I have Codec TLV320ADC5140 EVK board, where I can access I2C and I2S lines, I2C is working.
please find the below Audio codec connection details.
RZ/G2H CPU Pin AG34 {SSI_SCK78} is connected to TLV320ADC5140 pin BCLK.
RZ/G2H CPU Pin AG33 {SSI_WS78} is connected to TLV320ADC5140 pin FSYNC.
RZ/G2H CPU Pin AG30 {SSI_SDATA7} is connected to TLV320ADC5140 pin DOUT1.
Below is the dtsi configuration entries we . We enable the tlv321adcx140.c in the kernel driver
snd_rzg2h: sound {
// SPDX-License-Identifier: GPL-2.0
* Device Tree Source for the HiHope RZ/G2H Rev.4.0 and
* HiHope RZ/G2[MN] Rev.[2.0/3.0/4.0] main board common parts
* Copyright (C) 2019 Renesas Electronics Corp.
#include <dt-bindings/gpio/gpio.h>
aliases {
serial0 = &scif2; //GP5_11 GP5_10 serial debug port
serial1 = &hscif0; //GP5_13 GP5_14
serial2 = &hscif1; //GP5_5 GP5_6
serial3 = &scif0; //GP5_1 GP5_2
serial5 = &scif5; //GP5_19 GP5_21
chosen {
bootargs = "ignore_loglevel";
stdout-path = "serial0:115200n8";
hdmi0-out {
compatible = "hdmi-connector";
type = "a";
port {
hdmi0_con: endpoint {
remote-endpoint = <&rcar_dw_hdmi0_out>;
leds {
compatible = "gpio-leds";
led1 {
gpios = <&gpio6 12 GPIO_ACTIVE_HIGH>;
led2 {
gpios = <&gpio6 13 GPIO_ACTIVE_HIGH>;
led3 {
gpios = <&gpio0 0 GPIO_ACTIVE_HIGH>;
led4 {
gpios = <&gpio6 11 GPIO_ACTIVE_HIGH>;
reg_1p8v: regulator0 {
compatible = "regulator-fixed";
regulator-name = "fixed-1.8V";
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
regulator-boot-on;
regulator-always-on;
reg_3p3v: regulator1 {
regulator-name = "fixed-3.3V";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
regulator-boot-on;
sound_card: sound {
compatible = "audio-graph-card";
label = "rcar-sound";
dais = <&rsnd_port0 /* HDMI Audio */
&rsnd_port1>; /* External PCM5102A Codec */
vbus0_usb2: regulator-vbus0-usb2 {
regulator-name = "USB20_VBUS0";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
gpio = <&gpio6 16 GPIO_ACTIVE_HIGH>;
enable-active-high;
vccq_sdhi0: regulator-vccq-sdhi0 {
compatible = "regulator-gpio";
regulator-name = "SDHI0 VccQ";
gpios = <&gpio6 30 GPIO_ACTIVE_HIGH>;
gpios-states = <1>;
states = <3300000 1
1800000 0>;
x302_clk: x302-clock {
compatible = "fixed-clock";
#clock-cells = <0>;
clock-frequency = <33000000>;
x304_clk: x304-clock {
#clock-cells = <0>;
clock-frequency = <25000000>;
vspm_if {
compatible = "renesas,vspm_if";
pcm5102a: pcm5102a {
compatible = "ti,pcm5102a";
#sound-dai-cells = <0>;
port {
pcm5102a_endpoint: endpoint {
remote-endpoint = <&rsnd_endpoint1>;
&audio_clk_a {
clock-frequency = <22579200>;
&du {
status = "okay";
&ehci0 {
status = "okay";
&ehci1 {
status = "okay";
&extal_clk {
clock-frequency = <16666666>;
&extalr_clk {
clock-frequency = <32768>;
&gpio6 {
usb1-reset {
gpio-hog;
gpios = <10 GPIO_ACTIVE_LOW>;
output-low;
line-name = "usb1-reset";
&hdmi0 {
status = "okay";
ports {
port@1 {
reg = <1>;
rcar_dw_hdmi0_out: endpoint {
remote-endpoint = <&hdmi0_con>;
port@2 {
reg = <2>;
dw_hdmi0_snd_in: endpoint {
remote-endpoint = <&rsnd_endpoint>;
&hscif0 {
pinctrl-0 = <&hscif0_pins>;
pinctrl-names = "default";
uart-has-rtscts;
status = "okay";
#if 0
&scif1 {
pinctrl-0 = <&scif1_pins>;
status = "okay";
#endif
&scif0 {
pinctrl-0 = <&scif0_pins>;
status = "okay";
&hscif1 {
pinctrl-0 = <&hscif1_pins>;
uart-has-rtscts;
status = "okay";
&scif5 {
pinctrl-0 = <&scif5_pins>;
status = "okay";
&hsusb {
dr_mode = "otg";
status = "okay";
&i2c4 {
clock-frequency = <400000>;
status = "okay";
versaclock5: clock-generator@6a {
