
    w E0 7A FF
    w E0 7B FF
    w E0 7C FF
    w E0 7D FF
    w E0 7E FF
    w E0 7F 00
    # Page 0x01
    w E0 00 01
    w E0 01 00
    w E0 02 00
    w E0 03 00
    w E0 04 00
    w E0 05 00
    w E0 06 00
    w E0 07 00
    w E0 08 00
    w E0 09 00
    w E0 0A 00
    w E0 0B 00
    w E0 0C 00
    w E0 0D 00
    w E0 0E 00
    w E0 0F 00
    w E0 10 00
    w E0 11 00
    w E0 12 00
    w E0 13 00
    w E0 14 00
    w E0 15 00
    w E0 16 00
    w E0 17 00
    w E0 18 00
    w E0 19 00
    w E0 1A 00
    w E0 1B 00
    w E0 1C 00
    w E0 1D 00
    w E0 1E 00
    w E0 1F 00
    w E0 20 00
    w E0 21 00
    w E0 22 00
    w E0 23 00
    w E0 24 00
    w E0 25 00
    w E0 26 00
    w E0 27 00
    w E0 28 00
    w E0 29 00
    w E0 2A 00
    w E0 2B 00
    w E0 2C 00
    w E0 2D 00
    w E0 2E 00
    w E0 2F 00
    w E0 30 00
    w E0 31 00
    w E0 32 00
    w E0 33 00
    w E0 34 00
    w E0 35 00
    w E0 36 00
    w E0 37 00
    w E0 38 00
    w E0 39 00
    w E0 3A 00
    w E0 3B 00
    w E0 3C 00
    w E0 3D 00
    w E0 3E 00
    w E0 3F 00
    w E0 40 FF
    w E0 41 FF
    w E0 42 FF
    w E0 43 FF
    w E0 44 FF
    w E0 45 FF
    w E0 46 FF
    w E0 47 FF
    w E0 48 FF
    w E0 49 FF
    w E0 4A FF
    w E0 4B FF
    w E0 4C FF
    w E0 4D FF
    w E0 4E FF
    w E0 4F FF
    w E0 50 FF
    w E0 51 FF
    w E0 52 FF
    w E0 53 FF
    w E0 54 FF
    w E0 55 FF
    w E0 56 FF
    w E0 57 FF
    w E0 58 FF
    w E0 59 FF
    w E0 5A FF
    w E0 5B FF
    w E0 5C FF
    w E0 5D FF
    w E0 5E FF
    w E0 5F FF
    w E0 60 FF
    w E0 61 FF
    w E0 62 FF
    w E0 63 FF
    w E0 64 FF
    w E0 65 FF
    w E0 66 FF
    w E0 67 FF
    w E0 68 FF
    w E0 69 FF
    w E0 6A FF
    w E0 6B FF
    w E0 6C FF
    w E0 6D FF
    w E0 6E FF
    w E0 6F FF
    w E0 70 FF
    w E0 71 FF
    w E0 72 FF
    w E0 73 FF
    w E0 74 FF
    w E0 75 FF
    w E0 76 FF
    w E0 77 FF
    w E0 78 FF
    w E0 79 FF
    w E0 7A FF
    w E0 7B FF
    w E0 7C FF
    w E0 7D FF
    w E0 7E FF
    w E0 7F 00
    # Page 0x2c
    w E0 00 2C
    w E0 01 00
    w E0 02 00
    w E0 03 00
    w E0 04 00
    w E0 05 00
    w E0 06 00
    w E0 07 00
    w E0 08 00
    w E0 09 00
    w E0 0A 00
    w E0 0B 00
    w E0 0C 00
    w E0 0D 00
    w E0 0E 00
    w E0 0F 00
    w E0 10 00
    w E0 11 00
    w E0 12 00
    w E0 13 00
    w E0 14 00
    w E0 15 00
    w E0 16 00
    w E0 17 00
    w E0 18 00
    w E0 19 00
    w E0 1A 00
    w E0 1B 00
    w E0 1C 00
    w E0 1D 00
    w E0 1E 00
    w E0 1F 00
    w E0 20 00
    w E0 21 00
    w E0 22 00
    w E0 23 00
    w E0 24 00
    w E0 25 00
    w E0 26 00
    w E0 27 00
    w E0 28 00
    w E0 29 00
    w E0 2A 00
    w E0 2B 00
    w E0 2C 00
    w E0 2D 00
    w E0 2E 00
    w E0 2F 00
    w E0 30 00
    w E0 31 00
    w E0 32 00
    w E0 33 00
    w E0 34 00
    w E0 35 00
    w E0 36 00
    w E0 37 00
    w E0 38 00
    w E0 39 00
    w E0 3A 00
    w E0 3B 00
    w E0 3C 00
    w E0 3D 00
    w E0 3E 00
    w E0 3F 00
    w E0 40 FF
    w E0 41 FF
    w E0 42 FF
    w E0 43 FF
    w E0 44 FF
    w E0 45 FF
    w E0 46 FF
    w E0 47 FF
    w E0 48 FF
    w E0 49 FF
    w E0 4A FF
    w E0 4B FF
    w E0 4C FF
    w E0 4D FF
    w E0 4E FF
    w E0 4F FF
    w E0 50 FF
    w E0 51 FF
    w E0 52 FF
    w E0 53 FF
    w E0 54 FF
    w E0 55 FF
    w E0 56 FF
    w E0 57 FF
    w E0 58 FF
    w E0 59 FF
    w E0 5A FF
    w E0 5B FF
    w E0 5C FF
    w E0 5D FF
    w E0 5E FF
    w E0 5F FF
    w E0 60 FF
    w E0 61 FF
    w E0 62 FF
    w E0 63 FF
    w E0 64 FF
    w E0 65 FF
    w E0 66 FF
    w E0 67 FF
    w E0 68 FF
    w E0 69 FF
    w E0 6A FF
    w E0 6B FF
    w E0 6C FF
    w E0 6D FF
    w E0 6E FF
    w E0 6F FF
    w E0 70 FF
    w E0 71 FF
    w E0 72 FF
    w E0 73 FF
    w E0 74 FF
    w E0 75 FF
    w E0 76 FF
    w E0 77 FF
    w E0 78 FF
    w E0 79 FF
    w E0 7A FF
    w E0 7B FF
    w E0 7C FF
    w E0 7D FF
    w E0 7E FF
    w E0 7F 00
    # Page 0x2d
    w E0 00 2D
    w E0 01 00
    w E0 02 00
    w E0 03 00
    w E0 04 00
    w E0 05 00
    w E0 06 00
    w E0 07 00
    w E0 08 00
    w E0 09 00
    w E0 0A 00
    w E0 0B 00
    w E0 0C 00
    w E0 0D 00
    w E0 0E 00
    w E0 0F 00
    w E0 10 00
    w E0 11 00
    w E0 12 00
    w E0 13 00
    w E0 14 00
    w E0 15 00
    w E0 16 00
    w E0 17 00
    w E0 18 00
    w E0 19 00
    w E0 1A 00
    w E0 1B 00
    w E0 1C 00
    w E0 1D 00
    w E0 1E 00
    w E0 1F 00
    w E0 20 00
    w E0 21 00
    w E0 22 00
    w E0 23 00
    w E0 24 00
    w E0 25 00
    w E0 26 00
    w E0 27 00
    w E0 28 00
    w E0 29 00
    w E0 2A 00
    w E0 2B 00
    w E0 2C 00
    w E0 2D 00
    w E0 2E 00
    w E0 2F 00
    w E0 30 00
    w E0 31 00
    w E0 32 00
    w E0 33 00
    w E0 34 00
    w E0 35 00
