The amp chip in question is used in the Sony MEX-XB1000BT car radio. This car radio has a problem: it turns off and resets every time the volume is turned to maximum, even if the car radio is connected directly to the 12V battery with a large capacity cable. How come? Is it a voltage drop problem? Should I use an even larger and even shorter cable? Should I use a high capacity super capacitor in parallel with the battery?
Thank you very much.
aldo.alessi@tin.it