compatible = "idt,5p49v5923";
reg = <0x6a>;
#clock-cells = <1>;
clocks = <&x304_clk>;
clock-names = "xin";
&ohci0 {
status = "okay";
&ohci1 {
status = "okay";
&pcie_bus_clk {
clock-frequency = <100000000>;
&pfc {
pinctrl-0 = <&scif_clk_pins>;
hscif0_pins: hscif0 {
groups = "hscif0_data", "hscif0_ctrl";
function = "hscif0";
scif1_pins: scif1 {
groups = "scif1_data_a";
function = "scif1";
scif2_pins: scif2 {
groups = "scif2_data_a";
function = "scif2";
scif_clk_pins: scif_clk {
groups = "scif_clk_a";
function = "scif_clk";
hscif1_pins: hscif1 {
groups = "hscif1_data_a", "hscif1_ctrl_a";
function = "hscif1";
scif0_pins: scif0 {
groups = "scif0_data";
function = "scif0";
scif5_pins: scif5 {
groups = "scif5_data_a";
function = "scif5";
sdhi0_pins: sd0 {
groups = "sdhi0_data4", "sdhi0_ctrl";
function = "sdhi0";
power-source = <3300>;
sdhi0_pins_uhs: sd0_uhs {
function = "sdhi0";
power-source = <1800>;
sdhi2_pins: sd2 {
groups = "sdhi2_data4", "sdhi2_ctrl";
function = "sdhi2";
sdhi3_pins: sd3 {
groups = "sdhi3_data8", "sdhi3_ctrl", "sdhi3_ds";
function = "sdhi3";
sound_clk_pins: sound_clk {
groups = "audio_clk_a_a";
function = "audio_clk";
sound_pins: sound {
groups = "ssi01239_ctrl", "ssi0_data", "ssi1_data_a";
function = "ssi";
usb0_pins: usb0 {
groups = "usb0";
function = "usb0";
usb1_pins: usb1 {
mux {
groups = "usb1";
function = "usb1";
ovc {
pins = "GP_6_27";
bias-pull-up;
pwen {
pins = "GP_6_26";
usb30_pins: usb30 {
groups = "usb30";
function = "usb30";
&rcar_sound {
pinctrl-0 = <&sound_clk_pins &sound_pins>;
status = "okay";
/* Single DAI */
ports {
rsnd_port0: port@0 {
rsnd_endpoint: endpoint {
remote-endpoint = <&dw_hdmi0_snd_in>;
dai-format = "i2s";
bitclock-master = <&rsnd_endpoint>;
frame-master = <&rsnd_endpoint>;
playback = <&ssi2>;
rsnd_port1: port@1 {
rsnd_endpoint1: endpoint {
remote-endpoint = <&pcm5102a_endpoint>;
dai-format = "i2s";
bitclock-master = <&rsnd_endpoint1>;
frame-master = <&rsnd_endpoint1>;
playback = <&ssi1 &src1 &dvc0>;
&ssi1 {
shared-pin;
&rwdt {
timeout-sec = <60>;
status = "okay";
&scif2 {
pinctrl-0 = <&scif2_pins>;
status = "okay";
&scif_clk {
clock-frequency = <14745600>;
&sdhi0 {
pinctrl-0 = <&sdhi0_pins>;
pinctrl-1 = <&sdhi0_pins_uhs>;
pinctrl-names = "default", "state_uhs";
vmmc-supply = <®_3p3v>;
vqmmc-supply = <&vccq_sdhi0>;
cd-gpios = <&gpio3 12 GPIO_ACTIVE_LOW>;
bus-width = <4>;
sd-uhs-sdr50;
sd-uhs-sdr104;
status = "okay";
&sdhi2 {
status = "okay";
pinctrl-0 = <&sdhi2_pins>;
vmmc-supply = <&wlan_en_reg>;
bus-width = <4>;
non-removable;
cap-power-off-card;
keep-power-in-suspend;
#address-cells = <1>;
#size-cells = <0>;
wlcore: wlcore@2 {
compatible = "ti,wl1837";
reg = <2>;
interrupt-parent = <&gpio2>;
interrupts = <5 IRQ_TYPE_LEVEL_HIGH>;
&sdhi3 {
pinctrl-0 = <&sdhi3_pins>;
pinctrl-1 = <&sdhi3_pins>;
vqmmc-supply = <®_1p8v>;
bus-width = <8>;
mmc-hs200-1_8v;
mmc-hs400-1_8v;
non-removable;
fixed-emmc-driver-type = <1>;
status = "okay";
&usb_extal_clk {
clock-frequency = <50000000>;
&usb2_phy0 {
pinctrl-0 = <&usb0_pins>;
vbus-supply = <&vbus0_usb2>;
status = "okay";
&usb2_phy1 {
pinctrl-0 = <&usb1_pins>;
status = "okay";
&usb3_peri0 {
phys = <&usb3_phy0>;
phy-names = "usb";
companion = <&xhci0>;
status = "okay";
&usb3_phy0 {
status = "okay";
&usb3s0_clk {
&xhci0 {
pinctrl-0 = <&usb30_pins>;
status = "okay";
&cmt0 {
status = "okay";
&cmt1 {
status = "okay";
&tmu0 {
status = "okay";
&tmu1 {
status = "okay";
&tmu2 {
status = "okay";
&tmu3 {
status = "okay";
&tmu4 {
status = "okay";