    w E0 36 00
    w E0 37 00
    w E0 38 00
    w E0 39 00
    w E0 3A 00
    w E0 3B 00
    w E0 3C 00
    w E0 3D 00
    w E0 3E 00
    w E0 3F 00
    w E0 40 FF
    w E0 41 FF
    w E0 42 FF
    w E0 43 FF
    w E0 44 FF
    w E0 45 FF
    w E0 46 FF
    w E0 47 FF
    w E0 48 FF
    w E0 49 FF
    w E0 4A FF
    w E0 4B FF
    w E0 4C FF
    w E0 4D FF
    w E0 4E FF
    w E0 4F FF
    w E0 50 FF
    w E0 51 FF
    w E0 52 FF
    w E0 53 FF
    w E0 54 FF
    w E0 55 FF
    w E0 56 FF
    w E0 57 FF
    w E0 58 FF
    w E0 59 FF
    w E0 5A FF
    w E0 5B FF
    w E0 5C FF
    w E0 5D FF
    w E0 5E FF
    w E0 5F FF
    w E0 60 FF
    w E0 61 FF
    w E0 62 FF
    w E0 63 FF
    w E0 64 FF
    w E0 65 FF
    w E0 66 FF
    w E0 67 FF
    w E0 68 FF
    w E0 69 FF
    w E0 6A FF
    w E0 6B FF
    w E0 6C FF
    w E0 6D FF
    w E0 6E FF
    w E0 6F FF
    w E0 70 FF
    w E0 71 FF
    w E0 72 FF
    w E0 73 FF
    w E0 74 FF
    w E0 75 FF
    w E0 76 FF
    w E0 77 FF
    w E0 78 FF
    w E0 79 FF
    w E0 7A FF
    w E0 7B FF
    w E0 7C FF
    w E0 7D FF
    w E0 7E FF
    w E0 7F 00
    # Page 0x2e
    w E0 00 2E
    w E0 01 00
    w E0 02 00
    w E0 03 00
    w E0 04 00
    w E0 05 00
    w E0 06 00
    w E0 07 00
    w E0 08 00
    w E0 09 00
    w E0 0A 00
    w E0 0B 00
    w E0 0C 00
    w E0 0D 00
    w E0 0E 00
    w E0 0F 00
    w E0 10 00
    w E0 11 00
    w E0 12 00
    w E0 13 00
    w E0 14 00
    w E0 15 00
    w E0 16 00
    w E0 17 00
    w E0 18 00
    w E0 19 00
    w E0 1A 00
    w E0 1B 00
    w E0 1C 00
    w E0 1D 00
    w E0 1E 00
    w E0 1F 00
    w E0 20 00
    w E0 21 00
    w E0 22 00
    w E0 23 00
    w E0 24 00
    w E0 25 00
    w E0 26 00
    w E0 27 00
    w E0 28 00
    w E0 29 00
    w E0 2A 00
    w E0 2B 00
    w E0 2C 00
    w E0 2D 00
    w E0 2E 00
    w E0 2F 00
    w E0 30 00
    w E0 31 00
    w E0 32 00
    w E0 33 00
    w E0 34 00
    w E0 35 00
    w E0 36 00
    w E0 37 00
    w E0 38 00
    w E0 39 00
    w E0 3A 00
    w E0 3B 00
    w E0 3C 00
    w E0 3D 00
    w E0 3E 00
    w E0 3F 00
    w E0 40 FF
    w E0 41 FF
    w E0 42 FF
    w E0 43 FF
    w E0 44 FF
    w E0 45 FF
    w E0 46 FF
    w E0 47 FF
    w E0 48 FF
    w E0 49 FF
    w E0 4A FF
    w E0 4B FF
    w E0 4C FF
    w E0 4D FF
    w E0 4E FF
    w E0 4F FF
    w E0 50 FF
    w E0 51 FF
    w E0 52 FF
    w E0 53 FF
    w E0 54 FF
    w E0 55 FF
    w E0 56 FF
    w E0 57 FF
    w E0 58 FF
    w E0 59 FF
    w E0 5A FF
    w E0 5B FF
    w E0 5C FF
    w E0 5D FF
    w E0 5E FF
    w E0 5F FF
    w E0 60 FF
    w E0 61 FF
    w E0 62 FF
    w E0 63 FF
    w E0 64 FF
    w E0 65 FF
    w E0 66 FF
    w E0 67 FF
    w E0 68 FF
    w E0 69 FF
    w E0 6A FF
    w E0 6B FF
    w E0 6C FF
    w E0 6D FF
    w E0 6E FF
    w E0 6F FF
    w E0 70 FF
    w E0 71 FF
    w E0 72 FF
    w E0 73 FF
    w E0 74 FF
    w E0 75 FF
    w E0 76 FF
    w E0 77 FF
    w E0 78 FF
    w E0 79 FF
    w E0 7A FF
    w E0 7B FF
    w E0 7C FF
    w E0 7D FF
    w E0 7E FF
    w E0 7F 00
    # Page 0x2f
    w E0 00 2F
    w E0 01 00
    w E0 02 00
    w E0 03 00
    w E0 04 00
    w E0 05 00
    w E0 06 00
    w E0 07 00
    w E0 08 00
    w E0 09 00
    w E0 0A 00
    w E0 0B 00
    w E0 0C 00
    w E0 0D 00
    w E0 0E 00
    w E0 0F 00
    w E0 10 00
    w E0 11 00
    w E0 12 00
    w E0 13 00
    w E0 14 00
    w E0 15 00
    w E0 16 00
    w E0 17 00
    w E0 18 00
    w E0 19 00
    w E0 1A 00
    w E0 1B 00
    w E0 1C 00
    w E0 1D 00
    w E0 1E 00
    w E0 1F 00
    w E0 20 00
    w E0 21 00
    w E0 22 00
    w E0 23 00
    w E0 24 00
    w E0 25 00
    w E0 26 00
    w E0 27 00
    w E0 28 00
    w E0 29 00
    w E0 2A 00
    w E0 2B 00
    w E0 2C 00
    w E0 2D 00
    w E0 2E 00
    w E0 2F 00
    w E0 30 00
    w E0 31 00
    w E0 32 00
    w E0 33 00
    w E0 34 00
    w E0 35 00
    w E0 36 00
    w E0 37 00
    w E0 38 00
    w E0 39 00
    w E0 3A 00
    w E0 3B 00
    w E0 3C 00
    w E0 3D 00
    w E0 3E 00
    w E0 3F 00
    w E0 40 FF
    w E0 41 FF
    w E0 42 FF
    w E0 43 FF
    w E0 44 FF
    w E0 45 FF
    w E0 46 FF
    w E0 47 FF
    w E0 48 FF
    w E0 49 FF
    w E0 4A FF
    w E0 4B FF
    w E0 4C FF
    w E0 4D FF
    w E0 4E FF
    w E0 4F FF
    w E0 50 FF
    w E0 51 FF
    w E0 52 FF
    w E0 53 FF
    w E0 54 FF
    w E0 55 FF
    w E0 56 FF
    w E0 57 FF
    w E0 58 FF
    w E0 59 FF
    w E0 5A FF
    w E0 5B FF
    w E0 5C FF
    w E0 5D FF
    w E0 5E FF
    w E0 5F FF
    w E0 60 FF
    w E0 61 FF
    w E0 62 FF
    w E0 63 FF
    w E0 64 FF
    w E0 65 FF
    w E0 66 FF
    w E0 67 FF
    w E0 68 FF
    w E0 69 FF
    w E0 6A FF
    w E0 6B FF
    w E0 6C FF
    w E0 6D FF
    w E0 6E FF
    w E0 6F FF
    w E0 70 FF
    w E0 71 FF
