Other Parts Discussed in Thread: TAS2505
Hello. How can I run a .wav file? What should I do? What steps should I follow? Could you help?
I am playing an audio file from the speaker via Windows, but I need to do this at the MCU level.
Hi Mustafa,
You will need to consult support with your processor more than the amplifier. The amp is not capable of storing any wav files. It only receives I2S data. You will need to store the wav file on your MCU and play it back on an I2S bus to give to the TAS2505.
Jeff McPherson