    w E0 72 FF
    w E0 73 FF
    w E0 74 FF
    w E0 75 FF
    w E0 76 FF
    w E0 77 FF
    w E0 78 FF
    w E0 79 FF
    w E0 7A FF
    w E0 7B FF
    w E0 7C FF
    w E0 7D FF
    w E0 7E FF
    w E0 7F 00
    # Page 0x30
    w E0 00 30
    w E0 01 00
    w E0 02 00
    w E0 03 00
    w E0 04 00
    w E0 05 00
    w E0 06 00
    w E0 07 00
    w E0 08 00
    w E0 09 00
    w E0 0A 00
    w E0 0B 00
    w E0 0C 00
    w E0 0D 00
    w E0 0E 00
    w E0 0F 00
    w E0 10 00
    w E0 11 00
    w E0 12 00
    w E0 13 00
    w E0 14 00
    w E0 15 00
    w E0 16 00
    w E0 17 00
    w E0 18 00
    w E0 19 00
    w E0 1A 00
    w E0 1B 00
    w E0 1C 00
    w E0 1D 00
    w E0 1E 00
    w E0 1F 00
    w E0 20 00
    w E0 21 00
    w E0 22 00
    w E0 23 00
    w E0 24 00
    w E0 25 00
    w E0 26 00
    w E0 27 00
    w E0 28 00
    w E0 29 00
    w E0 2A 00
    w E0 2B 00
    w E0 2C 00
    w E0 2D 00
    w E0 2E 00
    w E0 2F 00
    w E0 30 00
    w E0 31 00
    w E0 32 00
    w E0 33 00
    w E0 34 00
    w E0 35 00
    w E0 36 00
    w E0 37 00
    w E0 38 00
    w E0 39 00
    w E0 3A 00
    w E0 3B 00
    w E0 3C 00
    w E0 3D 00
    w E0 3E 00
    w E0 3F 00
    w E0 40 FF
    w E0 41 FF
    w E0 42 FF
    w E0 43 FF
    w E0 44 FF
    w E0 45 FF
    w E0 46 FF
    w E0 47 FF
    w E0 48 FF
    w E0 49 FF
    w E0 4A FF
    w E0 4B FF
    w E0 4C FF
    w E0 4D FF
    w E0 4E FF
    w E0 4F FF
    w E0 50 FF
    w E0 51 FF
    w E0 52 FF
    w E0 53 FF
    w E0 54 FF
    w E0 55 FF
    w E0 56 FF
    w E0 57 FF
    w E0 58 FF
    w E0 59 FF
    w E0 5A FF
    w E0 5B FF
    w E0 5C FF
    w E0 5D FF
    w E0 5E FF
    w E0 5F FF
    w E0 60 FF
    w E0 61 FF
    w E0 62 FF
    w E0 63 FF
    w E0 64 FF
    w E0 65 FF
    w E0 66 FF
    w E0 67 FF
    w E0 68 FF
    w E0 69 FF
    w E0 6A FF
    w E0 6B FF
    w E0 6C FF
    w E0 6D FF
    w E0 6E FF
    w E0 6F FF
    w E0 70 FF
    w E0 71 FF
    w E0 72 FF
    w E0 73 FF
    w E0 74 FF
    w E0 75 FF
    w E0 76 FF
    w E0 77 FF
    w E0 78 FF
    w E0 79 FF
    w E0 7A FF
    w E0 7B FF
    w E0 7C FF
    w E0 7D FF
    w E0 7E FF
    w E0 7F 00
    # Page 0x31
    w E0 00 31
    w E0 01 00
    w E0 02 00
    w E0 03 00
    w E0 04 00
    w E0 05 00
    w E0 06 00
    w E0 07 00
    w E0 08 00
    w E0 09 00
    w E0 0A 00
    w E0 0B 00
    w E0 0C 00
    w E0 0D 00
    w E0 0E 00
    w E0 0F 00
    w E0 10 00
    w E0 11 00
    w E0 12 00
    w E0 13 00
    w E0 14 00
    w E0 15 00
    w E0 16 00
    w E0 17 00
    w E0 18 00
    w E0 19 00
    w E0 1A 00
    w E0 1B 00
    w E0 1C 00
    w E0 1D 00
    w E0 1E 00
    w E0 1F 00
    w E0 20 00
    w E0 21 00
    w E0 22 00
    w E0 23 00
    w E0 24 00
    w E0 25 00
    w E0 26 00
    w E0 27 00
    w E0 28 00
    w E0 29 00
    w E0 2A 00
    w E0 2B 00
    w E0 2C 00
    w E0 2D 00
    w E0 2E 00
    w E0 2F 00
    w E0 30 00
    w E0 31 00
    w E0 32 00
    w E0 33 00
    w E0 34 00
    w E0 35 00
    w E0 36 00
    w E0 37 00
    w E0 38 00
    w E0 39 00
    w E0 3A 00
    w E0 3B 00
    w E0 3C 00
    w E0 3D 00
    w E0 3E 00
    w E0 3F 00
    w E0 40 FF
    w E0 41 FF
    w E0 42 FF
    w E0 43 FF
    w E0 44 FF
    w E0 45 FF
    w E0 46 FF
    w E0 47 FF
    w E0 48 FF
    w E0 49 FF
    w E0 4A FF
    w E0 4B FF
    w E0 4C FF
    w E0 4D FF
    w E0 4E FF
    w E0 4F FF
    w E0 50 FF
    w E0 51 FF
    w E0 52 FF
    w E0 53 FF
    w E0 54 FF
    w E0 55 FF
    w E0 56 FF
    w E0 57 FF
    w E0 58 FF
    w E0 59 FF
    w E0 5A FF
    w E0 5B FF
    w E0 5C FF
    w E0 5D FF
    w E0 5E FF
    w E0 5F FF
    w E0 60 FF
    w E0 61 FF
    w E0 62 FF
    w E0 63 FF
    w E0 64 FF
    w E0 65 FF
    w E0 66 FF
    w E0 67 FF
    w E0 68 FF
    w E0 69 FF
    w E0 6A FF
    w E0 6B FF
    w E0 6C FF
    w E0 6D FF
    w E0 6E FF
    w E0 6F FF
    w E0 70 FF
    w E0 71 FF
    w E0 72 FF
    w E0 73 FF
    w E0 74 FF
    w E0 75 FF
    w E0 76 FF
    w E0 77 FF
    w E0 78 FF
    w E0 79 FF
    w E0 7A FF
    w E0 7B FF
    w E0 7C FF
    w E0 7D FF
    w E0 7E FF
    w E0 7F 00
    # Page 0x32
    w E0 00 32
    w E0 01 00
    w E0 02 00
    w E0 03 00
    w E0 04 00
    w E0 05 00
    w E0 06 00
    w E0 07 00
    w E0 08 00
    w E0 09 00
    w E0 0A 00
    w E0 0B 00
    w E0 0C 00
    w E0 0D 00
    w E0 0E 00
    w E0 0F 00
    w E0 10 00
    w E0 11 00
    w E0 12 00
    w E0 13 00
    w E0 14 00
    w E0 15 00
    w E0 16 00
    w E0 17 00
    w E0 18 00
    w E0 19 00
    w E0 1A 00
    w E0 1B 00
    w E0 1C 00
    w E0 1D 00
    w E0 1E 00
    w E0 1F 00
    w E0 20 00
    w E0 21 00
    w E0 22 00
    w E0 23 00
    w E0 24 00
    w E0 25 00
    w E0 26 00
    w E0 27 00
    w E0 28 00
    w E0 29 00
    w E0 2A 00
    w E0 2B 00
    w E0 2C 00
    w E0 2D 00
    w E0 2E 00
    w E0 2F 00
    w E0 30 00
    w E0 31 00
    w E0 32 00
    w E0 33 00
    w E0 34 00
    w E0 35 00
    w E0 36 00
    w E0 37 00
    w E0 38 00
    w E0 39 00
    w E0 3A 00
    w E0 3B 00
    w E0 3C 00
    w E0 3D 00
    w E0 3E 00
    w E0 3F 00
    w E0 40 FF
    w E0 41 FF
    w E0 42 FF
    w E0 43 FF
    w E0 44 FF
    w E0 45 FF
    w E0 46 FF
    w E0 47 FF
    w E0 48 FF
    w E0 49 FF
    w E0 4A FF
    w E0 4B FF
    w E0 4C FF
    w E0 4D FF
    w E0 4E FF
    w E0 4F FF
    w E0 50 FF
    w E0 51 FF
    w E0 52 FF
    w E0 53 FF
    w E0 54 FF
    w E0 55 FF
    w E0 56 FF
    w E0 57 FF
    w E0 58 FF
    w E0 59 FF
    w E0 5A FF
    w E0 5B FF
    w E0 5C FF
    w E0 5D FF
    w E0 5E FF
    w E0 5F FF
    w E0 60 FF
    w E0 61 FF
    w E0 62 FF
    w E0 63 FF
    w E0 64 FF
    w E0 65 FF
    w E0 66 FF
    w E0 67 FF
    w E0 68 FF
    w E0 69 FF
    w E0 6A FF
    w E0 6B FF
    w E0 6C FF
    w E0 6D FF
    w E0 6E FF
    w E0 6F FF
    w E0 70 FF
    w E0 71 FF
    w E0 72 FF
    w E0 73 FF
    w E0 74 FF
    w E0 75 FF
    w E0 76 FF
    w E0 77 FF
    w E0 78 FF
    w E0 79 FF
    w E0 7A FF
    w E0 7B FF
    w E0 7C FF
    w E0 7D FF
    w E0 7E FF
    w E0 7F 00
    # Page 0x33
    w E0 00 33
    w E0 01 00
    w E0 02 00
    w E0 03 00
    w E0 04 00
    w E0 05 00
    w E0 06 00
    w E0 07 00
    w E0 08 00
    w E0 09 00
    w E0 0A 00
    w E0 0B 00
    w E0 0C 00
    w E0 0D 00
    w E0 0E 00
    w E0 0F 00
    w E0 10 00
    w E0 11 00
    w E0 12 00
    w E0 13 00
    w E0 14 00
    w E0 15 00
    w E0 16 00
    w E0 17 00
    w E0 18 00
    w E0 19 00
    w E0 1A 00
    w E0 1B 00
    w E0 1C 00
    w E0 1D 00
    w E0 1E 00
    w E0 1F 00
    w E0 20 00
    w E0 21 00
    w E0 22 00
    w E0 23 00
    w E0 24 00
    w E0 25 00
    w E0 26 00
    w E0 27 00
    w E0 28 00
    w E0 29 00
    w E0 2A 00
    w E0 2B 00
    w E0 2C 00
    w E0 2D 00
    w E0 2E 00
    w E0 2F 00
    w E0 30 00
    w E0 31 00
    w E0 32 00
    w E0 33 00
    w E0 34 00
    w E0 35 00
    w E0 36 00
    w E0 37 00
    w E0 38 00
    w E0 39 00
    w E0 3A 00
    w E0 3B 00
    w E0 3C 00
    w E0 3D 00
    w E0 3E 00
    w E0 3F 00
    w E0 40 FF
    w E0 41 FF
    w E0 42 FF
    w E0 43 FF
    w E0 44 FF
    w E0 45 FF
    w E0 46 FF
    w E0 47 FF
    w E0 48 FF
    w E0 49 FF
    w E0 4A FF
    w E0 4B FF
    w E0 4C FF
    w E0 4D FF
    w E0 4E FF
    w E0 4F FF
    w E0 50 FF
    w E0 51 FF
    w E0 52 FF
    w E0 53 FF
    w E0 54 FF
    w E0 55 FF
    w E0 56 FF
    w E0 57 FF
    w E0 58 FF
    w E0 59 FF
    w E0 5A FF
    w E0 5B FF
    w E0 5C FF
    w E0 5D FF
    w E0 5E FF
    w E0 5F FF
    w E0 60 FF
    w E0 61 FF
    w E0 62 FF
    w E0 63 FF
    w E0 64 FF
    w E0 65 FF
    w E0 66 FF
    w E0 67 FF
    w E0 68 FF
    w E0 69 FF
    w E0 6A FF
    w E0 6B FF
    w E0 6C FF
    w E0 6D FF
    w E0 6E FF
    w E0 6F FF
    w E0 70 FF
    w E0 71 FF
    w E0 72 FF
    w E0 73 FF
    w E0 74 FF
    w E0 75 FF
    w E0 76 FF
    w E0 77 FF
    w E0 78 FF
    w E0 79 FF
    w E0 7A FF
    w E0 7B FF
    w E0 7C FF
    w E0 7D FF
    w E0 7E FF
    w E0 7F 00
    # Page 0x34
    w E0 00 34
    w E0 01 00
    w E0 02 00
    w E0 03 00
    w E0 04 00
    w E0 05 00
    w E0 06 00
    w E0 07 00
    w E0 08 00
    w E0 09 00
    w E0 0A 00
    w E0 0B 00
    w E0 0C 00
    w E0 0D 00
    w E0 0E 00
    w E0 0F 00
    w E0 10 00
    w E0 11 00
    w E0 12 00
    w E0 13 00
    w E0 14 00
    w E0 15 00
    w E0 16 00
    w E0 17 00
    w E0 18 00
    w E0 19 00
    w E0 1A 00
    w E0 1B 00
    w E0 1C 00
    w E0 1D 00
    w E0 1E 00
    w E0 1F 00
    w E0 20 00
    w E0 21 00
    w E0 22 00
    w E0 23 00
    w E0 24 00
    w E0 25 00
    w E0 26 00
    w E0 27 00
    w E0 28 00
    w E0 29 00
    w E0 2A 00
    w E0 2B 00
    w E0 2C 00
    w E0 2D 00
    w E0 2E 00
    w E0 2F 00
    w E0 30 00
    w E0 31 00
    w E0 32 00
    w E0 33 00
    w E0 34 00
    w E0 35 00
    w E0 36 00
    w E0 37 00
    w E0 38 00
    w E0 39 00
    w E0 3A 00
    w E0 3B 00
    w E0 3C 00
    w E0 3D 00
    w E0 3E 00
    w E0 3F 00
    w E0 40 FF
    w E0 41 FF
    w E0 42 FF
    w E0 43 FF
    w E0 44 FF
    w E0 45 FF
    w E0 46 FF
    w E0 47 FF
    w E0 48 FF
    w E0 49 FF
    w E0 4A FF
    w E0 4B FF
    w E0 4C FF
    w E0 4D FF
    w E0 4E FF
    w E0 4F FF
    w E0 50 FF
    w E0 51 FF
    w E0 52 FF
    w E0 53 FF
    w E0 54 FF
    w E0 55 FF
    w E0 56 FF
    w E0 57 FF
    w E0 58 FF
    w E0 59 FF
    w E0 5A FF
    w E0 5B FF
    w E0 5C FF
    w E0 5D FF
    w E0 5E FF
    w E0 5F FF
    w E0 60 FF
    w E0 61 FF
    w E0 62 FF
    w E0 63 FF
    w E0 64 FF
    w E0 65 FF
    w E0 66 FF
    w E0 67 FF
    w E0 68 FF
    w E0 69 FF
    w E0 6A FF
    w E0 6B FF
    w E0 6C FF
    w E0 6D FF
    w E0 6E FF
    w E0 6F FF
    w E0 70 FF
    w E0 71 FF
    w E0 72 FF
    w E0 73 FF
    w E0 74 FF
    w E0 75 FF
    w E0 76 FF
    w E0 77 FF
    w E0 78 FF
    w E0 79 FF
    w E0 7A FF
    w E0 7B FF
    w E0 7C FF
    w E0 7D FF
    w E0 7E FF
    w E0 7F 00
    # Page 0x3e
    w E0 00 3E
    w E0 01 00
    w E0 02 00
    w E0 03 00
    w E0 04 00
    w E0 05 00
    w E0 06 00
    w E0 07 00
    w E0 08 00
    w E0 09 00
    w E0 0A 00
    w E0 0B 00
    w E0 0C 00
    w E0 0D 00
    w E0 0E 00
    w E0 0F 00
    w E0 10 00
    w E0 11 00
    w E0 12 00
    w E0 13 00
    w E0 14 00
    w E0 15 00
    w E0 16 00
    w E0 17 00
    w E0 18 00
    w E0 19 00
    w E0 1A 00
    w E0 1B 00
    w E0 1C 00
    w E0 1D 00
    w E0 1E 00
    w E0 1F 00
    w E0 20 00
    w E0 21 00
    w E0 22 00
    w E0 23 00
    w E0 24 00
    w E0 25 00
    w E0 26 00
    w E0 27 00
    w E0 28 00
    w E0 29 00
    w E0 2A 00
    w E0 2B 00
    w E0 2C 00
    w E0 2D 00
    w E0 2E 00
    w E0 2F 00
    w E0 30 00
    w E0 31 00
    w E0 32 00
    w E0 33 00
    w E0 34 00
    w E0 35 00
    w E0 36 00
    w E0 37 00
    w E0 38 00
    w E0 39 00
    w E0 3A 00
    w E0 3B 00
    w E0 3C 00
    w E0 3D 00
    w E0 3E 00
    w E0 3F 00
    w E0 40 FF
    w E0 41 FF
    w E0 42 FF
    w E0 43 FF
    w E0 44 FF
    w E0 45 FF
    w E0 46 FF
    w E0 47 FF
    w E0 48 FF
    w E0 49 FF
    w E0 4A FF
    w E0 4B FF
    w E0 4C FF
    w E0 4D FF
    w E0 4E FF
    w E0 4F FF
    w E0 50 FF
    w E0 51 FF
    w E0 52 FF
    w E0 53 FF
    w E0 54 FF
    w E0 55 FF
    w E0 56 FF
    w E0 57 FF
    w E0 58 FF
    w E0 59 FF
    w E0 5A FF
    w E0 5B FF
    w E0 5C FF
    w E0 5D FF
    w E0 5E FF
    w E0 5F FF
    w E0 60 FF
    w E0 61 FF
    w E0 62 FF
    w E0 63 FF
    w E0 64 FF
    w E0 65 FF
    w E0 66 FF
    w E0 67 FF
    w E0 68 FF
    w E0 69 FF
    w E0 6A FF
    w E0 6B FF
    w E0 6C FF
    w E0 6D FF
    w E0 6E FF
    w E0 6F FF
    w E0 70 FF
    w E0 71 FF
    w E0 72 FF
    w E0 73 FF
    w E0 74 FF
    w E0 75 FF
    w E0 76 FF
    w E0 77 FF
    w E0 78 FF
    w E0 79 FF
    w E0 7A FF
    w E0 7B FF
    w E0 7C FF
    w E0 7D FF
    w E0 7E FF
    w E0 7F 00
    # Page 0x3f
    w E0 00 3F
    w E0 01 00
    w E0 02 00
    w E0 03 00
    w E0 04 00
    w E0 05 00
    w E0 06 00
    w E0 07 00
    w E0 08 00
    w E0 09 00
    w E0 0A 00
    w E0 0B 00
    w E0 0C 00
    w E0 0D 00
    w E0 0E 00
    w E0 0F 00
    w E0 10 00
    w E0 11 00
    w E0 12 00
    w E0 13 00
    w E0 14 00
    w E0 15 00
    w E0 16 00
    w E0 17 00
    w E0 18 00
    w E0 19 00
    w E0 1A 00
    w E0 1B 00
    w E0 1C 00
    w E0 1D 00
    w E0 1E 00
    w E0 1F 00
    w E0 20 00
    w E0 21 00
    w E0 22 00
    w E0 23 00
    w E0 24 00
    w E0 25 00
    w E0 26 00
    w E0 27 00
    w E0 28 00
    w E0 29 00
    w E0 2A 00
    w E0 2B 00
    w E0 2C 00
    w E0 2D 00
    w E0 2E 00
    w E0 2F 00
    w E0 30 00
    w E0 31 00
    w E0 32 00
    w E0 33 00
    w E0 34 00
    w E0 35 00
    w E0 36 00
    w E0 37 00
    w E0 38 00
    w E0 39 00
    w E0 3A 00
    w E0 3B 00
    w E0 3C 00
    w E0 3D 00
    w E0 3E 00
    w E0 3F 00
    w E0 40 FF
    w E0 41 FF
    w E0 42 FF
    w E0 43 FF
    w E0 44 FF
    w E0 45 FF
    w E0 46 FF
    w E0 47 FF
    w E0 48 FF
    w E0 49 FF
    w E0 4A FF
    w E0 4B FF
    w E0 4C FF
    w E0 4D FF
    w E0 4E FF
    w E0 4F FF
    w E0 50 FF
    w E0 51 FF
    w E0 52 FF
    w E0 53 FF
    w E0 54 FF
    w E0 55 FF
    w E0 56 FF
    w E0 57 FF
    w E0 58 FF
    w E0 59 FF
    w E0 5A FF
    w E0 5B FF
    w E0 5C FF
    w E0 5D FF
    w E0 5E FF
    w E0 5F FF
    w E0 60 FF
    w E0 61 FF
    w E0 62 FF
    w E0 63 FF
    w E0 64 FF
    w E0 65 FF
    w E0 66 FF
    w E0 67 FF
    w E0 68 FF
    w E0 69 FF
    w E0 6A FF
    w E0 6B FF
    w E0 6C FF
    w E0 6D FF
    w E0 6E FF
    w E0 6F FF
    w E0 70 FF
    w E0 71 FF
    w E0 72 FF
    w E0 73 FF
    w E0 74 FF
    w E0 75 FF
    w E0 76 FF
    w E0 77 FF
    w E0 78 FF
    w E0 79 FF
    w E0 7A FF
    w E0 7B FF
    w E0 7C FF
    w E0 7D FF
    w E0 7E FF
    w E0 7F 00
    # Page 0x40
    w E0 00 40
    w E0 01 00
    w E0 02 00
    w E0 03 00
    w E0 04 00
    w E0 05 00
    w E0 06 00
    w E0 07 00
    w E0 08 00
    w E0 09 00
    w E0 0A 00
    w E0 0B 00
    w E0 0C 00
    w E0 0D 00
    w E0 0E 00
    w E0 0F 00
    w E0 10 00
    w E0 11 00
    w E0 12 00
    w E0 13 00
    w E0 14 00
    w E0 15 00
    w E0 16 00
    w E0 17 00
    w E0 18 00
    w E0 19 00
    w E0 1A 00
    w E0 1B 00
    w E0 1C 00
    w E0 1D 00
    w E0 1E 00
    w E0 1F 00
    w E0 20 00
    w E0 21 00
    w E0 22 00
    w E0 23 00
    w E0 24 00
    w E0 25 00
    w E0 26 00
    w E0 27 00
    w E0 28 00
    w E0 29 00
    w E0 2A 00
    w E0 2B 00
    w E0 2C 00
    w E0 2D 00
    w E0 2E 00
    w E0 2F 00
    w E0 30 00
    w E0 31 00
    w E0 32 00
    w E0 33 00
    w E0 34 00
    w E0 35 00
    w E0 36 00
    w E0 37 00
    w E0 38 00
    w E0 39 00
    w E0 3A 00
    w E0 3B 00
    w E0 3C 00
    w E0 3D 00
    w E0 3E 00
    w E0 3F 00
    w E0 40 FF
    w E0 41 FF
    w E0 42 FF
    w E0 43 FF
    w E0 44 FF
    w E0 45 FF
    w E0 46 FF
    w E0 47 FF
    w E0 48 FF
    w E0 49 FF
    w E0 4A FF
    w E0 4B FF
    w E0 4C FF
    w E0 4D FF
    w E0 4E FF
    w E0 4F FF
    w E0 50 FF
    w E0 51 FF
    w E0 52 FF
    w E0 53 FF
    w E0 54 FF
    w E0 55 FF
    w E0 56 FF
    w E0 57 FF
    w E0 58 FF
    w E0 59 FF
    w E0 5A FF
    w E0 5B FF
    w E0 5C FF
    w E0 5D FF
    w E0 5E FF
    w E0 5F FF
    w E0 60 FF
    w E0 61 FF
    w E0 62 FF
    w E0 63 FF
    w E0 64 FF
    w E0 65 FF
    w E0 66 FF
    w E0 67 FF
    w E0 68 FF
    w E0 69 FF
    w E0 6A FF
    w E0 6B FF
    w E0 6C FF
    w E0 6D FF
    w E0 6E FF
    w E0 6F FF
    w E0 70 FF
    w E0 71 FF
    w E0 72 FF
    w E0 73 FF
    w E0 74 FF
    w E0 75 FF
    w E0 76 FF
    w E0 77 FF
    w E0 78 FF
    w E0 79 FF
    w E0 7A FF
    w E0 7B FF
    w E0 7C FF
    w E0 7D FF
    w E0 7E FF
    w E0 7F 00
    # Page 0x41
    w E0 00 41
    w E0 01 00
    w E0 02 00
    w E0 03 00
    w E0 04 00
    w E0 05 00
    w E0 06 00
    w E0 07 00
    w E0 08 00
    w E0 09 00
    w E0 0A 00
    w E0 0B 00
    w E0 0C 00
    w E0 0D 00
    w E0 0E 00
    w E0 0F 00
    w E0 10 00
    w E0 11 00
    w E0 12 00
    w E0 13 00
    w E0 14 00
    w E0 15 00
    w E0 16 00
    w E0 17 00
    w E0 18 00
    w E0 19 00
    w E0 1A 00
    w E0 1B 00
    w E0 1C 00
    w E0 1D 00
    w E0 1E 00
    w E0 1F 00
    w E0 20 00
    w E0 21 00
    w E0 22 00
    w E0 23 00
    w E0 24 00
    w E0 25 00
    w E0 26 00
    w E0 27 00
    w E0 28 00
    w E0 29 00
    w E0 2A 00
    w E0 2B 00
    w E0 2C 00
    w E0 2D 00
    w E0 2E 00
    w E0 2F 00
    w E0 30 00
    w E0 31 00
    w E0 32 00
    w E0 33 00
    w E0 34 00
    w E0 35 00
    w E0 36 00
    w E0 37 00
    w E0 38 00
    w E0 39 00
    w E0 3A 00
    w E0 3B 00
    w E0 3C 00
    w E0 3D 00
    w E0 3E 00
    w E0 3F 00
    w E0 40 FF
    w E0 41 FF
    w E0 42 FF
    w E0 43 FF
    w E0 44 FF
    w E0 45 FF
    w E0 46 FF
    w E0 47 FF
    w E0 48 FF
    w E0 49 FF
    w E0 4A FF
    w E0 4B FF
    w E0 4C FF
    w E0 4D FF
    w E0 4E FF
    w E0 4F FF
    w E0 50 FF
    w E0 51 FF
    w E0 52 FF
    w E0 53 FF
    w E0 54 FF
    w E0 55 FF
    w E0 56 FF
    w E0 57 FF
    w E0 58 FF
    w E0 59 FF
    w E0 5A FF
    w E0 5B FF
    w E0 5C FF
    w E0 5D FF
    w E0 5E FF
    w E0 5F FF
    w E0 60 FF
    w E0 61 FF
    w E0 62 FF
    w E0 63 FF
    w E0 64 FF
    w E0 65 FF
    w E0 66 FF
    w E0 67 FF
    w E0 68 FF
    w E0 69 FF
    w E0 6A FF
    w E0 6B FF
    w E0 6C FF
    w E0 6D FF
    w E0 6E FF
    w E0 6F FF
    w E0 70 FF
    w E0 71 FF
    w E0 72 FF
    w E0 73 FF
    w E0 74 FF
    w E0 75 FF
    w E0 76 FF
    w E0 77 FF
    w E0 78 FF
    w E0 79 FF
    w E0 7A FF
    w E0 7B FF
    w E0 7C FF
    w E0 7D FF
    w E0 7E FF
    w E0 7F 00
    # Page 0x42
    w E0 00 42
    w E0 01 00
    w E0 02 00
    w E0 03 00
    w E0 04 00
    w E0 05 00
    w E0 06 00
    w E0 07 00
    w E0 08 00
    w E0 09 00
    w E0 0A 00
    w E0 0B 00
    w E0 0C 00
    w E0 0D 00
    w E0 0E 00
    w E0 0F 00
    w E0 10 00
    w E0 11 00
    w E0 12 00
    w E0 13 00
    w E0 14 00
    w E0 15 00
    w E0 16 00
    w E0 17 00
    w E0 18 00
    w E0 19 00
    w E0 1A 00
    w E0 1B 00
    w E0 1C 00
    w E0 1D 00
    w E0 1E 00
    w E0 1F 00
    w E0 20 00
    w E0 21 00
    w E0 22 00
    w E0 23 00
    w E0 24 00
    w E0 25 00
    w E0 26 00
    w E0 27 00
    w E0 28 00
    w E0 29 00
    w E0 2A 00
    w E0 2B 00
    w E0 2C 00
    w E0 2D 00
    w E0 2E 00
    w E0 2F 00
    w E0 30 00
    w E0 31 00
    w E0 32 00
    w E0 33 00
    w E0 34 00
    w E0 35 00
    w E0 36 00
    w E0 37 00
    w E0 38 00
    w E0 39 00
    w E0 3A 00
    w E0 3B 00
    w E0 3C 00
    w E0 3D 00
    w E0 3E 00
    w E0 3F 00
    w E0 40 FF
    w E0 41 FF
    w E0 42 FF
    w E0 43 FF
    w E0 44 FF
    w E0 45 FF
    w E0 46 FF
    w E0 47 FF
    w E0 48 FF
    w E0 49 FF
    w E0 4A FF
    w E0 4B FF
    w E0 4C FF
    w E0 4D FF
    w E0 4E FF
    w E0 4F FF
    w E0 50 FF
    w E0 51 FF
    w E0 52 FF
    w E0 53 FF
    w E0 54 FF
    w E0 55 FF
    w E0 56 FF
    w E0 57 FF
    w E0 58 FF
    w E0 59 FF
    w E0 5A FF
    w E0 5B FF
    w E0 5C FF
    w E0 5D FF
    w E0 5E FF
    w E0 5F FF
    w E0 60 FF
    w E0 61 FF
    w E0 62 FF
    w E0 63 FF
    w E0 64 FF
    w E0 65 FF
    w E0 66 FF
    w E0 67 FF
    w E0 68 FF
    w E0 69 FF
    w E0 6A FF
    w E0 6B FF
    w E0 6C FF
    w E0 6D FF
    w E0 6E FF
    w E0 6F FF
    w E0 70 FF
    w E0 71 FF
    w E0 72 FF
    w E0 73 FF
    w E0 74 FF
    w E0 75 FF
    w E0 76 FF
    w E0 77 FF
    w E0 78 FF
    w E0 79 FF
    w E0 7A FF
    w E0 7B FF
    w E0 7C FF
    w E0 7D FF
    w E0 7E FF
    w E0 7F 00
    # Page 0x43
    w E0 00 43
    w E0 01 00
    w E0 02 00
    w E0 03 00
    w E0 04 00
    w E0 05 00
    w E0 06 00
    w E0 07 00
    w E0 08 00
    w E0 09 00
    w E0 0A 00
    w E0 0B 00
    w E0 0C 00
    w E0 0D 00
    w E0 0E 00
    w E0 0F 00
    w E0 10 00
    w E0 11 00
    w E0 12 00
    w E0 13 00
    w E0 14 00
    w E0 15 00
    w E0 16 00
    w E0 17 00
    w E0 18 00
    w E0 19 00
    w E0 1A 00
    w E0 1B 00
    w E0 1C 00
    w E0 1D 00
    w E0 1E 00
    w E0 1F 00
    w E0 20 00
    w E0 21 00
    w E0 22 00
    w E0 23 00
    w E0 24 00
    w E0 25 00
    w E0 26 00
    w E0 27 00
    w E0 28 00
    w E0 29 00
    w E0 2A 00
    w E0 2B 00
    w E0 2C 00
    w E0 2D 00
    w E0 2E 00
    w E0 2F 00
    w E0 30 00
    w E0 31 00
    w E0 32 00
    w E0 33 00
    w E0 34 00
    w E0 35 00
    w E0 36 00
    w E0 37 00
    w E0 38 00
    w E0 39 00
    w E0 3A 00
    w E0 3B 00
    w E0 3C 00
    w E0 3D 00
    w E0 3E 00
    w E0 3F 00
    w E0 40 FF
    w E0 41 FF
    w E0 42 FF
    w E0 43 FF
    w E0 44 FF
    w E0 45 FF
    w E0 46 FF
    w E0 47 FF
    w E0 48 FF
    w E0 49 FF
    w E0 4A FF
    w E0 4B FF
    w E0 4C FF
    w E0 4D FF
    w E0 4E FF
    w E0 4F FF
    w E0 50 FF
    w E0 51 FF
    w E0 52 FF
    w E0 53 FF
    w E0 54 FF
    w E0 55 FF
    w E0 56 FF
    w E0 57 FF
    w E0 58 FF
    w E0 59 FF
    w E0 5A FF
    w E0 5B FF
    w E0 5C FF
    w E0 5D FF
    w E0 5E FF
    w E0 5F FF
    w E0 60 FF
    w E0 61 FF
    w E0 62 FF
    w E0 63 FF
    w E0 64 FF
    w E0 65 FF
    w E0 66 FF
    w E0 67 FF
    w E0 68 FF
    w E0 69 FF
    w E0 6A FF
    w E0 6B FF
    w E0 6C FF
    w E0 6D FF
    w E0 6E FF
    w E0 6F FF
    w E0 70 FF
    w E0 71 FF
    w E0 72 FF
    w E0 73 FF
    w E0 74 FF
    w E0 75 FF
    w E0 76 FF
    w E0 77 FF
    w E0 78 FF
    w E0 79 FF
    w E0 7A FF
    w E0 7B FF
    w E0 7C FF
    w E0 7D FF
    w E0 7E FF
    w E0 7F 00
    # Page 0x44
    w E0 00 44
    w E0 01 00
    w E0 02 00
    w E0 03 00
    w E0 04 00
    w E0 05 00
    w E0 06 00
    w E0 07 00
    w E0 08 00
    w E0 09 00
    w E0 0A 00
    w E0 0B 00
    w E0 0C 00
    w E0 0D 00
    w E0 0E 00
    w E0 0F 00
    w E0 10 00
    w E0 11 00
    w E0 12 00
    w E0 13 00
    w E0 14 00
    w E0 15 00
    w E0 16 00
    w E0 17 00
    w E0 18 00
    w E0 19 00
    w E0 1A 00
    w E0 1B 00
    w E0 1C 00
    w E0 1D 00
    w E0 1E 00
    w E0 1F 00
    w E0 20 00
    w E0 21 00
    w E0 22 00
    w E0 23 00
    w E0 24 00
    w E0 25 00
    w E0 26 00
    w E0 27 00
    w E0 28 00
    w E0 29 00
    w E0 2A 00
    w E0 2B 00
    w E0 2C 00
    w E0 2D 00
    w E0 2E 00
    w E0 2F 00
    w E0 30 00
    w E0 31 00
    w E0 32 00
    w E0 33 00
    w E0 34 00
    w E0 35 00
    w E0 36 00
    w E0 37 00
    w E0 38 00
    w E0 39 00
    w E0 3A 00
    w E0 3B 00
    w E0 3C 00
    w E0 3D 00
    w E0 3E 00
    w E0 3F 00
    w E0 40 FF
    w E0 41 FF
    w E0 42 FF
    w E0 43 FF
    w E0 44 FF
    w E0 45 FF
    w E0 46 FF
    w E0 47 FF
    w E0 48 FF
    w E0 49 FF
    w E0 4A FF
    w E0 4B FF
    w E0 4C FF
    w E0 4D FF
    w E0 4E FF
    w E0 4F FF
    w E0 50 FF
    w E0 51 FF
    w E0 52 FF
    w E0 53 FF
    w E0 54 FF
    w E0 55 FF
    w E0 56 FF
    w E0 57 FF
    w E0 58 FF
    w E0 59 FF
    w E0 5A FF
    w E0 5B FF
    w E0 5C FF
    w E0 5D FF
    w E0 5E FF
    w E0 5F FF
    w E0 60 FF
    w E0 61 FF
    w E0 62 FF
    w E0 63 FF
    w E0 64 FF
    w E0 65 FF
    w E0 66 FF
    w E0 67 FF
    w E0 68 FF
    w E0 69 FF
    w E0 6A FF
    w E0 6B FF
    w E0 6C FF
    w E0 6D FF
    w E0 6E FF
    w E0 6F FF
    w E0 70 FF
    w E0 71 FF
    w E0 72 FF
    w E0 73 FF
    w E0 74 FF
    w E0 75 FF
    w E0 76 FF
    w E0 77 FF
    w E0 78 FF
    w E0 79 FF
    w E0 7A FF
    w E0 7B FF
    w E0 7C FF
    w E0 7D FF
    w E0 7E FF
    w E0 7F 00
    # Page 0x45
    w E0 00 45
    w E0 01 00
    w E0 02 00
    w E0 03 00
    w E0 04 00
    w E0 05 00
    w E0 06 00
    w E0 07 00
    w E0 08 00
    w E0 09 00
    w E0 0A 00
    w E0 0B 00
    w E0 0C 00
    w E0 0D 00
    w E0 0E 00
    w E0 0F 00
    w E0 10 00
    w E0 11 00
    w E0 12 00
    w E0 13 00
    w E0 14 00
    w E0 15 00
    w E0 16 00
    w E0 17 00
    w E0 18 00
    w E0 19 00
    w E0 1A 00
    w E0 1B 00
    w E0 1C 00
    w E0 1D 00
    w E0 1E 00
    w E0 1F 00
    w E0 20 00
    w E0 21 00
    w E0 22 00
    w E0 23 00
    w E0 24 00
    w E0 25 00
    w E0 26 00
    w E0 27 00
    w E0 28 00
    w E0 29 00
    w E0 2A 00
    w E0 2B 00
    w E0 2C 00
    w E0 2D 00
    w E0 2E 00
    w E0 2F 00
    w E0 30 00
    w E0 31 00
    w E0 32 00
    w E0 33 00
    w E0 34 00
    w E0 35 00
    w E0 36 00
    w E0 37 00
    w E0 38 00
    w E0 39 00
    w E0 3A 00
    w E0 3B 00
    w E0 3C 00
    w E0 3D 00
    w E0 3E 00
    w E0 3F 00
    w E0 40 FF
    w E0 41 FF
    w E0 42 FF
    w E0 43 FF
    w E0 44 FF
    w E0 45 FF
    w E0 46 FF
    w E0 47 FF
    w E0 48 FF
    w E0 49 FF
    w E0 4A FF
    w E0 4B FF
    w E0 4C FF
    w E0 4D FF
    w E0 4E FF
    w E0 4F FF
    w E0 50 FF
    w E0 51 FF
    w E0 52 FF
    w E0 53 FF
    w E0 54 FF
    w E0 55 FF
    w E0 56 FF
    w E0 57 FF
    w E0 58 FF
    w E0 59 FF
    w E0 5A FF
    w E0 5B FF
    w E0 5C FF
    w E0 5D FF
    w E0 5E FF
    w E0 5F FF
    w E0 60 FF
    w E0 61 FF
    w E0 62 FF
    w E0 63 FF
    w E0 64 FF
    w E0 65 FF
    w E0 66 FF
    w E0 67 FF
    w E0 68 FF
    w E0 69 FF
    w E0 6A FF
    w E0 6B FF
    w E0 6C FF
    w E0 6D FF
    w E0 6E FF
    w E0 6F FF
    w E0 70 FF
    w E0 71 FF
    w E0 72 FF
    w E0 73 FF
    w E0 74 FF
    w E0 75 FF
    w E0 76 FF
    w E0 77 FF
    w E0 78 FF
    w E0 79 FF
    w E0 7A FF
    w E0 7B FF
    w E0 7C FF
    w E0 7D FF
    w E0 7E FF
    w E0 7F 00
    # Page 0x46
    w E0 00 46
    w E0 01 00
    w E0 02 00
    w E0 03 00
    w E0 04 00
    w E0 05 00
    w E0 06 00
    w E0 07 00
    w E0 08 00
    w E0 09 00
    w E0 0A 00
    w E0 0B 00
    w E0 0C 00
    w E0 0D 00
    w E0 0E 00
    w E0 0F 00
    w E0 10 00
    w E0 11 00
    w E0 12 00
    w E0 13 00
    w E0 14 00
    w E0 15 00
    w E0 16 00
    w E0 17 00
    w E0 18 00
    w E0 19 00
    w E0 1A 00
    w E0 1B 00
    w E0 1C 00
    w E0 1D 00
    w E0 1E 00
    w E0 1F 00
    w E0 20 00
    w E0 21 00
    w E0 22 00
    w E0 23 00
    w E0 24 00
    w E0 25 00
    w E0 26 00
    w E0 27 00
    w E0 28 00
    w E0 29 00
    w E0 2A 00
    w E0 2B 00
    w E0 2C 00
    w E0 2D 00
    w E0 2E 00
    w E0 2F 00
    w E0 30 00
    w E0 31 00
    w E0 32 00
    w E0 33 00
    w E0 34 00
    w E0 35 00
    w E0 36 00
    w E0 37 00
    w E0 38 00
    w E0 39 00
    w E0 3A 00
    w E0 3B 00
    w E0 3C 00
    w E0 3D 00
    w E0 3E 00
    w E0 3F 00
    w E0 40 FF
    w E0 41 FF
    w E0 42 FF
    w E0 43 FF
    w E0 44 FF
    w E0 45 FF
    w E0 46 FF
    w E0 47 FF
    w E0 48 FF
    w E0 49 FF
    w E0 4A FF
    w E0 4B FF
    w E0 4C FF
    w E0 4D FF
    w E0 4E FF
    w E0 4F FF
    w E0 50 FF
    w E0 51 FF
    w E0 52 FF
    w E0 53 FF
    w E0 54 FF
    w E0 55 FF
    w E0 56 FF
    w E0 57 FF
    w E0 58 FF
    w E0 59 FF
    w E0 5A FF
    w E0 5B FF
    w E0 5C FF
    w E0 5D FF
    w E0 5E FF
    w E0 5F FF
    w E0 60 FF
    w E0 61 FF
    w E0 62 FF
    w E0 63 FF
    w E0 64 FF
    w E0 65 FF
    w E0 66 FF
    w E0 67 FF
    w E0 68 FF
    w E0 69 FF
    w E0 6A FF
    w E0 6B FF
    w E0 6C FF
    w E0 6D FF
    w E0 6E FF
    w E0 6F FF
    w E0 70 FF
    w E0 71 FF
    w E0 72 FF
    w E0 73 FF
    w E0 74 FF
    w E0 75 FF
    w E0 76 FF
    w E0 77 FF
    w E0 78 FF
    w E0 79 FF
    w E0 7A FF
    w E0 7B FF
    w E0 7C FF
    w E0 7D FF
    w E0 7E FF
    w E0 7F 00
    Memory Dump Finished
    Arash
  • Hi Arash,
    Thanks for confirming the configuration.
    I got EVM works but I must disconnected GUI and re-connected GUI to make it works.
    I loaded the script you provided and executed(showed 'executing finished'), also no DIN output.
    Then I disconnected GUI and re-connected GUI to execute init cfg file, it worked, I got SDIN signal at SRC4392 output and audio signal at PCM5142 output. I don't know why your EVM can run PCM5141_SRC_96k well. I will compare init cfg and SRC_96k cfg later.
    I have two EVM boards and another one can't replicate my operation on the previous one. When I play audio from Audacity, the sounds came out from PC speakers. I can make sure the speakers was choose as USB-Audio EVM. If this is a USB driver issue?
    BRs
    Kian
  • Hi Kian,
    In my several tests that I did yesterday , Couple of times I had to disconnect the GUI and connect it back too( which  power cycles or resets the board). That is no issue but if your computer doesn't recognize the EVM it is a problem.  On the speaker icon, once you hover the mouse on it , it should reflect the name of the board TI_Audio USB or something like that ( should not say Speaker.  Go to device manager and under audio device or HID and see if TI_Audio device  exist there , sometimes you have to uninstall  and unplug it and then plug it back.
    Arash
